jsSyncro Samba Member
Joined: August 18, 2007 Posts: 59 Location: mill valley, ca
Posted: Wed Oct 03, 2007 1:53 pm Post subject: Westy grey interior paint color? |
Tried searching for this but no luck.
What color grey are the interior parts of an '87 Westy?
I want to repaint the my table legs, brackets, etc so I'm hoping
someone can recommend a color of Krylon or similar that is a close
match that I can shoot them with.
thanks!
John _________________ ++++++++++++++
87 Syncro Westy Hoth Patrol Unit |
Benito_del_norte Samba Member
Joined: October 02, 2007 Posts: 24 Location: Tremblant
Posted: Wed Oct 03, 2007 3:11 pm Post subject: |
Plastikote
Dove gray 364
Available at Napa etc ...
Benito |
wavanagon Samba Member
Joined: September 17, 2007 Posts: 400 Location: Everett, WA
Posted: Wed Oct 03, 2007 3:19 pm Post subject: |
yessssssssss. thank you benito. i am going to call my local napa to see if they carry it.
edit: well, I just called the local NAPA. they don't carry it here. i'm gonna try some other locations around me. this came up on the vanagon.com mail list and if i remember, there was not a consensus on brand/color of spray paint.
edit2: well, after getting hung up on at 2 other NAPA's, i googled and came up w/ this from a chevelle message board:
Quote: |
270ss
Can anyone tell me who has the correct dove gray wheel paint for the back side of the 70 ss wheel, I have been unable to find anything that looks right, someone said to use shock gray but that looks to dark to me... Thanks Don
1badss396
Krylon's Dove Gray (#1605).
Dove gray valspar #165816
Plasti-kote also has dove gray #364,its also a good match. |
fwiw _________________ 1988 Vanagon GL - For Sale
1987 Westfalia
2008 Audi A4 2.0T
http://wavanagon.googlepages.com
Dirty from working on your Vanagon? Buy soap from my wife!
http://www.teatreesoap.com |
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1159 Location: Northern Nevada
Posted: Fri Nov 08, 2019 6:48 pm Post subject: Re: Westy grey interior paint color? |
I just used a paint color I like on the rear table leg. It's not a close match for the original leg color, but I like it much better. I find the original too dark and sort of an odd hint of green in it.
The paint is: Rust-Oleum Painter's Touch 2X Ultra Cover,
in a color called Stone Gray Satin.
Found at Home Depot:
https://www.homedepot.com/p/Rust-Oleum-Painter-s-T.../307244952
I've been using this 2X Ultra Cover variety of paint almost exclusively for about 10 years now and have been noticing a greatly expanding pallet of colors over the years.
Hope you might like it too.
Jim Davis _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Mon Nov 11, 2019 10:21 am Post subject: Re: Westy grey interior paint color? |
I found a great match at Home Depot where they'll mix you a sample can of it you can brush on for $3.75. Here's the thread I posted on this subject: https://www.thesamba.com/vw/forum/viewtopic.php?t=617369&highlight=hatch+panel _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
jimf909 Samba Member
Posted: Mon Nov 11, 2019 5:13 pm Post subject: Re: Westy grey interior paint color? |
Years ago I wrote down these notes from a Samba thread on paint match. Two weeks ago I had the stove off and wanted to get the job done so I used the Rustoleum Smoke Grey 7786.
Resources
- Gray paint: Rustoleum7786 Smoke Grey . . . got it at Lowe's
- SEM 15183 matches the factory grey trim color almost perfectly.
- SEM 13023 is a low luster clear that will make the grey the same sheen as factory
- SEM 38353 is a cleaner that you use to clean/prep the plastic before painting.
It's a reasonable match and looks waaay better than before but my guess is the the SEM, rustoleum mentioned above and HD paint match would all be closer. I did have HD match the cabinet Formica in a qt of exterior paint and it's a great match!
_________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Posted: Mon Nov 11, 2019 5:16 pm Post subject: Re: Westy grey interior paint color? |
Jim, that looks GREAT! Well chosen. Hey - the two knives in sheaths. Are they held on by a magnet that's strong enough to do that, or are they mechanically fastened somehow? What's the magnet? _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Nov 11, 2019 6:08 pm Post subject: Re: Westy grey interior paint color? |
Thanks, Doug.
The magnetic knife holder is from Amazon (I shortened it by a few inches to fit the van's kitchen. The knife holder looks decent, is easy to clean and has worked well in the van since 2016 and my house even longer)...
The knives stay secure even held through the plastic sheaths. The big one will occasionally be in the right place to vibrate and make an annoying noise that I'm rewiring my brain to believe is a soothing noise. The screws are concealed behind the stainless cap. Cutting a magnet glued to stainless is a bit of a mess. I believe I used a grinder with a cutoff wheel.
Standard gear: two kitchen knives, a leather man multi tool, a cheap Gerber folding knife and a Japanese utility/box knife that I find to be well made, reasonably priced and versatile so I keep them in many places so I can give them away ):
Endurance Deluxe Magnetic Knife Bar https://www.amazon.com/dp/B007SPKRTE/ref=cm_sw_r_cp_api_i_EZFYDb4XFATHA
NT Cutter PRO Auto-Lock Stainless Steel Utility Knife (A-1P) https://www.amazon.com/dp/B005J0XDSW/ref=cm_sw_r_cp_apip_tkQqVd6zbVK5V
I've used these AAA GE LED lights above the kitchen and in a rear cabinet. No motion detector, flashing or colored lights! Just a simple pushbutton switch that toggles between off, high and low in an extruded aluminum case.
GE Portable LED Light Wand, On / Off, 3 AAA Battery Operated, 35 Lumens, Detachable, Hand-Held, Ideal for Under Cabinet, Closet, Hallway, Work Bench, Washroom, Pantry & Laundry Room, 12747 https://www.amazon.com/dp/B01L2H1XJ6/ref=cm_sw_r_cp_api_i_AoGYDb9HEE062 _________________ - Jim
Butcher wrote: |
Guilty as charged.
