Anyone ever fabricate rear side windows that open?
bucko
bucko is offline
PostPosted: Tue Nov 27, 2007 2:44 pm    Post subject: Reply with quote
I would buy, especially on the rear drivers side. It's darn near impossible to clean that glass on the inside behind the closet. A slider window setup would fix that, so long as we can get to the bottom tab "locker" that lets it slide....
Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181
dobryan
dobryan is offline
PostPosted: Tue Nov 27, 2007 8:36 pm    Post subject: Rear Jalousie window Reply with quote
How's this? Very Happy
If they didn't post try going to
http://picasaweb.google.com/dnd.obryan/JalousieWindows
I love the flow thru ventilation especially when it's raining. Very Happy
Dave O
'87 Westy
McVanagon
McVanagon is offline
PostPosted: Tue Nov 27, 2007 9:03 pm    Post subject: Reply with quote
dobryan wrote:
How's this?
'69 Mike
'85 GL
'87 Wolfsburg Hardtop
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
bucko
bucko is offline
PostPosted: Wed Nov 28, 2007 5:16 am    Post subject: Reply with quote
McVanagon wrote:
dobryan wrote:
How's this?
Interesting. Got any details, like, where did you get them, or how did you make them?
dobryan
dobryan is offline
PostPosted: Wed Nov 28, 2007 6:28 am    Post subject: Reply with quote
Yes. I used this article
http://www.everybus.com/dworkin/vgon_jalousie/
as a guide.
I double checked the dimensions against the glass I removed from the Westy to get the right fit. I obviously had to extend the rear side piece to match the curved shape of the original window, and I had to remove the glass and cut down the frames to be shorter for the passenger side one. No big deal really, just some tedious work.
BTW, I was also able to get a set of seals for the Jalousie windows that included all the little seals around and between the window panes so they seal real nice.
This has totally transformed the comfort of the Westy. I really do get great flow thru ventilation even on very hot days, and don't have to worry about rain coming in. I can get a breeze across my face when I am sleeping on a hot muggy night. Very Happy
It also is great for expelling heat from the Dometic fridge area since I can keep the window open behind the fridge in all weather.
It's a great way to go if you've got the time and patience.
Dave O
The Western Syncro build
Wellington
Wellington is offline
PostPosted: Wed Nov 28, 2007 8:54 am    Post subject: Reply with quote
Thanks for all the kind words. There is one other option I would consider, since i saw how easily the frame could be reworked, i thought a nice pop out window, like the ones I have on my Beetle 1/4 widows would be cool. Oh how i like to dream........, any one want to donate some Beetle pop out frames. I figure two of those shold be able to do one rear window.
msinabottle
msinabottle is offline
PostPosted: Wed Nov 28, 2007 1:15 pm    Post subject: LUST! Oh, LUST! Reply with quote
That double Jalousie job is just... about... perfect. That is exactly what I need for summer camping and rain in Winston.
Plot, plot, plot, scheme...
Will raid wrecks for the window frames, just for starters... And maybe I can find a good source for rebuilt jalousies...
LUST!
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
dobryan
dobryan is offline
PostPosted: Wed Nov 28, 2007 5:28 pm    Post subject: Reply with quote
The jalousies I started with were in rough shape. But after some elbow grease with sandpaper and steel wool I was able to take off the old oxidation from the aluminum and they shined up real nice. I also rescreened them (just like doing a screen door). The frame extension is made from scrap aluminum which is then bonded to the original jalousie frame like in the drawings. Not hard to do but a PITA. I definitely found the use of a table saw and a router to be a BIG help. Very Happy
This arrangement works so well that I never even open the sliding window on the sliding door anymore. That is good because that window always screeched at me. Laughing
Dave O
motelvw
motelvw is offline
PostPosted: Sat Dec 01, 2007 5:57 pm    Post subject: Reply with quote
dobryan, can you open the sliding door with the jalousies open?
BTW, beautiful job on those windows. It's on my someday list.
dobryan
dobryan is offline
PostPosted: Sun Dec 02, 2007 6:51 pm    Post subject: Reply with quote
Yes, I can open the slider. In fact the pic I showed is the amount that the rear window will open and let the sliding door clear it. I always open the sliding door first and then look as I open the jalousie to see how far I can open it before it will interfere with the door. My last step in this project it to put a stop in the jalousie so I can't open it too much.
I'm glad you like it. Smile
Dave O
msinabottle
PostPosted: Fri Feb 22, 2008 11:11 pm    Post subject: Beginning the Jalousie Project Reply with quote
I don't know if dobryan's still around, I recall no recent posts. I have a set of jalousies = 2 louvered windows on order from a Breadloaf salvage yard, they're also selling me seal rebuild kits and screens that the hardware store can repair.
The plan is to rebuild 'em, clean 'em up, and follow the old article for the passenger's side middle, and try to back-engineer what dobryan did on the rear passenger's side.
