nick9 Samba Member
Posted: Tue Aug 28, 2007 8:33 pm Post subject: Type 4 Oil Breather Pressure Regulating Valve 022 115 303 A |
The breather box on top of the engine, has a fitting attached that has hose coming out of the side and a round, flat top. Is this supposed to act like a PCV valve? Or is it supposed to just filter out oil for crankcase ventilation? Does anyone have any information on these? I don't find much about these in Bentley.
Maybe someone has cut one open, seen inside, and has pictures? |
satchmo Samba Member
Joined: November 23, 2003 Posts: 285 Location: Crosby, MN
Posted: Thu Aug 30, 2007 1:58 pm Post subject: Re: Type 4 Breather Box Valve question |
nick9 wrote: |
There isn't any valve in there. The box just acts as a separator for the little bits of oil carried in the crank case vapors as they circulate back to the air intake and air filter.
Tim |
Joined: June 12, 2003 Posts: 747 Location: Colorado Springs, Co.
Posted: Thu Aug 30, 2007 6:23 pm Post subject: |
If you are so inclined to clean it out, you may be suprised how much crap you get out of there.
Best regards,
John _________________ luck is the result of good preperation |
nick9 Samba Member
Posted: Thu Jan 22, 2009 11:36 am Post subject: |
When I looked at manuals written in German language, it calls this part a "Druckregelventil" which translates in to "Pressure Control Valve". I guess this answers my old question. The MANN filter website says,"...pressure regulating valves ensure optimum pressure inside the crankcase. This prevents the escape of blow-by gases, and thus loss of oil at bearings and sealing points."
Sounds like an important part. (At idle, the valve would be closed and there would be no unmetered air being sucked in from crankcase fumes and leaks in the case?) Not a PCV valve but pressure regulating. I recently found out that there is discussion of these on the Vanagon/Eurovan forum. They have taken these, and the ones from their cars, apart, and there is a spring and diaphragm that is usually ruptured. They found that when this valve is broken, you get a rough, lean idle.
picture borrowed from that post
It is unfortunate that this part is NLA |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23298 Location: Oklahoma City
Posted: Thu Jan 22, 2009 12:43 pm Post subject: |
It is indeed a PCV valve and it does indeed regulate the pressure in the crankcase.
It is a crankcase vent. How it works...is its simplt a dipahram style PCV.
rebuild it without th eflexible diaphram and spring. many of us have found on type 4 engines in 411/412 and 914...that getting rid of any pulsing or intermittant style of PCV and going to a smaller but constant flow orifice....allows cleaner crankcase, constant metering of gasses..and less fluctuations in idle. It can work by allowing a constant measured amount of air by passing through it from the crankcase to the manifold. In this way it is not wide open to the manifold..causing an idle or open throttle situation. It gives plenty of air bypass to to keep crankcase gasses vented, has positive vacuum on those gasses via the intake manifold connection.....and above all...acts as an oil vapor seperator.
Simply put it back together with a solid metal or plastic plate in place of that spring loaded diaphram...with a 2-4mm hole drilled in it (you will need to find what size hole works for your engine...mine works with a 3mm hole).....and readjust idle and possibly idle mixture. Ray |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Thu Jan 22, 2009 8:02 pm Post subject: |
So here is what i find, number wise.
= 3/16
.1574 = 4mm
.156 = 5/32 = 3.96mm
.118 = 3mm
.122 = 1/8 = 3.09mm
.0787 = 2mm
.0781 = 5/64 = 1.98mm
= 1/16
Doesn't take much. Makes me want to see if mines defective. Another one of those tuning issues, chasing gremlins. Who would think to check for a broken diaphragm _________________ Peace, ~R |
nick9 Samba Member
Posted: Thu Jan 22, 2009 8:21 pm Post subject: |
Ray - Thank you for the information. Now that I know what to look for, I can see at least 2 tears in the diaphragm while shining a light inside. I am going to try to modify a spare.
Also, is this hole in the top normal, or did someone drill it? Isn't this what would be considered a vacuum leak. You can draw air through this tiny hole, from the 20mm outlet in the side even if you plug the bottom intake. It goes through the breather hose, right into the intake boot, past the AFM.
...and...
How about this hole in the bottom part? This is not a vacuum leak, but is just a direct path for crankcase air into the breather hose. Maybe I can just fill in the area to the side and leave this hole as the 3mm hole suggested?
It's one of those things that would be easy if they just still made the part. I've been looking at this for 15 years thinking that it must be replaceable. Every VW repair shop or dealer says it isn't a valve. I finally decided to really look into it, and it turns out it is a valve. One that must have been purposeful enough to include in the original design, but whatever... these cars are "obsolete". Time to improvise, adapt, overcome... _________________ Improvise, adapt, overcome. |
obieoberstar Samba Member
Posted: Thu Jan 22, 2009 9:06 pm Post subject: |
didn't the early type 4 buses have a breather cover that simply had a small pipe coming off of it as opposed the the plastic valve assembly?
definitely more reliable than the NLA valve in the long run. |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3069 Location: Portland, Oregon
Posted: Thu Jan 22, 2009 9:23 pm Post subject: |
raygreenwood wrote: |
I swear Ray needs to get together with an editor and write a book. It'd be a best-seller in the air-cooled world!
Hey Ray, what about putting a plate in there and tapping a hole in it to hold a carb jet? Then one could simply swap jets to tune the bypass instead of drilling, test, drilling, test, drilling...oops!, dang, need to go smaller  _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Posted: Thu Jan 22, 2009 11:32 pm Post subject: |
There was a pretty good discussion of what these things do on the Vanagon forum a while back. They seem to do nothing but cause a small pressure buildup in the crankcase. They don't seem to function as a backfire preventer which is what I had thought they might be. I replaced the failed one on my beater 83 1/2 Vanagon and could tell no difference what so ever in how the engine idled or ran, or in the oil usage.
