vw donvieira Samba Member
Joined: May 11, 2004 Posts: 630 Location: stockton, California
Posted: Thu Nov 22, 2007 12:19 am Post subject: Compatible Ignition switch |
| I need to replace the ignition switch on my '56 oval. Does anyone make a switch that will work without doing any cutting to the dash. I have given up on a true NOS switch as they just do not sem to exist. Otherwise I am going to update the entire electrical system. Thanks, VW don |
vicky Samba Member
Posted: Thu Nov 22, 2007 7:48 am Post subject: Re: Compatible Ignition switch |
| vw donvieira wrote: |
I have seen them for sale here before. You can also check on E-Bay of course. Shouldn't be all that difficult to find at least a used one that's still in good condition |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17678 Location: Left coast, Canada
Posted: Fri Nov 23, 2007 1:50 am Post subject: |
There's no repro switch that fits an oval dash. Don't believe the high volume vendors that say their switch fits cars from 54-67 because the different dash shape of an oval requires a switch that is different. You are relegated to good used switches or the uber rare NOS ones that show up every couple of years. Last one I saw on eBay went for around $250. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Fri Nov 23, 2007 10:17 am Post subject: |
Gabrielle rebuilds stock switches... _________________ die schwarzen Schafe #666 |
65Westy Samba Member
Joined: February 15, 2005 Posts: 219 Location: Central Ohio
Posted: Fri Nov 23, 2007 5:30 pm Post subject: |
I found one for my 56 on ebay within the last 6 months. It came with
the cutout VW key and was less than $80. _________________ Craig
63 Beetle
72 Schnepp XL13 Vintage Formula Vee
72 Caldwell D13 Vintage Formula Vee
71 Super Beetle convertible |
nivag Samba Member
Joined: January 28, 2004 Posts: 244 Location: Vancouver, BC
Posted: Fri Nov 23, 2007 8:25 pm Post subject: |
VW Donviere - I have a really good used ignition w/ key for a 56 that I am about to list for sale. I sent you a PM.
Gavin |
Panhandle_dubs Samba Member
Posted: Fri Nov 23, 2007 10:27 pm Post subject: |
| dude check out BFY obsolete |
Bruce Samba Member
Posted: Sat Nov 24, 2007 1:16 am Post subject: |
BFY does not sell an oval ignition switch.
Here's the difference between an oval switch (left) and a later one. The oval requires a longer mounting tab.
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 1066 Location: Gilbert,Arizona
Posted: Sat Nov 24, 2007 5:48 pm Post subject: |
| Bruce wrote: |
So cut and weld if you have too!(the bracket i mean). _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red) |
Bruce Samba Member
Posted: Sun Nov 25, 2007 1:19 am Post subject: |
| GDOG57 wrote: |
| ...So cut and weld if you have too!(the bracket i mean). |
Not so simple. The oval's switch's bracket is directly inline with the centerline of the switch. A 58 and later's bracket is offset to the side.
But if you must attempt this, start with a 58-59 only switch so you still use a SG key to match with your door handle and deck lid handle. _________________
GDOG57 Samba Member
Posted: Sun Nov 25, 2007 10:42 pm Post subject: |
Your right,i see it's a little off,it was a thought! _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
