Experiences with aftermarket springs?
Page: Previous  1, 2, 3  Next
lonbordin
lonbordin is offline
PostPosted: Thu Jun 15, 2006 7:59 pm    Post subject: Thank you Riceye. I just install the Napa # 58595 Reply with quote
Installing these shocks are one of the best upgrades for your westy. My 1985 Westfalia Weekender now sits 17" in front 18" in rear. Hooray!!!
Check out the pics at my blog:
http://lonbordin.blogspot.com/
riceye wrote:
This borders on travesty, and could get me booted from VW cyberworld, but I swapped out the OE (or OG - whatever) rear shocks with a pair of load leveling shocks. These are the ones with the coils around them. The ones I used are now Napa # 58595. They are widely used as rear shocks on late 70 to mid 80's Chevy vans.
I did do a great deal of research to find the shock with the same upper and lower mounting, and extended and comperssed lengths, and travel distance. Under normal load, the shocks are right in the middle of their travel range.
The vehicle leveled out nicely, and the ride improved dramatically. They have been on the vehicle for about 40,000 miles, and I've not had a problem.
I still like the Bilsteins for the front, though!
vwjedi
vwjedi is offline
PostPosted: Fri Jun 16, 2006 5:05 am    Post subject: Reply with quote
WBX- You have a PM.
I re-read this post and for some reason I don't seem to be answering your question. Yes, I do think the Carrat springs will sag in the back. Mine had the classic nose slightly up with the stock springs, not as bad as some I've seen. However the load rate must be quite different for "window vans" and "westy's" because mine def. sits nice and high with her butt up in the air now. Wink
I will pass on Provocyclist's good Vanagon mojo and give you my springs for the cost of shipping if you promise to use them. Very Happy Lemme know.
1987 Wolfsburg T25 still riding out. A bunch of other VW's passed on...
tclark
tclark is offline
PostPosted: Mon Jun 26, 2006 6:39 am    Post subject: Re: Thank you Riceye. I just install the Napa # 58595 Reply with quote
Boy this looked exactly what I wanted untill I doubled checked the specs
for the vw van shows
-27" uncompressed, 16" compressed going on 5/8" bolt up
the specs for 58595 show
-20" uncompresssed, 13" compress might not be so bad BUT it 1/2" bolt up
are my specs for the vw rear shocks correct ???
riceye- you say you did r&d to get compatibility but these specs seem to be way out what did I get wrong ??
riceye
riceye is offline
PostPosted: Mon Jun 26, 2006 5:28 pm    Post subject: Reply with quote
I PM'd you with the pages and specs, but here it is again, for all to see:
Hey Tim,
Here is what I found for you:
http://www.monroe.com/products/mp_detail.asp?cat=S...0Absorbers
http://www.napaonline.com/MasterPages/NOLMaster.as...ter+-+Rear
http://info.rockauto.com/Monroe/58595.html
$90.79 US per pair at www.rockauto.com.
There is some body material that will interfere with the coils. Another poster cut this off with a die grinder and cutoff wheel. He included pictures in his post. The metal is obscured by the tire in the picture.
http://www.thesamba.com/vw/forum/viewtopic.php?t=105142
I just bent it over with an adjustable wrench or Vise-Grips. Don't recall which, as that was back in 1994. They have been great since.
Thanks for the thumbs up.
I'm pretty sure my research is correct.
Regards,
Ric
'87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig
tclark
tclark is offline
PostPosted: Thu Jun 29, 2006 11:52 am    Post subject: Reply with quote
Hey Tim,
Regards,
Ric
Heya Rick
Yah the specs on the page show monroe as the same as I found & that was the issue
The van show
Do I have the wrong specs for the 85 van ???
riceye
riceye is offline
PostPosted: Thu Jun 29, 2006 3:24 pm    Post subject: Reply with quote
Hi Tim,
The specs for Monroe's replacement shocks for an 85 vanagon are here:
http://info.rockauto.com/Monroe/34971.html
The specs for the shocks I am running are here:
Regards,
Ric
tclark
tclark is offline
PostPosted: Thu Jun 29, 2006 9:14 pm    Post subject: ok so all can see vw spec monroe vs load leveler Reply with quote
THANK YOu RICK ...
Looks like I got the vw spec wrong
VW specd monroe http://info.rockauto.com/Monroe/34971.html
Upper/lower Bolt on A=12MM & B=1 9/16
Compressed Length 13.375
Extended Length 21
Length of Travel 7.625
Upper/lower Bolt on A=½ & B=1 5/8
Extended Length 20.875
Length of Travel 7.875
so the only real diff is in the upper/lower bolt holes
looks like there is 1/16" of play in the bolt holes
and the load levelers travel .2 of a inch longer
on a real deep dip I guess Smile
good call it was funny i posted to the vanagon list and not a beep
good or bad I just think this is a great solution just shows
yiou gotta keep your eye on both samba & vanagon list Smile
I wonder I might even be a bit raked bcus I have installed
1" aluminium spacers already under the rear springs at top
camit34
camit34 is offline
PostPosted: Sun Dec 17, 2006 5:02 pm    Post subject: Reply with quote
r39o wrote:
Measure from the center of the wheel to the bottom of the fender flare. That way we all end up being able to compare equally, regardless of wheel or tire size. Mine is 17.5 in the back and 18 in the front (and yes, like many 85 Westies, the nose points up.)
So what do you have front and rear?
I was searching for posts about shocks and ran across this old thread. I noticed just about everyone stating they are running at about 17 to 18 inches, I also noticed most of those figures are on mid 80's (84's & 85's)
I was wondering if the same would apply to my 1980? I measured mine at just over 15" in the front and just over 17" in the rear...is that correct for an 80?
