buster Samba Member
Joined: September 20, 2002 Posts: 283 Location: Missouri
Posted: Fri Aug 17, 2007 7:57 pm Post subject: Cargo door latch identification |
I guess i never knew there was different kinds of rear cargo door latches. Whats the deal between the two? Year changes, what? One came of a double door panel if that makes a difference.
Lohe Samba Member
Joined: June 26, 2007 Posts: 662 Location: Chandler, Az
Posted: Fri Aug 17, 2007 8:40 pm Post subject: |
Duh, one ends with an A and the other with a B, cant you see??
A = 55-63 and B = 63-67 from classified ads.. I had no idea either  |
Clara  Samba Member
Posted: Sat Aug 18, 2007 7:48 am Post subject: |
you can look up parts in the online parts list... see this page, look on the right hand side:
http://oacdp.freeweb7.com/5867part/447.png
you can see the A version takes different check rods than the B version... the B version takes the kind with circles for the bolt to go through that bolts to the mechanism on the arms that stick out.
The check rod for the A mechanism has a little notch that hooks inside the mechanism. The mechanism does not have arms. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Josh_crosson Samba Member
Posted: Sat Aug 18, 2007 11:34 am Post subject: |
ok so i had the "A" from a box of parts i had. And i had the other side door latch, the big one with the arms that come out that the rods screw on to, so naturaly i thought that i needed the "B" one cause it had the arms that stick up for the rods to screw on to as well. I just looked at both "A" and "B" and it looks like the mounting holes are on the same side on the "A" and opposite on the "B" my 58 door has them on both sides. Also how and what do i use for the rods on the "A" latch?
Sorry if that reads like a tard wrote it, but it makes sence to me......LOL _________________
| vwluver74 wrote: |
| josh, if you ever see anyone in here with a screenname of weatherly, call him mathilda heatherly and watch what happens |
| RoachGhia wrote: |
| LOL, do it josh. |
2004 Passat W8 4Motion
samba# 65532 |
rjonas Samba Member
Joined: July 24, 2004 Posts: 644 Location: Chandler, AZ
Posted: Wed Dec 19, 2007 8:06 am Post subject: Re: Whats up with these cargo door latches |
Last night I was assembling this mechanism on my 59 std and in the bag that I labeled 2-years ago was the mechanism "A" but it also had two little spring clips that I cant figure out how they fit. My Bently is a 63-67 and only shows the later "B" style.
Anyone have an exploded view or description of how these spring clips work?
Thanks.
Roy
_________________ 1979 Type-2 Westfalia “Sandy”
1973 Type-181 Thing "Velma"
1956 Type-1 Beetle Patina Project “Rosie”
www.azbusclub.org |
technowar Samba Member
Posted: Wed Oct 21, 2009 6:31 am Post subject: |
| So in a 62 cargo door, how many hole latches they have in the frame? |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72040 Location: Phoenix 602
elliottjohnson Samba Member
Joined: June 20, 2009 Posts: 160 Location: fresnOakland
Posted: Wed Oct 21, 2009 12:56 pm Post subject: |
| technowar wrote: |
As Everett says there are two holes in both styles. The real question is over the placement of the holes. If the holes line up vertically you need an A style. If the holes are offset you'll need a B style.
The A and B styles accept different style rods. The A's have a notched rod and the B's have a rod with holes for screws to attach to.
The OACDP is great for this stuff, like Clara pointed out. |
Clara  Samba Member
Posted: Tue Mar 23, 2010 9:59 am Post subject: |
early:
later:
