JonF Samba Member
Joined: December 16, 2005 Posts: 2030 Location: Oklahoma
Posted: Sat Aug 18, 2007 1:07 am Post subject: info needed on Porsche 2 liter wheels |
i need some info on Porsche 2 liter wheels. i found a 914 that has 2 liter wheels that i can get for cheap
how to tell real 2 liters from copies?
what sizes did the wheels come in?
who made them for Porsche? Fuchs? _________________ 68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79490 Location: Sneaking up behind you
Posted: Sat Aug 18, 2007 3:56 am Post subject: Re: info needed on Porsche 2 liter wheels |
<FiSh(( wrote: |
Real with have a Porsche part number 914 361 011 01 on the back
5.5x15J
Fuchs |
Real are forged, repro are cast.
Get the lug bolts also. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
JonF Samba Member
Posted: Sat Aug 18, 2007 3:54 pm Post subject: |
thanks glenn.
should i have any problems with them fitting my bug?
68 beetle long axle with type 3 rear brakes and ghia disc on the front _________________ 68 bug 1600sp 30/31
Glenn  Mr. 010
Posted: Sat Aug 18, 2007 5:14 pm Post subject: |
The correct lug bolts might hit the brake shoe springs on the rear drums. _________________ Glenn
Member #1009
#BlueSquare
bugnut68 Samba Member
Joined: June 10, 2003 Posts: 4180 Location: Eugene, OR
Posted: Sun Aug 19, 2007 10:25 am Post subject: |
Glenn wrote: |
The correct lug bolts might hit the brake shoe springs on the rear drums. |
I learned that one the hard way The solution of course is to have the bolts ground down a smidge.
Another thing to consider is your front end, and the method you've used to lower it (assuming you've lowered it). Since I used CB dropped spindles, I had an issue with the inside of the rim hitting the bottom ball joint. If you have an adjustable front beam, you should be okay, but in my case, I can't run my set on my '70 Bug due to the clearance issue. I had numerous suggestions to grind on the ball joint, but that's not a solution that I'm too fond of utilizing. |
JonF Samba Member
Posted: Sun Aug 19, 2007 3:39 pm Post subject: |
whelps i went and looked at them today. they are real fuchs. i ended up not getting them. he only had 2 of them and both was beat up beyond fixing. the car was parked 20 years ago and shared the field with goats at sometime in its life. the goats had the porsche dinner. _________________ 68 bug 1600sp 30/31
Posted: Mon Aug 20, 2007 12:40 pm Post subject: |
<FiSh(( wrote: |
whelps i went and looked at them today. they are real fuchs. i ended up not getting them. he only had 2 of them and both was beat up beyond fixing. the car was parked 20 years ago and shared the field with goats at sometime in its life. the goats had the porsche dinner. |
I've got a set I'm likely to be looking to sell pretty soon (rims and lug bolts) Feel free to drop me an email and I'll keep you posted. |
John M. Samba Member
Joined: July 22, 2005 Posts: 3833 Location: Boulder, CO
Posted: Wed Aug 22, 2007 7:38 pm Post subject: |
I have real 2 Liter Fuchs on my 74 Beetle. It's lowered 3 1/2" in front and does not rub at all with 195/65's. The rear is stock-ish height with 205/65's. I have the correct lug bolts and they do not interfere with the rear brake components. _________________
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
Mike951 Samba Member
Joined: November 12, 2006 Posts: 115 Location: New Jersey
Posted: Wed Sep 15, 2010 7:18 am Post subject: 914 2L fuchs |
How much are a set of these wheels worth?
Can someone post pic of one of these?
Thanks |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18043 Location: Eugene, OR
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
oly29 Samba Member
Joined: August 21, 2002 Posts: 55 Location: Sparks Nevada
Posted: Thu Sep 16, 2010 6:25 pm Post subject: |
Bugnut68, I had the same problem using CB dropped spindles and running polished Pedrinni's on my car. Someone said to have the taper opened up on the lower part of the dropped spindle so the lower ball joint extends futher into the lower spindle. I had to use a larger washer under the nut but now I have over 0.125 clearance between the bottom of the ball joint and the inside of the wheel. Someone also said to get a tapered reamer and run that thru the lower spindle opening but trying to find a tapered reamer that size is not fun or cheep. |