Thanks!
In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD)
1965 Bug (SOLD)
camit34
camit34 is offline
PostPosted: Wed Dec 27, 2006 4:56 am    Post subject: Reply with quote
Thanks!
No one?
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1965 Bug (SOLD)
airkooledchris
airkooledchris is offline
PostPosted: Thu Apr 05, 2007 12:39 pm    Post subject: Reply with quote
camit34 - I wondered the same.
I run an 81 AC westy, measured at 16 up front and 17 in the back.
when going over bumps it sqeaks like crazy, and I have that nose dip under heavy breaking.
I am thinking about going this 'napa' shock route myself.
riceye
riceye is offline
PostPosted: Thu Apr 05, 2007 1:02 pm    Post subject: Reply with quote
Chris,
Check out my reply to the thread "Sagging Rear and Electrics"
Cheers,
Ric
[email protected]
skinnyboy76@hotmail.com is offline
PostPosted: Sat Apr 21, 2007 5:34 pm    Post subject: Reply with quote
82 diesel westy, 125k miles, 15" front 16" rear. i thought mine was extra low, but seem all early 80's westys are very low
westy87
westy87 is offline
PostPosted: Sun Apr 22, 2007 8:07 am    Post subject: Reply with quote
Back to RAISING the ride height in the rear - to correct the driver side sag, until I got new springs, I cut a circular piece of 3/4 plywood, painted it flat black, and inserted as a spacer. I pulled it three years later when I replaced the springs and it continued to show no signs of wear. So there's a cheap and easy fix!
1621
1621 is offline
PostPosted: Tue May 15, 2007 1:34 pm    Post subject: Reply with quote
This may seem a silly question, but what is the primary difference between the Monroe Sensatracs discussed above, and the Bilstien HDs for the rear?
I know the coil spring is different, but I don't understand how this will provide any additional height as it's still simply a shock absorber.
Also, are there "rebound ratings" (I made that up if you couldn't tell) that indicate whether the shock provides more or less rebound strength? If so, again what is the difference between the two?
I'm trying to raise the rear a bit more, and I currently have Bilstien HDs. I like the ride currently, so I don't want to go with something with less dampening, though a little more dampening isn't bad. Just don't want it to ride like my lifted Jeep. Is it worth it to replace the rears with the Sensatracs?
Lundy
'85 Westy
Dogpilot
Dogpilot is offline
PostPosted: Tue May 15, 2007 2:03 pm    Post subject: Reply with quote
I don't want to sound like a shill for GoWesty, but they have released some new progressive springs that raise the rear and front a bit. They are not cheap, but then again, what is these days.
http://www.gowesty.com/ec_view_details.php?id=4090&category_id=253&category_parent_id=
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
1621
1621 is offline
PostPosted: Tue May 15, 2007 8:47 pm    Post subject: Reply with quote
Lundy
Anyone? Bueller? Bueller?
'85 Westy
riceye
riceye is offline
PostPosted: Wed May 16, 2007 5:49 am    Post subject: Reply with quote
Because of the coil-over construction the SensaTracs bear some of the weight, which ends up raising the vehicle, both empty and loaded.
Simply transfers some of the weight from the coils to the shocks.
I have not driven a van with fresh Billies or Konis in the rear, so I can't compare. I have enjoyed a rather stiff ride for over ten years with the NAPA (Monroe) coil-overs. Better in crosswinds, and highway cornering. I don't do much off-roading, other than National Forest campground trails, but the van has never, to my recollection, bottomed out.
Shocks tend to wear slowly, and changes in performance are diffcult to perceive. I changed mine, initially, when I noticed the right rear wheel bouncing like a basketball going over RR tracks.
Prosit,
Ric
JWPATE
JWPATE is offline
PostPosted: Thu Jan 13, 2011 8:09 pm    Post subject: Reply with quote
Old thread but a new one to me. Thanks to riceye for researching this and passing on the info.
Just ordered a set.
vanagonjr
vanagonjr is offline
PostPosted: Fri Jan 14, 2011 7:27 pm    Post subject: Reply with quote
vwjedi wrote:
Notice how they don't even rebound in my hand! Are yours this shot? Could be partial cause of sag.
Are they gas charged shocks? If not, then they won't (nor be expected to).
furrylittleotter
furrylittleotter is offline
PostPosted: Sun Aug 14, 2016 8:48 pm    Post subject: Re: Experiences with aftermarket springs? Reply with quote
I am adding the following post to threads related to rear spring selection.
It is applicable to 2wd and Syncro:
"After trying new shocks, carat springs, and new poly rear arm bushings I was still extremely dissatisfied with my rear suspension setup.
It simply wasn't moving.
I wanted to be able to custom select my springs based on rate so I decided to fit 2.5" coilover springs and see what happened.
Here is a photo in place but before paint and without rubber isolators.
No unusual angles. Slight rub on rubber sleeve at stop on top. Seems acceptable.
First I fitted 450lb 10" 2.5" Eibachs.
Still could barely move the van up and down jumping up and down on bumper.
Then I fitted 400# springs and it finally moved.
So far so good more testing to do.
I made the mounts from 1/4" steel plate and steel pipe coupling (conduit) cut in half, welded in.
The extra rubber is 1/2" reinforced belting I custom ordered to help isolate.
I cut it to fit.
The lower mount is angled.
The factory bump stop is covered with a thick rubber sleeve ( 1/4"?)
Fun little project."
Neil2
Page 2 of 3
