boxrod Samba Member
Joined: February 02, 2005 Posts: 517 Location: Las Vegas
Posted: Mon Oct 22, 2007 1:44 am Post subject: Volksarama "Bonneville Bus" becoming reality. |
Through a strange series of events, it looks like the Bonneville Bus will come to reality. This bus was always one of those what-if projects. Chris Clark, of Clarks Customs, penned this awsome rendition of this way cool dream bus. Now, dream no more. I have become the new owner of the KCW "shop truck" project. Photos of the chassis work can be found here http://kustomcoachwerks.com/gallery/main.php?g2_view=core.ShowItem&g2_itemId=23646 . The torsion housing has been raised and narrowed, front beam narrowed, 5 inch dropped spindles, raised box, wheel tubs, barndoor rear decklid and engine compartment. A great start for this project. I plan on building this as I have time and money, and plan to actually take this to the salt flats and/or the dry lakes to make real top speed passes. I'll start documenting the progress soon and will start a new folder in my gallery to show the progress. I'll keep you up to date. Here's the artwork
[/url]
boxrod Samba Member
Posted: Mon Oct 22, 2007 1:55 am Post subject: Sponsors needed !!! |
In an effort to reduce costs and speed up construction time, I am searching for companies that would like to contribute to this build. In exchange for parts, labor, cash, or trades, your company can be associated with this high profile build. A logo on the bus, link on our website, and recognition in all magazine and web features would be your return. I anticipate this vehicle will catch the attention of all types of magazines and websites. Plus, the bus will be taken to many shows around the West and hopefullly be entered into the 2008 SEMA show. If you are interested, contact me at [email protected] or PM me with your phone #.
Parts needed:
Engine internals: , crank, rods, cam, lifters, heads, pistons/cyls, and all other long block parts
Engine externals: tin, alternator, pulleys, clutch/plate,
Ignition system: Distributor, ignition box, wires, coil
Fuel system: tank, pump, regulator, lines, fitttings
Oil system: cooler, filter, lines, fittings
Turbo system: intake, carb, exhaust, turbo, wastegate
Flush mount windows
Rubber and seals
Electrical system: wiring harness, battery, lights, starter, alternator
Sheetmetal body panels: front nose skin, pass. side rocker panels (in/out)
Safety equipment: harnesses, fire supression, racing suit, helmet,
Paint materials.
Steel tubing
Sheetmetal work
Interior work
Labor needed.
Interior work.
Electrical install
Contact me to donate anything. [email protected]. Thanks.............Derek
boxrod Samba Member
Posted: Mon Oct 22, 2007 2:50 am Post subject: Sponsors for build |
Please support the shops that support this project,
Let them know you saw them on Volksarama.
Go to http://volksarama.com/BonnevilleBuildup1.html to see what we still need if you want to get involved in this project
R/C Trans- (702)221-4363 - http://rctrans.com/ - rebuilt HD transaxle.
The Wagen - (702)699-wagn - sheet metal install
Sand Freak Fabrication - www.sandfreak.net - Safety cage/roll bars
KCW - http://www.kustomcoachwerks.com/ - body and paint labor, front beam, raised box, narrowed torsion housing
Type 2 Parts.com - http://www.type2parts.com/ - sheet metal repair panels
Chirco VW - http://www.chircoestore.com/catalog/index.php - Crow 3x3 safety harnesses, Crow gloves
Old Speed - http://www.oldspeed.com/ - 944 Porsche rear hubs, backing plates, calipers, cables etc.
Econo International Supply E.I.S - http://eisparts.com/Merchant2/merchant.mvc? - new bus nose skin
DPR Machine Shop - http://www.dprmachine.com/ - 84 mm C/W crankshaft.
Speedwerks - http://www.speedwerks.net/ - MSD 6AL box with soft touch rev limiter.
Engle Cams - http://www.englecams.com/index.php - Engle turbo camshaft
MOFOCO - http://www.mofoco.com/ - 050 heads, 42x37, dual springs, opened for 94s, fully ported and polished
Mooneyes - http://www.mooneyesusa.com/Store/index.php - complete set of moon disks with dzus fastner kit.
Big Wig Race Cars - http://www.bigwigracecars.com/ - A set of aluminum front door panels and kick panels
Bugpack - http://www.bugpack.com/ - chromoly H beam race rods, a set of race lifters, and a set of their straight cut cam gears.
