8 week mini-series on cooling systems on 4th Dimension Radio
Page: 1, 2, 3  Next
Jake Raby
Jake Raby is offline
PostPosted: Fri May 18, 2007 6:05 am    Post subject: 8 week mini-series on cooling systems on 4th Dimension Radio Reply with quote
Thats right! Beginning with today's show (5/18/07) and spanning for the next 8 weeks the entire 4th Dimension Radio podcast will be on the very myth infested topic of "cooling"...
In these shows we will be going over every aspect related to cooling from myths to testing date, cooling essentials, cooling tips and even detailed information about the cooling system test work that we did here in the lab and on the road.
Here is the tentative schedule for this mini-series on 4th Dimension Radio:
5/18- Cooling essentials for both Type 1 and Type 4 engines. In this show we'll go over the things that must exist before any engine can best utilize it's cooling system.
5/25- Engine temperatures. In this show we'll go over the minimum and maximum acceptable running temperatures for TI and TIV engines as well as the acceptable engine temperature variances between cylinders/ heads. This show will be full of information that is not posted on any website, book or other reference material.
6/1-Cooling fan differences- Radial Vs. Axial.. This show will go over the two different types of cooling fans used and their strengths and weaknesses and why they work better in different applications.This show will basically be "911 Vs. Stock/DTM cooling" more than anything else.
6/8 -Does my larger engine than stock engine have to run hotter than a stocker?? This is a hugely misunderstood topic!! In this show we'll bust the myth as it relates to larger engines running higher temperatures.
6/15-Cooling the Type 4 engine equipped with the "stock" pancake cooling system. In this show we'll go over the way the stock system functions, this show will be geared mostly toward buses and 914s and we'll divide the show down the middle and go over the most critical questions and information concerning both applications.We will cover stock and performance base engines as well.
6/22- Type 4 upright conversion detailed information. In this show we'll go over the function and characteristics of the various Type 4 conversion cooling systems including the DTM, 911 style shrouds and the Cali conversion.
6/29-Cooling the Type 1 engine. The Type 1 engine is the target of many aftermarket solutions aimed at providing better cooling for the engine. Find out why most of these don't work as well as stock! We'll be going over our cooling system evaluations and their results in this show as well as covering the things that must exist for any cooling system to be effective on the Type 1 engine.
6/29- The Aircooled Technology DTM cooling system. This show will go over the Type 1 and Type 4 DTM, it's entire history, it's development and how the DTM has proven to be the best cooling system solution available. This show will cover the Type 1 and Type 4 shrouds universally.
These shows are a must listen!! Even if you don't typically listen to our Radio Shows make sure to listen to this mini-series!!
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Fri May 18, 2007 6:37 am    Post subject: Reply with quote
Sounds good Jake.
Can you FF to 6/29? LOL Wink
Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
vwdmc16
vwdmc16 is offline
PostPosted: Fri May 18, 2007 2:22 pm    Post subject: Reply with quote
will you be having more mini series? like for exhuast, or what have you?
"Fiberglass is for boats and race cars-Steel is real-fix it right the first time"-Wolff
'72 Ghia: http://i111.photobucket.com/albums/n146/vwdmc17/100_1964.jpg
'72 Honda Z600
'81 Delorean
www.EVILGENIUSRACING.com
Street Bug 29
Street Bug 29 is offline
PostPosted: Fri May 18, 2007 2:25 pm    Post subject: Reply with quote
I want to do the type 4 convertion to my shroud,,
Jake Raby
PostPosted: Fri May 18, 2007 3:00 pm    Post subject: Reply with quote
After you hear my info on that mod you might change your mind...
This is the only series we'll be doing thats this in depth, the others are a max of two shows in duration..
Jake Raby
Droolman
Droolman is offline
PostPosted: Fri May 18, 2007 3:26 pm    Post subject: Reply with quote
Was I wrong in the fact that ART took you out of the race a few weeks ago using EMPI products including fanshroud? You doing a piece on that.
