Stocknazi Samba Member
Posted: Sat Nov 03, 2007 7:51 am Post subject: removing rust from vin plate |
anyone have any ideas for a good way to remove rust from a steel vin plate without completly removing the stamped vin numbers? i tried a brass brush, but it is still really diffucult to see the numbers.
i think media blasting would be way too aggressive. ideas? _________________ WANTED:
Thomas Jefferson |
tanhis Samba Member
Joined: July 23, 2005 Posts: 662 Location: Rauma Finland
Posted: Sat Nov 03, 2007 8:42 am Post subject: |
It depends how bad the rust is. I would try glass blasting its one of the gentles way to blast rusted parts.
This is example of glass blasting
http://www.fvwa.sitefactory.fi/data/5392.jpg _________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton |
Ian Samba Moderator
Posted: Sat Nov 03, 2007 9:22 am Post subject: |
I would try like electroloysis or something of the like, maybe CLR?, something that will chemically remove the rust and not mechanically remove the rust.
My VIN in my engine compartment has been eaten away by battery acid, before I bought the Bus, long story. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 & KEN CRIMMINS 1957-2024 |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10804 Location: the past
Posted: Sat Nov 03, 2007 9:24 am Post subject: |
| soak/sumberge it in lemon juice for a few days to a week. |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2717 Location: Missoula MT
Posted: Sat Nov 03, 2007 10:02 am Post subject: |
| hazetguy wrote: |
well, when life gives you lemons, soak your rusty vin plate in lemon juice  |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71900 Location: Phoenix 602
Nic B-C Samba Member
Joined: January 02, 2006 Posts: 605 Location: North East UK
Posted: Sat Nov 03, 2007 5:01 pm Post subject: |
i'll give the lemon juice/clr treatments a try. thanks for the ideas. never understood why they did'nt make these plates out of aluminum like the made in western germany tags.
of course i have seen some 59-64 vin plates that had been somewhat eaten away as well. _________________ WANTED:
Thomas Jefferson |
Posted: Sat Nov 03, 2007 5:45 pm Post subject: |
| candyman wrote: |
| hazetguy wrote: |
lemon juice contains citric acid which is mild and yes, it does remove rust without serious metal damage. if you buy some in the store, get as pure juice as you can, as some is slightly watered down.
you just need to be patient, as it is a slow working process.
before on left, after a couple days in lemon juice on the right.
you might also try a product called evaporust, although you usually need to buy it in 5 gallon containers. |
vdubinit Samba Member
Joined: July 11, 2005 Posts: 1870 Location: central coast
Posted: Sat Nov 03, 2007 8:05 pm Post subject: |
| hazetguy wrote: |
| candyman wrote: |
| hazetguy wrote: |
great info  _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
bugboy63 Samba Member
Joined: December 11, 2005 Posts: 523 Location: tennessee
arthurnugen Samba Member
Joined: January 11, 2005 Posts: 3082 Location: The PNW, where "going green" means rolling with moss.
Posted: Mon Nov 05, 2007 2:07 pm Post subject: |
| hazetguy wrote: |
That's the coolest rust removal idea I've heard in weeks! _________________
| cdennisg wrote: |
| Lawyers don't deserve buses. |
| zozo wrote: |
| Don't worry too much. You can always trust a lawyer. |
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke! |
