kevin derby Samba Member
Posted: Tue Aug 21, 2007 8:18 pm Post subject: removing bushing and needle bearings in lower front beam |
i need to remove my needle bearings(outer)and my inner ?bearings or bushing not sure what is in there yet,what would be the best way to drive these bushing or bearing races out of the tube,also what is the best method of extraction IE tool to drive these from tube or would you pull them?? any help would be greatly appreciated, i am just learning about my vw and have never seen this done ,thanks to all who may offer their help..
kevin |
tim61 Samba Member
Posted: Tue Aug 21, 2007 9:39 pm Post subject: |
| First I spent 20 min. at the local car wash getting all of grease out of the inside of the beam. I used a cheap propane torch to heat the bearings. Then I used a hook from a hook and pick set to pull them out. It was a solid hook and I clamped vise grips on the hook, so I could get a good grip and pull hard. I also heated the micarta inners and then pulled them right out also. Hope this helps just how I did it. I know that you have a welder and are pretty handy with it you can run a bead on the race of the bearing you will be able to just tip over the beam and it will fall right out. |
Street Bug 29 Samba Member
Posted: Tue Aug 21, 2007 11:00 pm Post subject: |
| i had good quick results with a sawsall,stuck it in the beam,cut the needle bearing,then pryed it out, installed the red bushings,if you are carefull with the cut it works good |
Cliff@BrownBags Samba Member
Joined: June 14, 2007 Posts: 649 Location: glen burnie maryland
Posted: Wed Aug 22, 2007 12:04 pm Post subject: |
| i can make it easy for you. i used a piece of tub or box tubing about 3-4 feet long. slide it in from the other side and tap it out. took 5 minutes. i was like you, wasnt sure what to do until this lol |