1967 blue bug
1965 drag bug
One Owner
One Owner is offline
PostPosted: Fri May 18, 2007 3:46 pm    Post subject: Reply with quote
1st show is up at http://www.richchristensen.com/radio/4thdim/COOLINGpt1.mp3
or just subscribe in Itunes
http://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=186541956
Watch Won&Done only on MAVTV
--77 Riviera--
http://www.thesamba.com/vw/forum/viewtopic.php?t=489967
Jake Raby
PostPosted: Sun May 20, 2007 12:03 pm    Post subject: Reply with quote
We didn't have any temperature issues... Clutches and bent valves are what took us out Smile
BTW- We were not racing any other car, not Art and not the Chevelle that was in the episode, we were being challenged by the host of the show and were not lined up against any other car when we lost the competition....
Art did kick some serious ass in the challenge, I'll be the first to admit that. He and his crew did a great job!
Jake Raby
redhot
redhot is offline
PostPosted: Sun May 20, 2007 1:02 pm    Post subject: Reply with quote
Jake: where can I find some of your old shows?
I think there was one on carbs, but couldnt find it when I followd the link on your webpage.
Jake Raby
PostPosted: Sun May 20, 2007 1:50 pm    Post subject: Reply with quote
We pull and archive them every so often.. They will all be available for sale (at a very good price) through my store soon... Maybe in just a couple of weeks they'll be available.
Someone may have saved the show you need and I certainly don't care if you guys share them amongst yourselves..
Jake Raby
redhot
redhot is offline
PostPosted: Mon May 21, 2007 2:03 pm    Post subject: Reply with quote
Thank you for a great effort in enlightening me and probably a lot of others!
Well: if anyone have them, please PM me Smile
synapticburn
synapticburn is offline
PostPosted: Sat May 26, 2007 10:45 am    Post subject: Reply with quote
Loving the 4th dimension show. I listened to the first episode on cooling as I was replacing a huge steam to air heat exchanger at work, and it's nice to hear someone discuss the concepts and science behind a lot of this stuff.
I can only get the last 6 shows to download, and couldn't find any on the site yet. There are compaines that will create and distribute the cd's for you, I know of another podcast that does just that and the price is very reasonable. PM me and I can pass along the info if you need it.
Ronnie
'66 bug, 2275cc slowpoke (no name yet)
'98 GMC sierra (grandpa truck)
'05 Vstrom
One Owner
PostPosted: Tue May 29, 2007 12:03 pm    Post subject: Reply with quote
2nd Show up in all the usual places!
-Ray
--77 Riviera--
Jake Raby
PostPosted: Tue May 29, 2007 2:31 pm    Post subject: Reply with quote
Yep! This one is another good one!
Jake Raby
One Owner
PostPosted: Tue Jun 05, 2007 10:04 am    Post subject: Reply with quote
3rd Show is Up!!
-Ray
--77 Riviera--
Jake Raby
PostPosted: Tue Jun 05, 2007 10:23 am    Post subject: Reply with quote
Gotta hear this one!! I go over a lot of the 911 cooling shortcomings!
Jake Raby
One Owner
PostPosted: Fri Jun 08, 2007 4:46 pm    Post subject: Reply with quote
The 4th Part is available
-Ray
--77 Riviera--
BugUser
BugUser is offline
PostPosted: Mon Jun 11, 2007 2:49 am    Post subject: Reply with quote
-Ray
Somehow, all archived IVth Dimension Radio broadcasts on www.richchristensen.com seem to be broken?!?
WideFive
SBS Hit Squad
WideFive is offline
PostPosted: Mon Jun 11, 2007 5:59 am    Post subject: Reply with quote
From Raby's sig...
"4th Dimension Radio" listen to it weekly @ www.aircooledtechnology.com/radio
Aaron D. Badertscher
Click here for ALL my links.
One Owner
PostPosted: Mon Jun 11, 2007 10:07 am    Post subject: Reply with quote
Problem Fixed
-Ray
--77 Riviera--
Page: 1, 2, 3  Next
