Park on an incline, smoke show.
Rocknrod
Rocknrod is offline
PostPosted: Thu Oct 04, 2007 3:27 pm    Post subject: Park on an incline, smoke show. Reply with quote
Hey guys...
My bus (71 with 1600 dp) puts on a decent james bond smoke effect show... Doesn't do it any other time, or doesn't burn much oil... So I figure the rings are in decent shape.
Is this enough to warrant an overhaul, is the cause badly worn out valve stems/valve guides? No seals on these motors to my knowledge... Is a smoke show just part of VW ownership?
(Its been a few months without having to pull the engine, I guess I'm feeling lost without having it out... Laughing )
1971 Westfalia with a high top.
http://71vwbus.blogspot.com/ - Pictures and words... Oh My!
Max Welton
Max Welton is offline
PostPosted: Thu Oct 04, 2007 3:30 pm    Post subject: Reply with quote
What tests have you done so far? Compression test? Leakdown test?
Which direction is the incline? Nose up?
Max
1967 Type-3 Fastback
mat3833
mat3833 is offline
PostPosted: Thu Oct 04, 2007 8:06 pm    Post subject: Reply with quote
mine does it every morning, it smokes for a second or 2 and then its fine. it is from oil leaking past the rings, its normal if you are in an incline with the tail down-slope. at least i hope so...
Matt
grimace007 wrote:
then i found thesamba where we point out the painfully obvious and make eachother feel retarded Wink
kidder = what are the pros and cons to getting more hp or less hp.
runslikeapenguin = Rolling Eyes
don3751 = Don't worry, kidder; he's rolling his eyes because he hasn't got the slightest @#$% idea.
Glenn = Owned!
nextgen
nextgen is offline
PostPosted: Thu Oct 04, 2007 8:18 pm    Post subject: Reply with quote
Mine does it also and then it is fine. On one hand it make your car look like an old bomb, but on the other it lubes the cylinders on start up.
Hey it is part of the air cooled game. Would a Harley be a Harley if it didn't make noise.
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
Rocknrod
Rocknrod is offline
PostPosted: Thu Oct 04, 2007 8:38 pm    Post subject: Reply with quote
Nose up.
Haven't done a compression or leak down on the motor yet... saving up for a decent set.
mat3833
mat3833 is offline
PostPosted: Fri Oct 05, 2007 7:07 am    Post subject: Reply with quote
you should be ok, if it smokes for more than a few seconds you might have a problem tho.
Matt
Glenn = Owned!
