john7 Samba Member
Joined: August 06, 2003 Posts: 1550 Location: Garden grove ca
Posted: Sat May 28, 2005 9:50 pm Post subject: Zwitter speedo |
My 53 zwitter has a speedometer dated 3/53 but looks like a 53-60 type speedo. could my zwitter be so late that it had a late type speedo? or?
as far as i can tell it is original. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
john7 Samba Member
Posted: Sat May 28, 2005 10:34 pm Post subject: |
they are a single arrow like the 53-60 speedo, that is why i asked.
could my car be one of the last zwitters? i dont have the body # as the car has been clipped in the 80's |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Tue May 31, 2005 5:03 pm Post subject: |
The '53 speedo is '53 only and is correct for your car. The size of the double headed arrow and the shift points which reflect the 25hp motor are one year only. If you don't want it---I'll buy it. You won't find another one.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Matthew Tolbert Samba Member
Posted: Wed Jun 01, 2005 5:02 am Post subject: 53 speedo |
could someone post a pic of a 53 speedo. i have a may 53 oval and i was wondering about he shift point thing bob mentioned. it is in kph and the date stamped on back is correct i just wanted to make sure the internals had not been changed out.
thanks
matthew |
Posted: Wed Jun 01, 2005 6:05 am Post subject: |
Mine is in MPH and I don't own a digital camera.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Wed Jun 01, 2005 8:44 am Post subject: speedo |
| are the shift points at a lower speed than the 36 hp cars? if so what are yours at and maybe i could convert to kph to see if they are the same. not sure if that would be correct but worth a try i guess. also what is different about the size of the arrows bigger or smaller? |
Posted: Wed Jun 01, 2005 3:44 pm Post subject: |
The arrow is smaller than the '54 and later speedo and the shift points are at 13, 28, & 43. Hope that helps. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
kafer53 Samba Member
Joined: July 24, 2004 Posts: 904 Location: Ontario, Canada
Posted: Wed Jun 01, 2005 3:53 pm Post subject: |
| I've seen that 53 Only Speedo that came out just after the seperated arrows for the zwitter and it is definately a rare piece! It has a joined arrow that is smaller than the 54 style "fat arrow" and still has the shift points and is date stamped for 53. Not too many of these around. |
Jimmy Perez Samba Member
Joined: September 08, 2003 Posts: 310 Location: Cruising in Cali, Nomad
Posted: Wed Jun 01, 2005 8:27 pm Post subject: Zwitter Speedo |
| Hi Just put a picture on Gallery, Parts and Accessories Bug. Don't know how to tranfer yet, so 1 of you can transfer it to here. There are 2 types of 53 speedo's both have small arrow indicaters. later 1 has arrow indicaters connected and early 1 does not. The picture is of speedo is dated 5-53 later 1. Hope that helps. |
Posted: Wed Jun 01, 2005 8:45 pm Post subject: |
The pictured speedo is for a '53 oval. The early one you refer to is for the Zwitter, produced until March of that year. Your date stamp makes this an oval speedo. http://www.thesamba.com/vw/forum/album_page.php?pic_id=209989 _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
surfindo Samba Member
Joined: March 11, 2004 Posts: 442 Location: Haarlem, Netherland
Posted: Thu Jul 26, 2007 7:15 am Post subject: |
while searching for zwitter speedo I found this old post,
how about this oval speedo dated 4.53 .the arrow look diferent but the shift point exacltly the same w the pic above, my 55 speedo has taller/higher shift point, maybe sombody change the internal parts and just used the housing??
Thanks
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9408 Location: Northwood, NH USA
Posted: Thu Jul 26, 2007 7:21 am Post subject: |
| 53 0val wrote: |
Mine is in MPH and I don't own a digital camera.  |
Do you have indoor plumbing Bob? Did you know the Beatles broke up??
 _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Jul 26, 2007 9:23 am Post subject: |
| johnshenry wrote: |
| 53 0val wrote: |
Old quote.... My digital camera does not interface with my computer. The programs do not match up. I have a Sony camera and Mac computer and one will not read the other. The camera is one of the first digitals (took over my daughters when she got a upgraded one.) and I just need to buy a new one. There are no problems with the new stuff. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Thu Jul 26, 2007 9:25 am Post subject: |
| 53 0val wrote: |
| johnshenry wrote: |
| 53 0val wrote: |
Old quote.... My digital camera does not interface with my computer. The programs do not match up. I have a Sony camera and Mac computer and one will not read the other. The camera is one of the first digitals (took over my daughters when she got a upgraded one.) and I just need to buy a new one. There are no problems with the new stuff. |
Oh, I see that post IS quite old..... glad to see you are "keeping up" Bob........  _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Jul 26, 2007 10:05 am Post subject: |
Hi Bob thanks!! i've seen that add yesterday, my question was the oval speedo pic I post and the one above, they both come from 53 (one 5-53 the one I post 4-53)but the arrows look diferent?? if the theory there are 2 types of 53 speedo,
1. zwitter speedo with separated arrows
2.speedo with joined arrow that is smaller than the 54
my question why this one dated 4-53 but has fat arrow??
Posted: Thu Jul 26, 2007 10:07 am Post subject: |
| surfindo wrote: |
Hi Bob thanks!! i've seen that add yesterday, my question was the oval speedo pic I post and the one above, they both come from 53 (one 5-53 the one I post 4-53)but the arrows look diferent?? if the theory there 2 types 53 speedo,
Arrows look the same to me, between those two. Look at how many lnes it crosses top to bottom, and how much space between it and the warning lights on either side.... Looks to same to me... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Jul 26, 2007 10:29 am Post subject: |
| johnshenry wrote: |
| surfindo wrote: |
Arrows look the same to me, between those two. Look at how many lnes it crosses top to bottom, and how much space between it and the warning lights on either side.... Looks to same to me... |
is it ?? hmmm i need to check my eyes!!! |
