Dull case to shiny case...
volky1970
volky1970 is offline
PostPosted: Mon May 21, 2007 6:13 pm    Post subject: Dull case to shiny case... Reply with quote
Hi,
I am currently rebuilding my 1585cc single port engine. I am going to convert it to a 1776cc dual port engine. During disassembly I noticed the case to be dull.
I decided to sandpaper the case for a natural smooth alloy look.
Motor out:
This is how the case looks:
A little sandpaper:
It will take some time but it will finish with a smooth surface.
1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon May 21, 2007 6:16 pm    Post subject: Reply with quote
When you polish the case you close the pours and reduce the surface area.
In other words the engine will run hotter.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
volky1970
PostPosted: Mon May 21, 2007 6:29 pm    Post subject: Reply with quote
Thanks Glenn,
Do you know of a product I can use to at least make it look better?
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Mon May 21, 2007 6:57 pm    Post subject: Reply with quote
volky1970 wrote:
Thanks Glenn,
A wire wheel could clean off the gunk while leaving the outside surface rough.
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
Mr. 010
Glenn is offline
I washed mine with some degreaser and that's it.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
a.wilson
a.wilson is offline
PostPosted: Mon May 21, 2007 7:20 pm    Post subject: Reply with quote
Triple 000 or higher steel wool always does the trick.
Be kind to all critters. America's "H8TERZ" can drink sludgy used Motor Oil!
oemwolf
lowmitsu
lowmitsu is offline
PostPosted: Mon May 21, 2007 7:40 pm    Post subject: Reply with quote
Hotter or not it looks good,but I'm a neat freak.I'm betting it won't be that noticable a difference..
Mr. 010
Glenn is offline
PostPosted: Mon May 21, 2007 7:44 pm    Post subject: Reply with quote
You really only see 15% of the case. is it worth it?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
John M.
John M. is offline
PostPosted: Mon May 21, 2007 8:02 pm    Post subject: Reply with quote
That finish won't last very long either.
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
oorwullie
oorwullie is offline
PostPosted: Tue May 22, 2007 12:23 am    Post subject: Reply with quote
i had a type 4 engine fan housing bead blasted,was really shiny but it was all pretty oxidised again after 6 months.. lesson learned. Wink
Mr. 010
Glenn is offline
PostPosted: Tue May 22, 2007 3:08 am    Post subject: Reply with quote
That's aluminum and the Type 1 case is magnesium. It will start to darken in days.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
oc63rag
oc63rag is offline
PostPosted: Tue May 22, 2007 8:57 am    Post subject: Reply with quote
I'd spend my time and effort on cleaning/painting everything above the case. Just a thorough cleaning makes a huge difference. If you paint the tin, fan shroud, intake, etc. it will look really nice.
Designed for four soldiers and a machine gun...also for family use.
My food baby is crowning.
