tree hugger Samba Member
Posted: Fri Aug 10, 2007 1:14 pm Post subject: Welding behind number 3? |
Hi All
At what point is it necessary to weld behind number three on the case or is it just a standard must have conversion? I've got an AS41 case I was planning on building up out of parts I have already which may mean using a 76mm crank but 85.5 pistons. It will be essentially otherwise stock, I quess I might as well have the case welded but it has had a line bore, will it need another after welding? |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80679 Location: Sneaking up behind you
Posted: Fri Aug 10, 2007 1:20 pm Post subject: |
It's never been proven that it's a "must have". If the person welding it overheats the case they can cause more damage than it prevents.
My 2180 is not welded by #3.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
LittleThunder Samba Member
Posted: Fri Aug 10, 2007 1:22 pm Post subject: |
| Okay, I give up. Weld what and why? |
57 Rag Samba Member
Joined: October 24, 2006 Posts: 1145 Location: Paradise
Posted: Fri Aug 10, 2007 1:27 pm Post subject: |
| LittleThunder wrote: |
Back in the day.... and even now some people weld behind #3 because it it prone to cracking, especially in big bore aps. So they fill in the dip there making it thicker. Like Glenn says... it hasn't been proven, but on the other hand none the the guys who did it never had there case crack there. Well that I know of, I'm sure there have been.  _________________ 57 Ragtop
84x94 86C
IDAs
Glenn  Mr. 010
The #3 cylinder is closes to the "front" of the engine is over time the case can crack. The #3 area is that section just to the right of the crankshaft. Some people weld a plate there to strengthen the area. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Aug 10, 2007 1:33 pm Post subject: |
Sweet, thanks for the quick replies, I figured it was more for the big bore and stroke engines. The other case I have cut for 94's is welded. I'll use that for my "big"motor. Cheers  |
Glenn  Mr. 010
Posted: Fri Aug 10, 2007 1:34 pm Post subject: |
Mine is 92x82. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Aug 10, 2007 1:40 pm Post subject: |
| Exactly and you've obviously had no problems so thats reassuring. I wonder if some of the problem has been alleviated with newer lighter engine components and more attention to balancing or was it only ever a heat issue? |
Bugzlife Samba Member
Posted: Fri Aug 10, 2007 3:17 pm Post subject: |
Yea, no need if crank and rods pistons etc are strong, and balanced, _________________ I'm looking for some rear wheels for my rail( 4lug), 8" wide up to 12" with or without tires, |
sszuch Samba Member
Posted: Fri Aug 10, 2007 3:53 pm Post subject: |
| It is a heat and fatigue issue. The constant heating and cooling of the case will eventually change the microstructure of the material, causing it to become brittle. The area behind #3 is the thinner than the other side of case and which increases the stress. Balancing is always a benefit becasue it reduces vibration and bending of the crank, but rod and piston strength is not a factor when looking at case longevity. |
RonR Samba Member
Joined: October 03, 2004 Posts: 169 Location: Hesperia,CA
Posted: Fri Aug 10, 2007 8:40 pm Post subject: Third degree on # 3 |
| We put a 1/8" radius at the base of our large bore motors. I have seen cracks, but only with sharp corner bores. |
1432 Samba Member
Posted: Fri Aug 10, 2007 9:36 pm Post subject: |
| Cracks in this area are a result of extreme loads in the combustion process. Virtually all will propagate from nearest the end of the head studs. To correct this the factory introduced the "#3 deep stud" back in the 70's to alter the studs' load path from square across the base of the bore to diagonal thru a larger area of mass, they also switched to the 8mm head studs for added protection from cracking, in most cases this is enough to prevent failure at this point, however if your engine is set up for serious abuse like drag racing, sand buggin, turbos or spl fuels welding it can be of substantial value when done correctly which means the welding of rolled mag plate material, stress relieving and line boring. Before the days of the aluminum cases it was quite common to see mag cases welded at the #1 & 4 cyls as well. |
CJG Samba Member
Joined: November 07, 2005 Posts: 571 Location: Phoenix
Posted: Sat Aug 11, 2007 1:17 am Post subject: |
The cast is better now a days. A good engine builder will make sure of the tolerance's.  |
fitnessforyoutoo Samba Member
Posted: Fri Aug 17, 2007 11:38 pm Post subject: Re: Welding behind number 3? |
| tree hugger wrote: |
Hi All
This is what I do, grind the hole to rough it up then mix up enough J B Weld to fill it up flush with the top. I have been doing this for years with high HP turbo motors and never had a crack.
I do both sides of the case behind #3 and #1 flush with the top of the case. This can also be done after you have a crack to repair it permanently. _________________ 1956 2000cc 30 psi + boost, methanol EFI NOS chop top turbo sedan under construction
Last edited by fitnessforyoutoo on Sat Aug 18, 2007 9:07 am; edited 1 time in total |
57 Rag Samba Member
Posted: Sat Aug 18, 2007 1:12 am Post subject: |
I knew JB weld was great but dang. My motor is sitting ready to go in. Maybe I'll do it just for the hell of it. Do you do it by layers like coats or one big one? How long does it take to cure?
thanks _________________ 57 Ragtop
84x94 86C
IDAs |
CJG Samba Member
Posted: Sat Aug 18, 2007 1:38 am Post subject: |
no need to weld, unless you are in the 250 hp range  |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sat Aug 18, 2007 3:33 am Post subject: |
Also keep in mind Glenn's engine is still new an shiny with few miles on it. The problem is more prevelent in cases bored for 94's. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sat Aug 18, 2007 5:05 am Post subject: |
Doesn't Glenn's engine use thick 92's? Same size hole in the case as 94's... _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
| satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Posted: Sat Aug 18, 2007 5:11 am Post subject: |
| miniman82 wrote: |
| Doesn't Glenn's engine use thick 92's? Same size hole in the case as 94's... |
I guess you are right, He did use thick walled 92's. But his engine is nice and shiny  _________________ Jerry...
RIP Morgan
My photos
1432 Samba Member
Posted: Sat Aug 18, 2007 7:20 am Post subject: |
| Again the major cause of cracking in this area is excessive cylinder pressures and in street engines the major cause of this excess pressure is detonation, usually thru overheating caused by high compression, poor tuning , overloaded use/driving or a combination of. while extreme detonation kills parts quickly, lower levels of detonation have more of a cumulative damaging effect that can manifest itself in this manor (cracks). Given the fact that the use of higher compression ACVWs appears to be the trend nowadays I predict more ACVW owners will experience cracked cases not only behind #3 but also #1 cyl as well. |
