flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1173 Location: Las Vegas, Nevada
Posted: Tue Apr 10, 2007 9:05 pm Post subject: Wide five disc brakes for type 3 |
This is a story of my pain. So, my wife wanted wide five disc breaks on her 67 squareback. It starts off simple enough, just put adapters but you need a 5/16 spacer behind it so the adaptor can clear the caliper. After that bolt the (Rocket brand five spokes, these have about 7/16 less offset than the Eagle Alloys) five spokes up that also set the wheels out . When all is said and done the front wheels are set out just a little to far at the inner edge of the finder with the 185/55/15. The car, she also likes lowered 2 outer splines in the front and one outer spline in the rear.
So, I am now ready to take the car for a ride. Going down the street I hit a cupple small bumps and then a large one, I had not noticed before even in my lowered bug. Well, it ripped a good chunk off my side wall. When I got home I was livid at the damage it had done to the side wall of the new tires. I told my wife she needs to choose a new rim or have another solution in mind.
I started to think of her options rims or ? wide five Bug disc breaks. So, I made some calls to some good friends at Bill & Steves on the mesurements the bug disc break kit. My questions were do thay cause a change of offset when put on a stock beetle? And the bearings should be the same for the 67 as the beetle? Yes, the bearings are the same and no the offset is not changed. So I ordered them. Two days later thay were here, Empi disc break kit. It was quite an ordeal the brackets had to be fit in place of the original caliper mount that had to be cut off. After that modification and drilling and tapping for the grade 10-10mm bolts and making sure the caliper bracket had a 5/8 gap around the center ring of the caliper bracket, it was finally done, at least on one side. Both sides took me two days to install, I slotted the rotors in that time also. It brought the rims in appox. one inch on each side as I wanted and no rubbing at all...even when turning!!!!
All in all I must say it stops way better than my 67 fastback, that I also put new slotted ATE rotors on and both cars have new master cylinders.
This job is not for the faint at heart, it is about a 9 on the scale of difficulty. So, take caution.
Pictures will be posted when my wife can get to them.
wolfman's brother Samba Member
Posted: Wed Apr 11, 2007 2:42 pm Post subject: |
csp makes a wide 5 disc kit specific for type 3,comes with EVERYTHING you need and no clearance issues.the only thing you need to know when calling in your order is what size spindle you have (early or late)so they can send the right bearings. _________________ insanity takes it's toll,please have exact change ready.
my imaginary friends keep telling me I have a mental problem. |
Posted: Wed Apr 11, 2007 10:23 pm Post subject: |
| Yes, I looked at the other disk kits but the type 3 kits had the stock off set and I wanted to bring the wheels in a little more because the 5 spoaks always set out a little further. And Im really not fond of compromising the front suspension of the car with a beam that was designed for a lighter car to get the same results. Also the bug,ghia and type 3's all had the same calipers and roters at that time. |
jimmynotch Samba Member
Joined: February 11, 2003 Posts: 2901 Location: sacramento
Posted: Wed Apr 11, 2007 11:27 pm Post subject: |
The CSP kit is great... but for $1500 it better be. The Germans sure know how to engineer some good stuff, its just too bad they are so much money. _________________ Jim in Sacto -
| my wonderful loving supportive wife wrote: |
| You guys are dorks. |
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13592 Location: Tejas!
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Thu Apr 12, 2007 10:03 am Post subject: |
I'm a little confused. Did you order a '67 Type 1 wide 5 kit?
Pics! Pics! Pics! _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Posted: Thu Apr 12, 2007 1:06 pm Post subject: |
Does anyone know how to add pictures and be able to view them without a link? I've been trying for awhile now to post them for you guys to see and I can't seem to get it to work. Help  |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11497 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Thu Apr 12, 2007 1:10 pm Post subject: |
of course we can... where are your pictures? _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Thu Apr 12, 2007 1:24 pm Post subject: |
| flyinglow94 wrote: |
This should help you:
http://www.thesamba.com/vw/forum/viewtopic.php?t=6 _________________ Phillip Bradfield
Posted: Thu Apr 12, 2007 3:26 pm Post subject: |
I'd be a little leary on how accurate drilling of the holes were, but it looks pretty straight forward. Any binding? Any grabing of the brakes on one side?
What year of Type 1 Beetle was the brake kit for? _________________ Phillip Bradfield
Posted: Thu Apr 12, 2007 5:02 pm Post subject: |
empi 66-67 beetle disk brake kit was used. As for drilling the holes I clamped the caliper bracket in position and used a center punch then a center drill and finelly drilled for the 10mm 1.0 tap size. (my 10mm 1.0 tap had cracked while doing this so I had to locate another not easy at 9pm) I had also checked the spacing from the bearing seal edge to the inside edge of the caliper bracket with a 5/8 round rod.
I think my wife also posted pictures of 61-65 type 3 spindles that I did not use as it looked like I would have to drill a new lower mounting hole for the new caliper bracket. |
Posted: Thu Apr 12, 2007 5:11 pm Post subject: |
| the brakes have no pulling, binding or draging . And I drive the car on my days off . It is hard to choose between that or the fastback even though the square is "the wifes" . |
Posted: Fri Apr 13, 2007 10:04 am Post subject: |
Very cool. I have been looking for a way to convert my 4 lug disk to 5 lug disk for a while.
Nice work! Thanks for the link to the pics! _________________ Phillip Bradfield
Erik G Samba Member
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5476 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Fri Jun 29, 2007 10:50 am Post subject: |
Okay...so it took me a while to take the time to figure it out. Thanks for the help.
Wow...that's a lot of pictures...sorry...
Okay I know this isn't rocket science... LOL
Posted: Fri Jun 29, 2007 10:53 am Post subject: |
Uh, you need to attend class again.
Add [img] before and [/img] after each URL listed. _________________ Phillip Bradfield
