Engine and transmission mounts
KevinBug
KevinBug is offline
PostPosted: Tue Aug 28, 2007 5:36 am    Post subject: Engine and transmission mounts Reply with quote
Does anyone know where I can find #18, #8, #16 on this schematic? I got it from Ratwell. I know it sounds stupid but what is it called? motor mount? transmission mount? While I have the engine out I want to change all the mounting rubber but can't find this stuff at the online retailers.
'74 Super
germansupplyscott
germansupplyscott is offline
PostPosted: Tue Aug 28, 2007 5:39 am    Post subject: Reply with quote
none of those are available new any more.
we have #18 good used.
i have never seen a #16. not sure what year/model that was supposed to some on.
SL
KevinBug
KevinBug is offline
PostPosted: Tue Aug 28, 2007 5:47 am    Post subject: Reply with quote
WOW! Scott that was fast. I just sent you an email to your shop! My mounts are no torn or anything I thought since everything was out... I guess if they're NLA I'll use what I've got.
thanks
'74 Super
miweis
miweis is offline
PostPosted: Sat Aug 16, 2008 10:54 am    Post subject: Reply with quote
sorry to take it off topic, but do you know what size bolt goes into #18?
Karl
Karl is offline
PostPosted: Sat Aug 16, 2008 1:02 pm    Post subject: Reply with quote
#23 is part number N 0100583 and is M10 x 15mm long
pwilson
pwilson is offline
PostPosted: Tue Jan 06, 2009 5:40 pm    Post subject: Reply with quote
I am not sure which number it is on the schematic but, what size is the engine to transmission bolt on the top, opposite of the alternator? The other day I noticed I am missing it. Shocked
Phil
61Ragster
61Ragster is offline
PostPosted: Tue Jan 06, 2009 7:12 pm    Post subject: Reply with quote
Phil: Not sure what you mean by "opposite the alternator" but if you mean the passenger side upper engine mounting bolt (that would be immediately in FRONT of the alternator), then you want this:
http://www.thesamba.com/vw/classifieds/detail.php?id=509127
and you may want it kinda quick since it also holds the starter in place. I believe the size is M10 x 122mm.
If you need the driver's side bolt it is also M10 but shorter: ~70mm +/-.
[url=http://www.vw-mplate.com/mplate2-12938.png]Click to view image[/URL]
vw76westy
vw76westy is offline
PostPosted: Wed Jan 07, 2009 12:39 am    Post subject: Reply with quote
one mans junk is another mans treasure
i sold a pair of the #16
thinking why would anyone want to buy used bushing
now i realize i made someones day !!!
pwilson
pwilson is offline
PostPosted: Wed Jan 07, 2009 5:45 pm    Post subject: Reply with quote
Ragster, I mean the driver side. By 'alternator' I meant starter. Embarassed Guess I should have just said driver side in the first place. Thanks for the help.
Phil
vw76westy
PostPosted: Thu Jan 22, 2009 1:06 am    Post subject: Reply with quote
well i got some pics for you guys
i did list in classifieds & i will lower asking price for you guys
with a pm from someone here
77VWBusDude
77VWBusDude is offline
PostPosted: Thu Mar 05, 2009 6:30 pm    Post subject: Reply with quote
So #10 and #9 are for an automatic, right? And that part you have there vw76westy is for the manual? I have what looks like #9 on my auto, but I'm missing #10(and #3). My mechanic described that U shaped thing when I asked him what part I was missing, but I think he didn't know what he was talking about. Argh. I wonder if #10 is the same on a Vanagon, that would help my search out a lot.
'77 Bus auto EFI(stock)
WendyArmbuster wrote:
Oh man, I had forgotten the smell of a running bus. Sort of like a combination of old things and burning dust. Smells like... victory.
XXX/Rx/RnR
XXX/Rx/RnR is offline
PostPosted: Fri Mar 06, 2009 12:41 am    Post subject: Reply with quote
I got #18 new (transmission carrier bushing) from West Coast Meric. 78 auto. Old pair were split and hard as rock. The heat and dry air in Phoenix great for metal, but the dry rot or the rubber getting hard big problem. My m/c's get the garage,and the bus gets the sun. O'well!
magnus0328
magnus0328 is offline
PostPosted: Mon Jul 02, 2012 10:13 am    Post subject: Reply with quote
I know this is an old thread, buy has anyone been able to find these rubbers new?
I have checked all major vendors with no luck
Matthew 6:19-21
jjrose110
jjrose110 is offline
PostPosted: Tue Jul 03, 2012 11:24 am    Post subject: Reply with quote
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211599431
WW makes a reproduction of # 18 in the drawing. I have not seen the others being made.
magnus0328
PostPosted: Tue Jul 03, 2012 11:32 am    Post subject: Reply with quote
Same here. My # 18's are good. Its just that the ones in the pics are not.
Does # 16 act as a bumper for up and down transmission movement or does it serve as a bumper for when the transmission shifts front to back?
Matthew 6:19-21
jjrose110
PostPosted: Tue Jul 03, 2012 11:46 am    Post subject: Reply with quote
Up and down height is set with the slotted holes in # 12. So # 16 would stop any significant movement forward and back. My experience is that once everything is tightened back up, there isn't lot of movement though.
See if anyone else chimes in.
magnus0328
PostPosted: Tue Jul 03, 2012 12:12 pm    Post subject: Reply with quote
Im trying to find some material to make # 16. I was going to use a rubber roller for a boat trailer. Unless anyone else had made one with different material??
Matthew 6:19-21
thewalrus
Big Jack
thewalrus is offline
PostPosted: Fri Jul 06, 2012 12:02 pm    Post subject: Reply with quote
Figured I'd just add to this rather the make a new topic. I don't have a transmission mount at all and don't know which mount I need in the schematic:
http://bustedbus.com/groot/w/OtherAssets2/t204600.gif
(I'm guessing #15, #16, #25 & #24?)
'75 bus, 6 rib manual trans. Here are some pictures of what I have (Yes I replaced the coupler bushing already. That's how I noticed the missing mount)
'73 Transporter 1.7L Dual Carb
notchboy wrote:
You ran over some #Vanlife'ers hopes and dreams?
60vwnewengland wrote:
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards!
Manfreds78bay
Manfreds78bay is offline
PostPosted: Fri Jul 06, 2012 12:38 pm    Post subject: Reply with quote
Here you go. Item "I" half way down the page.
http://www.bughaus.com/type263.htm
1985 VANAGON GL Digijet
There is no spoon.
my59
my59 is offline
PostPosted: Mon Aug 11, 2014 7:24 am    Post subject: Reply with quote
Dredged up because of the schematic on first post-
Item 24- bolt - anyone know size and length? I am missing one.
Also FYI with a missing bolt and the other one loose it affects shifting such that you will start grinding about every gear... and you may start thinking the tranny or shifter is fubar'd
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
