Extremely loud, screeching speedometer
djs94124
djs94124 is offline
PostPosted: Sun Aug 05, 2007 9:19 pm    Post subject: Extremely loud, screeching speedometer Reply with quote
I searched for this problem in the forum, but found nothing.
The speedometer in my '87 Westfalia recently began making an extremely loud screeching noise while driving. It's loud enough where I can't hear my radio. It started out as intermittent but now happens every time I drive. It sounds like something inside the speedometer head is rubbing or has run out of lubrication during rotation. I find that I can make the sound go away if I manually pull the speedo cable from side to side while driving. However when I let go of it, the noise returns. This means that I could probably use a tie-wrap to forcibly hold the speedo cable in a position where it doesn't make the noise, but this obviously is not the optimal solution.
I disconnected the speedo cable from the speedo head, and there is no noise, so I am assuming the problem is coming from the head, not the speedo cable.
I also removed the instrument cluster and then removed the speedo unit to examine it, but it appears to be OK. No parts dropped out, no loose bits of metal or plastic to be seen. I can rotate the drive gear with a small screwdriver and it rotates smoothly.
Both my speedometer and odometer work fine, no bouncing or clicking, just this infernal racket while driving.
Anyone run into this before?
Thanking you in advance....
-Dan
1987 2WD Westfalia
Modifications: GoWesty 2300 engine & rebuilt transaxle, 16x7.5 tire/wheel kit, South African "Big Brake" kit, Bilstein HD shocks, Whiteline front sway bar, 2WD Lift Springs, 2nd deep-cycle battery.
UH60Driver
UH60Driver is offline
PostPosted: Mon Aug 06, 2007 7:45 am    Post subject: Reply with quote
Did you try lubing everything up yet? Graphite on the cable and whatnot?
tencentlife
tencentlife is offline
PostPosted: Mon Aug 06, 2007 9:42 am    Post subject: Reply with quote
The input bearing on the speedo head has dried out. Remove the cluster again and lay it on it's face. Get a couple drops of very light oil, sewing machine, 3in1, MMO, even ATF, into the gap around the input shaft collar. Don't overdo it; you don't want excess oil to go further into the head as it will get into the gap between the drive magnet and cup and cause the needle to get jumpy.
Mathew Zelezen
Mathew Zelezen is offline
PostPosted: Mon Aug 06, 2007 3:22 pm    Post subject: Reply with quote
I had exactly the same problem you're describing on my 86 Syncro... Its loud enough to drive you to drink (although not enough to drink and drive).
I tried everything that was suggested, sprayed all kinds of lubricants into the housing, took apart the speedo to check for something that would jump out at me, even zip tied the cable so that it was pulled to the side (that worked for about a week)...
In the end the solution turned out to be Moab, Utah.
I drove the 2 hours it took from my house to Moab one weekend with the speedometer cable plugged in screeching away... a half our into the journey the screeching started to subside until it went away all together.
That was 4 months ago, the speedo works great and I haven't heard a peep yet.
Sorry its not very scientific, but I'd give it a shot considering the prices of replacement housings out there...
87 Syncro Tintop
~Rocky J Motor
~Steedle Trans
Of all sad words of tongue or pen, the saddest are these: It might have been.
Rhinoculips
Rhinoculips is offline
PostPosted: Sat Nov 22, 2008 5:34 pm    Post subject: Reply with quote
I'm resurrecting this thread in hopes that the OP solved the problem and he could share his experiences or someone else can make a suggestion. My speedo is making such a hell of a racket that I can't even hear myself think let alone my radio! I have tried lubing it with a dry bike chain oil, 3 in 1, Silicon spray (commonly used on bike cables), etc. No luck. Maybe I will try Mathews trick and drive to Moab for a weekend getaway! Laughing
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
wgargan
wgargan is offline
PostPosted: Sat Nov 22, 2008 6:00 pm    Post subject: Reply with quote
I too would like advice tips etc...my van does it when it is cold and high humidity. When it warms up it does not do it. I have yet to pull it apart but i presume there are some bushing that where out on one of the spinning parts within the cluster, not just where the cable attaches.
