1.9 Flywheel Bolts - Wont Budge!!!
camo westy
camo westy is offline
PostPosted: Tue Nov 13, 2007 3:09 pm    Post subject: 1.9 Flywheel Bolts - Wont Budge!!! Reply with quote
The good news; I took out the 1.9 and put in a Subaru 2.2.
Perfectly good 1.9, 65K miles, very usable to someone. Motor had been leaking oil from the flywheel end.
I had a buyer contact me, we agreed on a price, I said I would put in the flywheel end seal, being the honest, helpful sort that I am. ...
I have never run into bolts that just dont turn before. Using my 1/2 inch drive air wrench, I gave them the wappa---wappa---wappa. Not one would budge.
OK, now I'm curious. Has anyone run into this issue on a 1.9 WBX.
Symproms are loosing oil out the flywheel seal, and way tight flywheel bolts. Question
I'm sure I can remove these bolts, I've dealt with worse. I'll heat them next, nothing to loose, seal is bad already. If a few heat cycles doesnt free them up, I'll cut them off with a torch, and remove the 'stubs'. Install the new seal, and the new owner can install his own flywheel.
Any ideas appreciated.
reiney
reiney is offline
PostPosted: Tue Nov 13, 2007 3:45 pm    Post subject: Reply with quote
I like to heat 'em up, then soak w/ WD-40; then repeat several times over the course of a day or two. There is also a wide variation in the qualtity of impact wrenches. I've seen bolts that would take the "wappa-wappa" all day long without budgeing but spun right off once a commercial-quality heavy-duty impact was used. Gotta have plenty of air pressure too .... Good luck! Smile
winkshog
winkshog is offline
PostPosted: Tue Nov 13, 2007 3:52 pm    Post subject: Reply with quote
just had the same problem with the one I just did. I had to drill mine out all most. I drilled into that about 1/4 to 3/8 with a 3/8 drill bit and then tryed them they gave a little pop and came out sweet as can be. what a pain in the a$$. but they all came out
85 Westy
85 7 pass w/AC 2.2_Subaru
Facebook for Operation Injured Soldiers For those how gave when they servered
Loghome for sale For those that want to get away from it all....
thinair
thinair is offline
PostPosted: Tue Nov 13, 2007 4:54 pm    Post subject: Reply with quote
I did that to my 85 1.9 about a year ago to fix the same oil leak. You have to get a real long breaker bar, add length with a 3-4' iron pipe, you want about 4-5 of leverage then they come off no prob! I remember they were hot and had the smell of epoxy when I took them off. There had been some sort of industrial lock tight applied.
I hope you have something to keep it from turning, I took mine off while it was still attached to the wheels.
Good Luck
McVanagon
McVanagon is offline
PostPosted: Wed Nov 14, 2007 4:15 am    Post subject: Reply with quote
No matter how frustrated you get, don't use a shotgun.
http://news.bbc.co.uk/1/hi/world/americas/7091904.stm
'69 Mike
'85 GL
'87 Wolfsburg Hardtop
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
UH60Driver
UH60Driver is offline
PostPosted: Wed Nov 14, 2007 4:46 pm    Post subject: Reply with quote
Dude, thats some funny $hit!
