Replacing panel clips with screws?
renobdarb
renobdarb is offline
PostPosted: Fri Jan 11, 2008 4:26 pm    Post subject: Replacing panel clips with screws? Reply with quote
I'm in the process of re-doing all my interior panels (slider, doors, kick panels, rear hatch, ect.), and was hoping to avoid securing them with the plastic panel clips. Ideally I'd like to secure them with stainless steel screws and some finishing washers. For instance, I think these are screws and washers holding this one in, and I thought it looked really nice:
Can anyone give advice on how to modify the holes to make them accept screws?
Thanks!
1978 Campmobile, 2000cc w/hydro lifters, dual Weber 44 IDF carbs (50 idle jets, 115 main jets), SVDA distributor w/Compufire.
Blaubus
Blaubus is offline
PostPosted: Fri Jan 11, 2008 4:33 pm    Post subject: Reply with quote
dont modify the existing holes- drill some new ones
busdaddy
busdaddy is offline
PostPosted: Fri Jan 11, 2008 6:28 pm    Post subject: Reply with quote
Head for the FLAPS and find some 1/4" plastic plugs that accept screws.
Looks good, you put plastic behind them, right?
Слава Україні!
Karl
Karl is offline
PostPosted: Fri Jan 11, 2008 6:32 pm    Post subject: Reply with quote
Bay window door panel clips are metal.....
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=N143893
busdaddy
busdaddy is offline
PostPosted: Fri Jan 11, 2008 6:43 pm    Post subject: Reply with quote
Or if you're made of money you could use splitty clips.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=221867615A
Karl, I'm suggesting putting plastic plugs in the clip holes in the door to screw into as the original clips aren't going to be pretty with bare panels.
Or he could do as Dan suggested and screw beside them directly into the metal.
Слава Україні!
Jerry
Jerry is offline
PostPosted: Fri Jan 11, 2008 7:49 pm    Post subject: Re: Replacing panel clips with screws? Reply with quote
Thanks!
Hello, & I agree w/Dansvans, I prefer screws & finishing washers b/c if you need to get back into the window workings, or install door speakers, whatever, you can. Busdaddy's idea is better though. that way your not drilling more holes like I did. If you do decide to drill holes, just use a 1/4" nut driver in your drill, & use a self-drilling screw the same diameter of your stainless screws. Then, back it out, and screw in your stainless screws. This method keeps you from sending the drill bit through your exterior door skin Mad . Karl, from reading your previous posts, I have much respect for your ideas, but, those clips are a pain in the a$$, especially on a big panel. Although they do the job, they also have a tendency to break off in the hole as well. If you do the clip method, get twice as many as you need, I got mine from MidAmerica, & they were crap. Just my 2cents... hope this helps you out.
HastaAlaska
HastaAlaska is offline
PostPosted: Mon Oct 01, 2018 1:53 am    Post subject: Re: Replacing panel clips with screws? Reply with quote
Just want to add my two pence worth, My previous panels were scred directly into the metal. They were constantly coming lose with road vibrations, many were lost over time and re-torquing them became a weekly chore. (bus used daily) I'm sure the issue became exasperated as the holes grew with the inevitable rust that developed.
I suppose you use blue lock-tight or nail varnish to help prevent the loosening, but I'm not sure how effective that would be as I haven't tried it on a sheet metal screw.
Around The World in a VW - Follow the Docuseries
2011 - 20Something
Latest Adventure Series - https://bit.ly/LifeDoneDifferently
View user's profile Send private message Visit poster's website Facebook Twitter Instagram Gallery Classifieds Feedback
kreemoweet
kreemoweet is offline
PostPosted: Mon Oct 01, 2018 8:28 am    Post subject: Re: Replacing panel clips with screws? Reply with quote
I'll second the warning about using screws instead of clips: in my case I used machine-threaded nutserts in
the original holes and nice stainless screws and finish washers. The screws were constantly backing out, so that
I had to use locktite on many of them. Then the nutserts would eventually lose their grip in the hole, and would
spin in the hole when an attempt to loosen or tighten a screw was made. Several panels had to be destroyed
when it became necessary to remove them. Wot a fustercluck!
'67 bug: seized by the authorities
Zed999
Zed999 is offline
PostPosted: Tue Oct 02, 2018 2:04 am    Post subject: Re: Replacing panel clips with screws? Reply with quote
Clips every time, those screws look butt ugly, are unnecessary and a dead giveaway that someone was in too much rush to work out how to orientate the clips or simply didn't have enough clips or bought the wrong size clips.
Orientating the clips to line up with the holes is easy. Just imagine the clips are there to stretch the panel and you won't be far out.
Mainly, why would anyone want to add ugly screws to a neat panel with invisible fixings?
rottenkid
rottenkid is offline
PostPosted: Tue Oct 02, 2018 2:37 am    Post subject: Re: Replacing panel clips with screws? Reply with quote
My panels stay secure with screws.
bent_karma
bent_karma is offline
PostPosted: Sat Nov 17, 2018 8:55 am    Post subject: Re: Replacing panel clips with screws? Reply with quote
What size screws did you use?
'71 VW Westfalia Bay [Bowie]
'23 Toyota Tacoma 4x4TrD 6sp
'71 VW Bay Window Deluxe Bus [Busness] sold
'73 VW Thing [Agent Orange]
'71 VW Squareback (first air cooled/vw ever) sold
'07 Mazda3 Hatchback GT [the Mazda] sold
'06 Nissan Sentra 1.8 S sold
'18 Subaru Forester 2.5i [Sue Bee]
"Water is for drinking"
