Engine Identification
Page: 1, 2, 3  Next
Euro 67
Samba's 67 part whord
Euro 67 is offline
PostPosted: Wed Aug 29, 2007 10:48 pm    Post subject: Engine Identification Reply with quote
This will help in Engine Identification for those who wonder.
68 Bug totaled one day will live again
69 Bug donor car
Many parts had, always need em!
millerje78 wrote:
I'm no expert but I'm guessing the spike during cold running has everything to do with the roofing tar(20-50) in the crankcase.
bill may wrote:
...i could be wrong as i have only been driving air cooled beetles since august 1965.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Aug 30, 2007 8:33 pm    Post subject: Reply with quote
http://www.type2.com/bartnik/enginecodes.htm
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Euro 67
Euro 67 is offline
PostPosted: Thu Aug 30, 2007 8:44 pm    Post subject: Reply with quote
Dang, I like that chart
69 Bug donor car
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Aug 31, 2007 12:35 am    Post subject: Reply with quote
For completists, how about this one?
http://home.planet.nl/~koni1691/ecodes.html
janerick3
janerick3 is offline
PostPosted: Sat Sep 01, 2007 4:01 am    Post subject: Re: Engine Identification Reply with quote
This chart has several errors in the engine prefixes; there are better references out there.
Thanks,
Jan K.
Aussiebug
Aussiebug is offline
PostPosted: Fri Apr 25, 2008 7:40 pm    Post subject: Reply with quote
For bugs, you might find my list more useful. It matches chassis numbers to the engine numbers for all models between 46 and 86 when they stopped making them in Germany (anyone got a list of chassis and engine numbers for Sth American manufactured bugs?)
http://www.vw-resource.com/years.html
regards
Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
QIKLUV
QIKLUV is offline
PostPosted: Sat Jun 07, 2008 1:09 pm    Post subject: Reply with quote
hello new here....
just pried my great grandmothers beetle out of my dads hands.
it has been in the garage for 23yrs. 37000 original miles.
it is 100% original.
having problems matching up the #'s chassis #1773805 says its a '57
motor # 2156366 says '58
what is the big #s stamp under the data plate? 150806
thnx for any of your help.
plans are for a TOTAL RESTO and give it back to dad for fathers day next yr
The Android
PostPosted: Sun Jun 08, 2008 12:07 am    Post subject: Reply with quote
The engine and chassis numbers are both model year 1958. Looks like the chassis was from the very end of Decmber 1957, and the engine was made at the very start of Jan 1958. That body number, I'm not very knowledgable of how those worked as far as how long they sat around after being stamped before the were mated to a pan - on the VIN chart it looks like the body was stamped closer to the start of December 1957. There's also a number stamped into the right bump stop support on the front axle beam, as well as on the transaxle you can look those numbers up too:
http://www.thesamba.com/vw/archives/info/bugchassisdating.php
With only 37K on it, you better restore it original! Get some pictures posted up here so you can show us your progress. Good luck, and welcome theSamba!
-Andy
QIKLUV
QIKLUV is offline
PostPosted: Sun Jun 08, 2008 7:05 pm    Post subject: Reply with quote
it WILL be done original.
thnx for the help.
will post pics. just want to make sure i post them in the right section...
each forum have there own rules..ya know..
green61bug
green61bug is offline
PostPosted: Sun Jun 15, 2008 7:33 pm    Post subject: Reply with quote
I have a quick question... Where can I find out if the engine case in the car is correct with the body and pan number... I have an original paint 1963 Beryl green beetle. The case number is 7443322...the body number is 5272855. I know that the motor is from a 63 but I am new to this whole deciphering numbers and stuff because I used to never care. This beetle I am actually kind of interested in. Thanks
1963 OG Beryl Green Beetle Bug
1960 Bus
djkeev
djkeev is offline
PostPosted: Sun Jun 15, 2008 8:24 pm    Post subject: Reply with quote
Hi
Go here, keep in mind the numbers for the month are the LAST ID numbers for the month, not the first.
Dave
Ghia
Vanagon
Beetle
The Android
PostPosted: Mon Aug 17, 2009 2:12 pm    Post subject: Reply with quote
Since I see this has been pegged in the "Sticky" FAQ index, I'll put in the Engine Data Chart I drew up, plus the Worldwide Engines Chart that I compiled from many different sources. Originally it was an appendix in the back of "The VW Beetle, A Collector's Guide" by Jonathan Wood, a British book. I took that chart, re-arranged it and added quite a bit more data to it. The large chart may be re-sized on your screen and will look better if you click-to-enlarge it.
lynellski
lynellski is offline
PostPosted: Tue Aug 18, 2009 8:57 pm    Post subject: still need a lil help... Reply with quote
im tryng to find the info on this block im trying to build up!!!! if i got it right its a 1700??? uummm 1776? do the other numbers mean anything? please any info would be great! here's the block number:
#CB06 2471 THANKS GUYS
Karmann_65
Karmann_65 is offline
PostPosted: Tue Aug 18, 2009 9:02 pm    Post subject: Reply with quote
Type 2 camper engine
CB 1972/73 1700cc - dual carb., manual transmission
View user's profile Send private message Send e-mail MSN Messenger Twitter Gallery Classifieds Feedback
lynellski
PostPosted: Tue Aug 18, 2009 9:14 pm    Post subject: Reply with quote
i got that on one of the charts just thought there would be a little more detail... i just never really heard of a 1700... ive always heard 1776..
Karmann_65
PostPosted: Tue Aug 18, 2009 9:18 pm    Post subject: Reply with quote
1700cc is a stock VW engine size.
1776cc is a modified 1600 most likely
lynellski
PostPosted: Tue Aug 18, 2009 9:23 pm    Post subject: Reply with quote
interesting! i have a 1650 now and found a 1700cc block with pistons, would it be better to just pump up my 1650?
The Android
PostPosted: Tue Aug 18, 2009 9:25 pm    Post subject: Reply with quote
The charts shown and this thread is centered around type 1 engines. The CB engine is a type 4-Bus, and never was in a Beetle.
You'll find the 1679cc CB engine listed on the Type 2 VIN page under 1971,1972, 1973.
http://www.thesamba.com/vw/archives/info/chassisdating.php
lynellski
PostPosted: Tue Aug 18, 2009 9:32 pm    Post subject: Reply with quote
thanks that cleared up alot! would it be a good idea or would this fit in a 58 bug, straight bolt on! i just want to kick some ass with a stronger engine and was thinking this would be a good way!
lynellski
PostPosted: Tue Aug 18, 2009 9:36 pm    Post subject: Reply with quote
this was the chart i was looking at? http://www.type2.com/bartnik/enginecodes.htm
it says type 2?
Page: 1, 2, 3  Next
