kings31 Samba Member
Posted: Sat Feb 28, 2004 8:35 pm Post subject: ANY ideas on keeping my gas tank off my front end |
I would like to know if you have ideas on how to brace the front end on my buggy to keep my gas tank off my front end. i put a hole in it from it hitting my front end .
chris |
62ragman Samba Member
Joined: November 01, 2003 Posts: 100 Location: San Dimas,CA
Posted: Sun Feb 29, 2004 12:29 am Post subject: |
What type of car do you have, is it a sand rail or baja bug? Maybe you have some pictures, for a better understanding of what it is you are looking for. Thanks, Randy |
volksaddict Samba Member
Posted: Sun Feb 29, 2004 7:13 am Post subject: |
Bet it was fun when the gas sprayed up in your face Guess you weren't smoking when it happened since you are still here to write about it! |
Posted: Sun Feb 29, 2004 8:11 am Post subject: |
sorry i forgot to say it is a manx style buggy. i'm looking for some kind of support in the front . under the fiber glass body to lift the tank up.
thank you  |
blueone Samba Member
Joined: August 22, 2008 Posts: 52 Location: Glendale, Az
Posted: Thu Jun 11, 2009 10:15 am Post subject: |
Any ideas? I have the same problem. |
jspbtown Samba Member
Posted: Thu Jun 11, 2009 10:24 am Post subject: |
The original manxs had simple brackets that were bolted to the two body attachment points which are on top of the front beam. They attached to the front of the buggy near the tank.
You can see the two holes here:
You can just see them in this pic. They are silver and just beyond the lower u-joint. Sorry I don't have a better picture.
Dinubadave Samba Member
Joined: February 18, 2009 Posts: 490 Location: Dinuba, CA
Posted: Thu Jun 11, 2009 11:00 am Post subject: |
I installed a home made support, you can see it below:
donmac Samba Member
Joined: April 23, 2007 Posts: 367 Location: Pearland, TX
Posted: Thu Jun 11, 2009 11:05 am Post subject: |
kings31 wrote: |
sorry i forgot to say it is a manx style buggy. i'm looking for some kind of support in the front . under the fiber glass body to lift the tank up. |
I bent a "Z" shaped bracket out of flat bar. Bolted it to the two existing holes on top of the front beam and the underside of the body.
_________________ Don
67 Dune Buggy aka Shrek
74 Baja Junk Pile aka Wild Thing |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6768 Location: Northern California
Posted: Thu Jun 11, 2009 12:50 pm Post subject: |
There are rubber squares that sandwich the bottom of the Z bracket which allow some movement between the suspension and the body, which are good to use.
The bolt that goes through the top of the Z bracket and the body, should also go through the tab that holds down the front of the tank. |
Posted: Thu Jun 11, 2009 11:18 pm Post subject: |
Very nice. Thanx for the quick responses I will try and fab something up this weekend. |
Baja68 Samba Member
Joined: June 08, 2007 Posts: 576 Location: Houston Texas
Posted: Fri Jun 12, 2009 5:32 am Post subject: |
blueone wrote: |
Just a thought when I bought my gas tank they had 2 sizes. I cant remember the exact gallons but I got the smaller one in fear of having the problem you are having with the larger one.
I think it was 13 galon what I got and 18 gallon for the bigger one some thing like that .
Goood luck |
Posted: Fri Jun 12, 2009 8:38 am Post subject: |
Original 58-67 tanks have the best chance of fitting under the hood. |
c.davis419 Samba Member
Posted: Fri Jun 12, 2009 3:15 pm Post subject: |
61 to 67 tanks actually. 61 tanks don't have the hole in the top of the tank for the fuel sending unit, but are identical in every other way. 56-60 tanks are called the humpback tanks and won't fit at all. _________________ 1967 beetle
1974 Thing |
