How to tell if I have Big nuts?
DUNEDRIVER
DUNEDRIVER is offline
PostPosted: Wed Nov 21, 2007 8:26 pm    Post subject: How to tell if I have Big nuts? Reply with quote
Okay so the topic sounds a bit funny, How do I tell if I have big nut RGB's or little ones? It is on a 67 bus.
Adaze1
Adaze1 is offline
PostPosted: Wed Nov 21, 2007 8:28 pm    Post subject: Small or large Reply with quote
Does a 36 mm socket fit the rear axle nut? Yes, small nut RGB
NO, large nut RGB
///Mink
///Mink is offline
PostPosted: Wed Nov 21, 2007 8:29 pm    Post subject: Reply with quote
I'm biting my tongue. Embarassed
Pop off the rear hubcap. If the nut holding the drum on is 36mm, then your Bus has small nuts. If it's 46mm, then they're big.
crofty
Judas of the North
crofty is offline
PostPosted: Wed Nov 21, 2007 8:48 pm    Post subject: Reply with quote
It's still stock height.
HamburgerBrad wrote:
Lohe
Lohe is offline
PostPosted: Wed Nov 21, 2007 9:23 pm    Post subject: Reply with quote
Anxious Use a ruler and measure them!
Skim
Rants Master
Skim is offline
PostPosted: Wed Nov 21, 2007 9:47 pm    Post subject: Reply with quote
depends on if shes experienced enough to tell you.
GFK
1953 Kabriolet
1959 Lowlight Ghia vert
jerry.t
jerry.t is offline
PostPosted: Thu Nov 22, 2007 11:14 am    Post subject: Reply with quote
if she hasnt told you by now, consider the obvius. Twisted Evil
p.s, a stock 67 would be big.
1957 euro oval
1958 standard euro bus
OGST
SBS #43
(14:39:50) Pintobean: i came out of the shower... cats were freaking out... i
69_Jim: I actually made girly noises as I was laying on the ground
VWSwap: I'm gonna post all over there...leave my DNA all over the place...make 'em bust out their black lights. Jerks.
WhitewallsJohnson
WhitewallsJohnson is offline
PostPosted: Thu Nov 22, 2007 11:50 am    Post subject: Reply with quote
Find a friend who knows, then compare them.
Show your love for the Land of Kong:
http://www.thesamba.com/vw/forum/viewtopic.php?t=254661&highlight=
Kermit, the highroof westy:
http://www.thesamba.com/vw/forum/viewtopic.php?t=318687&highlight=
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Thu Nov 22, 2007 12:12 pm    Post subject: Reply with quote
NO! no sword fighting here Mad
WhitewallsJohnson
PostPosted: Thu Nov 22, 2007 12:26 pm    Post subject: Reply with quote
This one time, at band camp...
Stocknazi
Stocknazi is offline
PostPosted: Thu Nov 22, 2007 12:29 pm    Post subject: Reply with quote
if you have later brakes with small nuts you have small nut/big nut boxes, 63 0nly. they are gearer the same as a big nut.
WANTED:
Thomas Jefferson
Stocknazi
if you have later brakes with small nuts you have small nut/big nut 1-ton boxes, 63 0nly. they are geared the same as a big nut.
WANTED:
Thomas Jefferson
WhitewallsJohnson
PostPosted: Thu Nov 22, 2007 12:42 pm    Post subject: Reply with quote
Interesting, so my 63 with little nuts is actually geared the same as my big nut buses?
Jesus, i dread buying parts for this thing when i do get started on it. Wink
Stocknazi
PostPosted: Thu Nov 22, 2007 4:07 pm    Post subject: Reply with quote
not all 63's would have the higher geared boxes. looks like m-215 would be for 1.26:1, 1-ton; m-216 would be for 1.39:1 ratio boxes. so not all 1500 equiped buses would have them. look to see if you have later brakes on the rear, that should tell you.
WANTED:
Thomas Jefferson
WhitewallsJohnson
PostPosted: Thu Nov 22, 2007 6:36 pm    Post subject: Reply with quote
not all 63's would have the higher geared boxes. looks like m-215 would be for 1.39 and m-216 would be for 1.26 ratio boxes. so not all 1500 equiped buses would have them. look to see if you have later brakes on the rear, that should tell you.
I dont have either of those M codes. Just M-360 (Blinkers and towelbars) but ill check out the brakes anyway, you know how parts get around Wink
VWAdam
VWAdam is offline
PostPosted: Thu Nov 22, 2007 6:48 pm    Post subject: Reply with quote
My Dad's '63 had much lower gearing than my '67 and his was a 1500 equipped Bus, still has the og engine in it. I don't remember what brakes it had though
All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana
Stocknazi
PostPosted: Thu Nov 22, 2007 8:00 pm    Post subject: Reply with quote
anyone have a clue why m-215 would say "except microbus and deluxe?"
m-215 1500 engine/1-ton payload, until oct.64
m-216 1500 engine, until oct.64
WANTED:
Thomas Jefferson
Da TOW'D
Da TOW'D is offline
PostPosted: Thu Nov 22, 2007 8:29 pm    Post subject: Reply with quote
Was there any other size rear axle/brake drum nuts?
Just 36mm and 46mm
was there a 42mm nut used?
'57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS
WhitewallsJohnson
PostPosted: Thu Nov 22, 2007 8:57 pm    Post subject: Reply with quote
Im assuming that means the option isnt available for passenger buses, since they wouldnt be used for hauling excessively heavy cargo, like the commercial models?
Or, are you thinking there is an alternate meaning for that M-code after Oct '64?
Just noticed my '63 has M-195 (adjustable back for bench seat). Thats pretty meaningless since its a 1/3 2/3 split. Maybe an alternate meaning after the intro of the split bench?
Things seems to get a little shakey in 63 dont they?
Last edited by WhitewallsJohnson on Thu Nov 22, 2007 9:11 pm; edited 1 time in total
WhitewallsJohnson
PostPosted: Thu Nov 22, 2007 8:58 pm    Post subject: Reply with quote
Just 36mm and 46mm
Do you have 42mm nuts Tow'd?