Dynamat - http://www.dynamat.com/ - Sound and heat absorbing materials.
Dolphin Gauges - http://www.dolphingauges.com/ - cockpit gauges
EZ Wiring - http://www.ezwiring.com/ - complete wiring kits
Sway A Way - http://www.swayaway.com/ - HD race axles
Vee Dub Parts Unlimited - http://www.vwparts.net/ - 94mm long cylinders, 94mm Weisco pistons
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4852 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Mon Oct 22, 2007 5:55 am Post subject: |
That will look badass. Can't wait to see more. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
sweetlokin66 Samba Member
Joined: November 15, 2006 Posts: 1220 Location: Luftwagenville, FLDuh
Posted: Mon Oct 22, 2007 6:40 am Post subject: |
Nice GEX sticker You should go after that V8 bus when this ones done.  _________________ Follow IG for more content @greyarearacing
Turbo type 4
http://shoptalkforums.com/viewtopic.php?f=3&t=134157
66 NA hard top
****Insert event here**** |
2true Samba Member
Posted: Mon Oct 22, 2007 8:57 am Post subject: |
| Agreed lose the GEX. Are the windows going to be red? |
vwfye Samba Member
Posted: Mon Oct 22, 2007 9:01 am Post subject: |
it doesn't say Gex... read it closer. _________________ 64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK" |
boxrod Samba Member
Posted: Mon Oct 22, 2007 10:06 am Post subject: |
| If you look closely, all the logos are slightly different from the real companies. ex: M8D, CEX, BUSPACK, AUTOCRASH, BEY. etc. After the real bus is built, the artwork will be redone to reflect the ACTUAL sponsors for the project. This artwork was done over 10 years ago just as a dream car, never knowing it would actually be built. |
FiveSeven Samba Member
Joined: August 22, 2004 Posts: 174 Location: Rocket City
Posted: Mon Oct 22, 2007 10:32 am Post subject: |
Any pictures of the Bus in it's current state? _________________ 57 Oval |
boxrod Samba Member
Posted: Mon Oct 22, 2007 10:42 am Post subject: |
| yea I'll get em up soon |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2962 Location: Fresno, Ca.
Posted: Mon Oct 22, 2007 7:04 pm Post subject: |
What a hack.  _________________ If you`re going to do something, do it right. |
boxrod Samba Member
Posted: Mon Oct 22, 2007 9:25 pm Post subject: |
| Two hacks = a whole. |
Church Key Samba Member
Posted: Tue Oct 23, 2007 12:04 am Post subject: |
Man, that salt is a MOTHERFUCKER to get out of your chassis/etc...
The salt is really otherworldly, and fucking peaceful.
Just don't depend on the food in Wendover...
We bring our grill, and do all of our own.
Enjoy...you always seem to have fun, dude. |
Clark Kustoms Samba Member
Joined: October 09, 2006 Posts: 798 Location: las Vegas
spudwinkle Samba Member
Joined: March 08, 2006 Posts: 177 Location: people's republic of Minnesota
Posted: Tue Oct 23, 2007 3:22 pm Post subject: |
I will kick in the muffler bearings. _________________ if you have not grown up by 50 you don't have to |
slammedtiki63 Samba Member
Posted: Tue Oct 23, 2007 6:15 pm Post subject: |
| I'll donate my wife to pose on it when it's finished. we go to vegas 1 or twice a year |
Posted: Tue Oct 23, 2007 6:26 pm Post subject: |
I'll send a NOS blinker fluid reservoir. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Nellynel Samba Santero
Joined: September 18, 2005 Posts: 194 Location: Brick City Jersey
Posted: Tue Oct 23, 2007 7:53 pm Post subject: |
| I'll donate cross drilled brake lines. |
boxrod Samba Member
Posted: Wed Oct 24, 2007 11:58 pm Post subject: |
| Well, I called John Jones at KCW to rap about a few things and he offered to do the body and paint labor !!! I just need to get the materials. I didn't even have to ask, he offered it to me straight up. So not only will it get done, but it will get done right and in short time. This is a race vehicle and not a show car so it won't be full show but you know it will look dam good. Thanks John and the Gang at KCW for your help. |
boxrod Samba Member
Posted: Thu Oct 25, 2007 12:01 am Post subject: |
| Also a special thanks to Kevin "Pigpen" Mccain for passing this project on to me for what he got it for. Thanks homie. |