Current ride:
1983.5 Watercooled Vanagon 'L' Automatic transmission
djs94124
djs94124 is offline
PostPosted: Mon Nov 24, 2008 12:50 am    Post subject: Reply with quote
Original Poster here:
I finally resolved the problem by replacing the speedometer with a good used unit. The source of the noise was apparently the shaft bearing, and I was not able to quiet the noise by lubricating it, so I located a used speedo on eBay, transferred my odometer gear cluster to it, and reinstalled. No more noise.
-Dan
1987 2WD Westfalia
j_dirge
j_dirge is offline
PostPosted: Mon Nov 24, 2008 2:39 pm    Post subject: Reply with quote
-Dan
Interesting.
My 89GL Westy speedo/cable is making a "clicking" sound.. not a screeching sound.
Just loud enough to hear over road noise.
Do you recall if there was a noise previous to the screeching? Did the symptoms worsen?
Will try the 3in1 per 10cent... just wondering if I should be sourcing a replacment speedo.
MootPoint
MootPoint is offline
PostPosted: Mon Nov 24, 2008 4:26 pm    Post subject: Reply with quote
They show up in the Classifieds with amazing regularity, usually available from SleepyJoe in Kelseyville for about $35. I got mine from him and then reset the odometer with the instructions at:
http://www.twistedlimbpaper.com/brian/vanagon/Odometer.htm
Fixing the odometer was much easier than I thought.
1984 Westy with tencentlife power!
targis58
targis58 is offline
PostPosted: Mon Dec 29, 2008 11:32 am    Post subject: Re: Extremely loud, screeching speedometer Reply with quote
-Dan
[/quote]
I was having exactly the same problem with my 90 westy and knowing that people have tried lubricating the speedo with differenrt lubes and not successful with it, I still wanted to try to lube it with something before having to replace the speedo.
And believe or not, it fixed
I stuffed regular vaseline into a little syringe I had and squirted into the back hole of the speedo after disconnecting the cable. I squirted enough vaseline until it came back out of the hole (it didn't take much vaseline) and connected the cable back on and drove. The minute I started driving I noticed the noise wasn't there anymore. Try this before buying another speedo. I didn't even have to remove the speedo out of the cluster to do this
90 westy 2wd w/ TBD
Volksbulli
Volksbulli is offline
PostPosted: Mon Dec 29, 2008 1:06 pm    Post subject: Reply with quote
Yup, I had that happen on my 67 Beetle, I was doing a highway trip in the winter, it started sounding off so loud I couldn't take it any more, I pulled off the side of the highway popped the hood pulled the wire cover off unscrewed the cable and dipped my pinky finger in a bottle of oil and slathered it all over the input shaft end put it all together got back up to 55 and it was quiet again.
It's a Volkswagen Thing, Even I Don't Understand!(o\|/o)
82' A/C Westfalia
67' Typ 1
96' Golf GL
Vanagonner
Vanagonner is offline
PostPosted: Wed Nov 11, 2009 8:11 pm    Post subject: Reply with quote
I had the same problem; I dutifully put 3-in-1 oil into the back of the speedo bushing, let it sit upside down for a few hours and put it back in. After running it for a while to get it worked in, it seemed to have solved it. However, when I first ran it, the dash was out. When I put the dash back in with the cluster, it started screeching like crazy when cold.
I discovered that the difference is the bend that the cable makes as it goes into the speedo. With the cluster cover off, I reached in with my left hand and pinched the cable to straighten out the cable as it entered the speedo (while driving 50). The noise went away, every time I did this. So I got a hose clamp the right size for the speedo cable (fuel line size) and put it on the cable a couple of inches from the end of the cable, near the speedometer (while not driving 50). This allowed me to put a zip tie on around the cable and the steel stay that is next to it, which anchors the steering wheel. This tugged it up enough to correct the angle of the cable so that it enters the gauge straight. Problem solved.