There were actually several types of breathers used on T4 engines. The D-jet motors had an actual PCV valve and vented rocker boxes, while the carburated engines just had a open box which maybe functioned as a baffle (this sounds like what nick9 asked about). The L-jet engines had the back pressure valve at issue here.
There were also a couple of European variant I have just seen pictures of.
If you have the common L-jet style valve and it is actually working 100%, I am not sure you should try Ray's idea. You might get a strong vacuum drawn in the crankcase under idle and decel, which could suck in a valve cover gasket. If the diaphragm were blown out, as I suspect most are, then it wouldn't be an issue.
Also if the diaphragm has failed then it would make since to close off the hole in the top of the valve with silicone, as this would cause the entrance of unmetered air into the intake air system.
Lively discussion to follow? |
Evil Clown Live
Joined: January 08, 2009 Posts: 1443 Location: Wacky Macs
Posted: Fri Jan 23, 2009 12:04 am Post subject: |
My 76 has been carb converted and have the same issue. A mechanic said to run a hose to the side of motor
I'm wanting back FI, but for now am thinking of this.
_________________ Quote from a Styx '83 song Mr (AI) Robocop
I'm schizophrenic, and so am I
Quote: |
kiss my airy VW ass |
Quote: |
Smoke the Rice Paper? |
Zeen wrote: "why would a bleedin' tree go to the post office?"
Because G.Washington used an axe on it 😂 |
Posted: Fri Jan 23, 2009 12:12 am Post subject: |
Evil Clown wrote: |
Just run a hose from the breather into your air cleaner housing. Some progressive air cleaners had a fitting or a hole for this and on some you need to add it. Easy enough to do. |
Evil Clown Live
Posted: Fri Jan 23, 2009 12:17 am Post subject: |
Wildthings wrote: |
Evil Clown wrote: |
Yes because it is ran originally into the FI intake so it has a purpose for the intake I would think.
Now just adding the L shaped valve to my air breather.
I saw one with duel carbs, it looked like a 73 1700. It had one hose to each carb. _________________ Quote from a Styx '83 song Mr (AI) Robocop
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42814 Location: at the beach
Posted: Fri Jan 23, 2009 12:58 am Post subject: |
I am wondering if anyone has actually talked to VW on this? One sees replacement PCV valves all the time for cars from the 70's. If truly there is no superceeded number, (there is also that 39 000 60 917 number on it), then a replacement might be made. I have only one so I cannot take it apart to see how it works. But if it acts as a PCV valve, closing to a small metered orifice at idle and opening at throttle or back pressure, one might be able to make a simple baseplate with a hole in it capable of fitting a grommet and a PCV valve from a similar size motor, perhaps a Honda 2 liter or something like that which is readially available. Another question for someone who knows these, is the diaphram from the later VW's the same size and shape? If so could one buy a newer unit, cannabilise it then rebuild the old style valve with it, perhaps with some sort of device that held the top on and could be removed to replace the diaphram every few years? I cannot believe that VW failed to make ample replacements of these if they are PCV valves. Smog laws in that era required parts for 50,000 to 100,000 miles be available. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Evil Clown Live
Posted: Fri Jan 23, 2009 8:10 am Post subject: |
JBUGS has this one.
http://www.jbugs.com/store/merchant.mvc?Screen=PROD&Product_Code=8544&Category_Code=159
Maybe this should be sufficient. _________________ Quote from a Styx '83 song Mr (AI) Robocop
SGKent  Samba Member
Posted: Fri Jan 23, 2009 9:33 am Post subject: |
To anyone who has had one apart. (1) Does the spring sit above the diaphram? (2) does the center of the diaphram seal the top of where the tube enters the body?
If so then the small hole on the bottom allows the metering of blowby in the closed position. If pressure builts it would push the diaphram up and open the larger hole to allow a greater flow. The tiny hole on the top would be to allow the backside of the diaphram to vent to ambient pressure. _________________ George Carlin:
Posted: Fri Jan 23, 2009 10:35 am Post subject: |
SGKent wrote: |
If so then the small hole on the bottom allows the metering of blowby in the closed position. If pressure builts it would push the diaphram up and open the larger hole to allow a greater flow. The tiny hole on the top would be to allow the backside of the diaphram to vent to ambient pressure. |
I think your explanation is pretty close to correct. I would add that the "small hole on the bottom" probably is there as much to drain moisture out of the elbow as for metering. |
SGKent  Samba Member
Posted: Fri Jan 23, 2009 11:07 am Post subject: |
If these leak they could be a cause of poor performance and a ean burn. While the mixture could be adjusted to accmodate, the system would work better with these functioning. I also see the potential for the main body of the valve to remain closed thus causing the engine to build up pressure and push out oil. Even if the diaphram is not ruptured, it might be hardened with age and not move to allow blowby. If I can't find a way to test them or one that is NOS, I will certainly look to see if a plate can be built that would allow a standard PCV valve to be used in lieu of this valve. Of all the misc NLA items that I've encounter restoring my 1977, this is one that troubles me. Lean burn or excessive crankcase pressure can cause serious side-effects. I am somewhat surprised that it has taken so many years for the community to notice this issue. _________________ George Carlin:
busman78 Samba Member
Joined: August 17, 2004 Posts: 4660 Location: Oklahoma City, OK
Posted: Fri Jan 23, 2009 11:25 am Post subject: |
SGKent, yes ignored in the bus community, but not in the Type 4 community. Over on ShopTalk Forums the PCV discussion has been going on for quite awhile. Excellent posts, lots of informatiion. If you think the info Ray posted here is good, you will find the some of his postings on STF outstanding. |
