Split 1 Samba Member
Joined: May 03, 2005 Posts: 764 Location: Adelaide. South australia
Posted: Fri Dec 07, 2007 10:52 pm Post subject: Any Supercharged Pics |
Has anyone got any pics or info on supercharged VW motors.
Thanks
Dave |
akokarski Samba Member
Posted: Fri Dec 07, 2007 11:36 pm Post subject: |
tons, just search. This has been a hot topic quite a few times lately.
Anton |
Marks67 Samba Member
Joined: December 17, 2006 Posts: 130 Location: Costa Mesa
mbugz60 Samba Member
Joined: November 26, 2000 Posts: 1369 Location: St. Martinville, Louisiana
Posted: Sat Dec 08, 2007 5:11 pm Post subject: |
2387 with 7 pounds of boost. _________________ Mike |
Eric_S Samba Member
Joined: August 12, 2007 Posts: 862 Location: Sparks (think Reno) NV
Posted: Sat Dec 08, 2007 11:15 pm Post subject: |
Damn! That looks intimidating! Just a tad bulkier than a turbo though. _________________ --
Eric_S
What are all these extra parts? |
Posted: Sun Dec 09, 2007 12:31 am Post subject: |
That is one of if not THE best beetle I have seen.
I am thinking of fitting two chargers to a 2007 stroked motor for my split.
One on each intake manifold, they are the small AMR 500 japanesee ones.
Dave |
splitty_smile Samba Member
Joined: October 01, 2003 Posts: 506 Location: Independence, OR
Posted: Sun Dec 09, 2007 4:31 pm Post subject: |
I'm a fan of these:
_________________ ---1976 standard bus "The Red Toad" transplanted 78 FI 2.0, Hydraulic lifters
---1974 Super Beetle "Gus" 1835 Engle 110 Dual Kadrons |
lbubbyj Samba Member
Posted: Mon Dec 10, 2007 2:47 pm Post subject: |
Split 1, That sounds like a sick idea. One small charger for each cylinder and one blow thru carb feeding each head. D o you have pictures of these small blowers? |
Hotrodvw Samba Member
Posted: Mon Dec 10, 2007 2:55 pm Post subject: |
I'll help where I can...
_________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Mon Dec 10, 2007 3:24 pm Post subject: |
Hotrodvw wrote: |
interesting how they mounted the one backwards to accomodate the thick belts. _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
smwaaw Samba Member
Joined: April 11, 2005 Posts: 12 Location: Douglasville GA
Posted: Mon Dec 10, 2007 5:44 pm Post subject: supercharge |
Has anyone ever tried to put a Paxton or Vortech supercharge on a VW. Looks to me to be a simple add instead of a turbo. Just wondering what ya'll think. |
tumtum Samba Member
Posted: Mon Dec 10, 2007 8:21 pm Post subject: |
mbugz60 wrote: |
2387 with 7 pounds of boost. |
jesus christ that is tight _________________ you know what they say about us welders, we do it in all positions, and we have deep penetration! |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Mon Dec 10, 2007 11:04 pm Post subject: |
Hey mbugz, have you had any issues with the charger belt tensioner causing thrown belts? I have a buddy with a part time buggy shop, who has a customer with this issue. I told him to use a flat idler to pull the belt, vice push on it like the one in the kit. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Shorrock Samba Member
Posted: Mon Dec 10, 2007 11:38 pm Post subject: Re: Any Supercharged Pics |
Split 1 wrote: |
Thanks
Dave |
Shorrock C75BV Supercharger. Was an off the shelf bolt on kit offered by EMPI in the early 60s.
Posted: Tue Dec 11, 2007 3:58 am Post subject: |
miniman82 wrote: |
Hey mbugz, have you had any issues with the charger belt tensioner causing thrown belts? I have a buddy with a part time buggy shop, who has a customer with this issue. I told him to use a flat idler to pull the belt, vice push on it like the one in the kit. |
If it is lined up with the blower and crank pulley, it should stay on with no problem. I had to put spacers between the tensioner and the mounting bracket to get the correct alignment on mine. Have your buddy check the three point alignment on the belt the next time he has the car. _________________ Mike |
Posted: Tue Dec 11, 2007 6:17 pm Post subject: |
mbugz60 wrote: |
miniman82 wrote: |
If it is lined up with the blower and crank pulley, it should stay on with no problem. I had to put spacers between the tensioner and the mounting bracket to get the correct alignment on mine. Have your buddy check the three point alignment on the belt the next time he has the car. |
It's lined up correctly, the problem is the idler is supposed to be kept stationary in it's little spring loaded tube by a sort of spline. Trouble is, it's wallowed out now, so the idler moves like 30* left and right, causing the belt to come off.
I should have mentioned that first, I guess.
I thought it was kind of a poopy design, and he's not sure what to do with it. That's why I suggested using a flat idler on the other side of the belt to pull it tight. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Posted: Tue Dec 11, 2007 6:38 pm Post subject: |
Yeah, sounds like a new tensioner needs to be fabricated. _________________ Mike |
Terry Cloyd Banned
Joined: March 23, 2004 Posts: 2218 Location: Valley Center "SO CAL"
Posted: Tue Dec 11, 2007 7:08 pm Post subject: |
DaveM wrote: |
Hotrodvw wrote: |
interesting how they mounted the one backwards to accomodate the thick belts. |
So Dave your not going to show them pictures  |
ian c Samba Member
Posted: Tue Dec 11, 2007 8:39 pm Post subject: Re: Any Supercharged Pics |
Split 1 wrote: |
Thanks
Dave |
Posted: Wed Dec 12, 2007 10:20 am Post subject: |
Terry Cloyd wrote: |
DaveM wrote: |
Hotrodvw wrote: |