Sage
'82 Westy 1.6 D
the mighty n/a
shorepig
shorepig is offline
PostPosted: Thu Nov 12, 2009 12:10 am    Post subject: Reply with quote
My speedo just died, abour five minutes ago. No noise as described above. I was cruising at about 80 and noticed it was sorta jumping erratically between about 40 and 60....then, about 2 minutes later it dropped to 0, and there it rests Sad So, what the heck happened here, and how can I fix it?
tclark
tclark is offline
PostPosted: Thu Nov 12, 2009 12:25 am    Post subject: Reply with quote
let guess busted speedo cable either at the connection at the wheel
of the plastic shaft at speedo head
http://www.thesamba.com/vw/forum/viewtopic.php?t=38495
89 Westy with TDI AHU 1.9 manual lots of mods
85 GL 1.9, auto (for sold)
firepilot
firepilot is offline
PostPosted: Tue Jan 26, 2010 5:58 pm    Post subject: Reply with quote
Mine has been doing the exact same thing. It sat for quite a while in a dry climate without moving, so I am sure that was probably not good for the lubrication inside. When its cold, at about 30mph it starts to screech, and after its warmed up some, it does not do it bad until about 40mph.
Right now I have the cluster out and put some drops of penetrating oil in there and letting it sit for about an hour before putting it back in. And a good part of getting the cluster out was finding my lost antenna cable.
86 Westy Syncro
ihurley
ihurley is offline
PostPosted: Mon May 16, 2016 3:29 pm    Post subject: Re: Extremely loud, screeching speedometer Reply with quote
FYI, the screeching is most often caused by a worn bearing inside the speedo that is either rubbing itself or causes the magnetic wheel (used to motivate the needle to rise as you go faster) to rub on the inside of the speedo. Putting lube down the back won't do a damn thing. That hole goes no where, it is a solid shaft and you are just filling it up for it to squeeze out everywhere when you reinsert the cable, or cause the cable to not be able to seat properly because it is packed. The wear is cause by the cable going into the speedo at a sharp angle putting stress on the shaft and the copper sleeve bearing inside the speedo. Once that wears out there is no fix (unless you can find a very small and very precise copper sleeve bearing and can press the old out and the new in). Though I have had some success pressing the magnetic wheel down on the shaft sandwiching the bearing and reducing lateral wobble and rubbing. But this creates more tension and most often causes your speedo to read less accurately and bounce around more as the cable will slip when spin tension buids and it releases suddenly over and over on each turn.
It is also not a good idea to get lube in the back of the speedo as it can interfere with the magnet and cause erratic needle movement.
One solution would be to try and get the cable to go in perfectly straight to help the shaft spin perfectly centered in the worn out bearing and reduce friction and noise. Most of the time this is exactly what you end up doing when pulling it out lubing it up and putting it back in. Really all you did was put it back in straight and removed the lateral tension that was causing the shaft to rub on one side of the bearing more than the other.
Squidbrain
Squidbrain is offline
PostPosted: Sat Jan 12, 2019 7:40 am    Post subject: Re: Extremely loud, screeching speedometer Reply with quote
I found that putting carbon lube in the attacher thing under the dash just squeezed out everywhere, like ihurley said. I had hoped it would still ooze down and stop the horrible loud clacking noise that I get at the wheel.. only when it is cold out, under like 32 degrees. Going 1 mile an hour or more. But no luck after a few weeks. The noise sounds like cracking metal.. but stops when the clutch is pressed.. which seems odd? I am going to look under the thing today and see if I can change the angle at the wheel, then otherwise disconnect the cable at the wheel hub.. that should stop it. Otherwise I have another problem, not the speedo cable.