One thought I had was to pull a rear passenger's rear window frame from a wreck and weld the Jalousies into that, with a plate attached to fill in the curved part and that painted.
Okay, when were you guys ever going to tell me that there ARE no window frames?
Shocked
I mean, there are for the sliding windows, but not for the glass on the rear passenger's side. So it'll be a matter of cutting a piece of metal to fit the window profile and attaching that to the rear jalousie. That'll be easier, but complicated... May have to leave the window out of the van for a bit, unpleasant thought.
I will do my usual verbose reporting on how it goes, but if anybody has any advice or specifics, I am scrabbling, groveling, and grateful for same.
I repeat...
Shocked
Best!
dobryan
dobryan is offline
PostPosted: Sun Mar 02, 2008 3:44 pm    Post subject: Reply with quote
msinabottle PM'd me asking for more information. I will start a new topic for this. Give me a few days to get my act together. Very Happy
Glad everyone likes what I did.
BTW, On a hot day last summer I did an experiment. The outside temp was 93F and a gentle breeze was blowing. I put the bus in the driveway in full sun, opened the Jalousie windows the amount shown in the pics, put a thermometer inside on the stove top and waited. I was surprised that after one hour the inside temp was only 3 degrees above the outside temp. The great cross flow ventilation kept the inside from overheating. I'm sure the result would not have been as good without the gentle breeze. Smile
Regards.
Dave O
dobryan
dobryan is offline
PostPosted: Thu Mar 06, 2008 10:24 pm    Post subject: Reply with quote
I just posted a new topic on my installation here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=283728
Dave O
Lanval
Lanval is offline
PostPosted: Thu Mar 06, 2008 11:27 pm    Post subject: Reply with quote
Hey MS,
If you're interested, these double Jalousie windows show up from time to time on the German Ebay; I was going to buy one a few weeks ago before the continuing existence of my engine became dicey.
http://cgi.ebay.de/Lamellenfenster-VW-Bus-T2-T3-Fe...dZViewItem
edit: Adding pic:
and another type of window; says its for a Joker model, though I'm a bit pressed to believe this is OEM... maybe I misunderstood the ad.
Won't be cheap, but would allow matching jalousie set up on both sides, or possible enable you to collapse the middle and use it in the rear passenger window.
if you need some translating or help in communicating with the seller, let me know. My German is passable.
Best,
Lanval
Classicvibe
Classicvibe is offline
PostPosted: Tue Nov 02, 2010 7:06 pm    Post subject: Reply with quote
Resurrecting the dead here...
Wellington, did you ever mount that window? I would love to see pics of the finished product.
On a mission, the destination is just an excuse.
Syncro Solstice 2022...see you there!
1986.5 Wolfsburg Syncro Westfalia Poptop Weekender Transporter
otiswesty
otiswesty is offline
PostPosted: Wed Nov 03, 2010 3:34 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=958793
You can see one of Wellington's windows on the opposite side. He made 2 of them, lucky me. The driver's side factory window has no built in screen but with the window all the way open, I can insert a screen with 1" to spare and close the window holding the screen in place. It works well overnight for camping and ventilation of the downstairs sleeping space. I have not tried driving with the screen in because I worry about it falling out.
1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Nov 04, 2010 2:56 pm    Post subject: Reply with quote
Shocked expensive......
the ones from south africa have the plastic vent included,latch is on vertical part of glass.225$ Mad
PDXWesty
PDXWesty is offline
PostPosted: Thu Nov 04, 2010 3:06 pm    Post subject: Reply with quote
If anyone wants the Jalouse windows, give these guys a call. http://airheadparts.com/ They had a stack of about 25 of them at a VW show I went to all for very cheap.
89 Westy 2.1 Auto
spitsnrovers
spitsnrovers is offline
PostPosted: Thu Nov 04, 2010 5:25 pm    Post subject: Reply with quote
There is another option, as shown here http://www.griffco.ca/interest/
'88 VW Westfalia
'75 Triumph Spitfire 1500
joetiger Premium Member
joetiger is offline
PostPosted: Wed Feb 23, 2011 1:26 pm    Post subject: Reply with quote
Thread Resurrection...
I was reading the Jalousie Window thread (having seen Winston's personally, they are quite impressive) I started thinking again about rear sliding windows. Has anybody tried RV replacement windows? I started looking around and saw this website:
http://www.motionwindows.com/prod1800.php
I figured it was a dead end until I saw the shape of the example window on their order worksheet:
http://www.motionwindows.com/order-summary-worksheet.pdf
I sent them an email to see if they've ever had their windows used in Vanagon applications, and/or whether or not they think it's possible. I haven't heard back yet.
Joe T.
'02 Baja-ish Beetle "Bubbles"
Page 4 of 10
