Malibu Maxx
Page: Previous  1, 2, 3
66busman
Samba Motorcyclist
66busman is offline
PostPosted: Mon Jan 28, 2008 3:47 pm    Post subject: Reply with quote
autiger78 wrote:
chillz1 wrote:
Icy wrote:
This sounds very, very far-fetched. Plastic pulleys and cardboard gears????
It's true, unfortunately, Gary. Many automakers have used a plastic-type idler for years. Now, the gears aren't really cardboard, but are composed of a paper-fiber type material (which oddly enough, is somewhat reliable). Supposedly to help with noise reduction.
Yep, I bet cardboard gears grind nice and quiet...
Grind into pulp, you mean. I wish I had a picture of it....
'66 SO-42
'73 Bay
'75 Type 181
chillz1
chillz1 is offline
PostPosted: Mon Jan 28, 2008 3:51 pm    Post subject: Reply with quote
You know, I've torn down a ton of engines that used fiber gears, and have seen VERY few with any problems. I think using high lift cams and heavy valve springs would certainly spell their death, but using stock valve train, the reported problems are somewhat few. I still think that automakers could come up with a better idea, though.
2%
http://www.animalsintheattic.com
Click to view image
66busman
Samba Motorcyclist
66busman is offline
PostPosted: Mon Jan 28, 2008 5:54 pm    Post subject: Reply with quote
My experience was very isolated(only chevy truck i've ever been asked to take a look at), but first impressions are everything. This truck was a total pile anyway. Huge, fist sized rust holes, bald tires, 200k + miles, amazing it made it as long as it did. Still, like you said, it would be nice to not make parts out of "pressed paper" or what ever.
But we digress...
'66 SO-42
'73 Bay
'75 Type 181
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Mon Jan 28, 2008 6:57 pm    Post subject: Reply with quote
Okay, Chillz, you win. No Maxx for me this week.
I bought another Ranger. 2002. 4door. XLT. 4 wheel drive.
Nine thousand, three hundred miles.(yes 9,300.)
Eight grand plus my 2001 two-wheeler with 97,000 miles. Very Happy
Gary
Person of Interest
Gary is offline
PostPosted: Mon Jan 28, 2008 7:52 pm    Post subject: Reply with quote
Well, the Model T used planetary gears in the transmission that were made from soybean fibers. People need to remember that all of this is done in the name of fuel efficiency standards. When my dad retired from the automotive industry in 1984, the directive from Detroit was to reduce the weight of every single part, including nuts, bolts, and screws, by approximately 10%. That's why we have "cheap, plastic" cars these days, or in the example of Ford pickups, trucks with radiator mounts that break because they are made from magnesium.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
///Mink
///Mink is offline
PostPosted: Mon Jan 28, 2008 9:14 pm    Post subject: Reply with quote
I've had to replace a couple of the plastic idler pullies on the BMWs I mentioned earlier, but it was never the plastic pulley that went bad, it was the sealed bearing pressed into it that failed. So not all plastic parts suck.
But then again, on the same cars BMW chose to use plastic thermostat housings and radiators with plastic end tanks. Replacing a radiator on an e34, e36, e39, etc is considered preventative maintenance at 50,000 miles unless you want your radiator neck to completely break off while driving. Rolling Eyes
i_am_cool_fred
i_am_cool_fred is offline
PostPosted: Tue Jan 29, 2008 1:54 pm    Post subject: Reply with quote
mike yapps wrote:
Isn't the Malibu Maxx a remake of the Citation?
motor trend even said it was an "oversized hatchback"
proud owner of a defunct 1979 sunroof kombi
Brian Denning, as seen on Gearz TV
Samba Curmudgeon
iowegian is offline
PostPosted: Tue Jan 29, 2008 2:23 pm    Post subject: Reply with quote
Of course it is a Citation.
How stupid of me. Embarassed
_monkey_
Samba Monkey
_monkey_ is offline
PostPosted: Tue Jan 29, 2008 3:13 pm    Post subject: Reply with quote
My dad gave me an old Citation about 17(?) years ago. I might have driven that pile of shit 1000 miles before the flywheel sheered the bolts that held it. It had a really reliable engine, whatever good that does when it doesn't turn the transmission.
59 vw guy
59 vw guy is offline
PostPosted: Thu Jan 31, 2008 12:07 pm    Post subject: Reply with quote
To late now but if you like the car get it and get an extended warranty i have a 2006 malibu and so far good luck except the front rotors warping from me or the po i bought it used.. but it under warranty and they fixed it without problem ..And mine is the ltz model and man it will scoot.. but i think most car problems are just the luck or unluck of the draw.. But i always get extra warranty only way to go.
New project 66 bug And 61 bug for parts if you need some 61 parts im me to see if i have it Will trade 61 parts for dual carbs and bumpers for a 66..
Page 3 of 3
