Karmann Ghia Chassis OK
Faust
Faust is offline
PostPosted: Sun Mar 09, 2008 10:03 pm    Post subject: Karmann Ghia Chassis OK Reply with quote
I am new to this forum, but not to mechanics. Here is the story, I recently picked up an old, complete but tired, Aztec GT. This has a Corvair engine and a rotted bottom. I also came across another kit car, a German Apal, I think. This has the 140 hp engine.
Ok, to the point. My local boneyard has a K-G with a good bottom and disc brakes, any problem with using that chassis under the Aztec?
didget69
didget69 is offline
PostPosted: Sun Mar 09, 2008 10:10 pm    Post subject: Reply with quote
Ghia pan is fine, but you'll have to install Beetle floorpans to make it work -
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
towd
towd is offline
PostPosted: Sun Mar 09, 2008 10:11 pm    Post subject: Reply with quote
The only thing is you will need to reshape the front of the pan,, It's wider than a Bug.
you will want to stiffen the pan anyway, by running something like 1 1/2 x 2 1/2" tube around the edge
Faust
Faust is offline
PostPosted: Sun Mar 09, 2008 10:28 pm    Post subject: Reply with quote
I also want IRS would I be better of to just take the K-G front suspension and brakes, then look for an IRS Beetle chassis. I know everything can be converted, just trying not to "learn by doing" anymore than I have to.
Thanks for the responses so far.
lostinbaja
lostinbaja is offline
PostPosted: Mon Mar 10, 2008 3:42 am    Post subject: Reply with quote
There is no need to reinforce the pan unless you really want to, it will work fine in stock form. Mine has since early 1968.
Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
BL3Manx
BL3Manx is offline
PostPosted: Mon Mar 10, 2008 5:51 pm    Post subject: Re: Karmann Ghia Chassis OK Reply with quote
You say the Aztec is sitting on a chassis with a "rotted bottom". If you're saying the floorpans are rusty, then they're fairly easy to replace. I'm not sure whether your Aztec uses a shortened chassis but if it does, and the tunnel is solid, then it makes much much more sense to replace the floorpans on the chassis you already have than buy a Karman Ghia chassis (which you may have to shorten and will have to replace the floorpans on ayway because they are the wrong shape).
I'd try get the 140 hp engine anyway though.
Faust
Faust is offline
PostPosted: Mon Mar 10, 2008 6:11 pm    Post subject: Re: Karmann Ghia Chassis OK Reply with quote
I think it is just the floorpans. The car is "rough" so I am expecting a full tear down. My local boneyard has about a dozen beetles, I settled on the K-G because of the disc brakes. Then started thinking, I should also go for the IRS.
I found an Aztec manual on the 'Net. It doesn't appear that it has to be shortened.
I'm taking that. The price is $300 for the whole car. Getting it home is the only problem at the moment.
Now that I have people's attention. I have seen reference on the 'Net for a "kit" that puts the Corvair engine and transmission in an IRS Vanagon. Will that work in a Beetle chassis? Any real advantage besides not reversing the rotation?
Faust
Faust is offline
PostPosted: Mon Mar 10, 2008 6:31 pm    Post subject: Reply with quote
I think the last year headlight covers were legal, was 1966. That was when they took them off the XK-E. Too bad, this needs them. To give you an idea of how "rough" it is, here you go:
[/img]
CoryN
CoryN is offline
PostPosted: Mon Mar 10, 2008 6:41 pm    Post subject: Reply with quote
That --it will buff out Wink
Faust
Faust is offline
PostPosted: Mon Mar 10, 2008 7:15 pm    Post subject: Re: Karmann Ghia Chassis OK Reply with quote
That is in this car. I think it is an Apal kit. Don't have a picture of the nose, it is sort of Porsche 917. Being a German kit, and missing a lot of pieces, I'm not too interested in anything but the 140hp engine.
[img]
While we are at it, does anyone recognize this? I think that someone had a Bentley kit in the 80's. That is what this looked like. Kind of like it,but the rear is burned off. An awful lot of fabrication if it wasn't possible to find the pieces:
[/img][img][/img]
BL3Manx
BL3Manx is offline
PostPosted: Mon Mar 10, 2008 8:26 pm    Post subject: Re: Karmann Ghia Chassis OK Reply with quote
Faust wrote:
[Now that I have people's attention. I have seen reference on the 'Net for a "kit" that puts the Corvair engine and transmission in an IRS Vanagon. Will that work in a Beetle chassis? Any real advantage besides not reversing the rotation?
At Tahoe last year I saw a Corvair engine and transaxle mounted in in a Bounty Hunter dune buggy that was on a shortened IRS beetle chassis. The builder(previous owner) had removed the rear horns from the chassis. The front of the trans was bolted to the torsion housing and the rear of the trans was and basically hung from a tube steel cantilever structure he built under the back seat. The engine wasn't separately supported, just at the bellhousing like a VW. His half axles had Corvair U-joints at the transaxle end and VW CV-joints at the stub axle end, similar to what they use in Type 2/Corvair conversions.
The biggest advantage in not reversing engine rotation is cost savings. Reversing rotation means a full rebuild. If you can use a stock used engine, right off the top you'll save $1000.
Faust
Faust is offline
PostPosted: Mon Mar 10, 2008 9:24 pm    Post subject: Re: Karmann Ghia Chassis OK Reply with quote
My car has all sorts of support stuff going on for the engine, a lot of it hangs out from under the body. I am not sure all of that is necessary. I'll get a better look later.
Here is the site that shows the Corvair installation in a '70 bus. I thought they were all the same under the skin and the kit might work for a Beetle chassis. Since no supplier of the "kit" is named, I emailed the author. No response.
http://www.type2.com/library/enginem/busvair.htm
BL3Manx
BL3Manx is offline
PostPosted: Mon Mar 10, 2008 9:57 pm    Post subject: Reply with quote
Transvair used to make kits for it but its been years. Clarks Corvair may still have some of the Transvair U-joint adaptor pieces they used. You'd have to fabricate everything else.
http://www.corvair.com/
then go to
(Otto catalog page 44)
Faust
Faust is offline
PostPosted: Mon Mar 10, 2008 10:04 pm    Post subject: Reply with quote
then go to
OK, that looks like most of it. Since they specify "bus axles", I suspect there is a difference. Can they be integrated with a Beetle IRS?
BL3Manx
BL3Manx is offline
PostPosted: Mon Mar 10, 2008 10:37 pm    Post subject: Reply with quote
Yes but your stub axles need to have bus CV size flanges.
Page 39 and 40 on here:
http://books.google.com/books?id=XJQFGmUhGlEC&...n#PPA39,M1
BL3Manx
BL3Manx is offline
PostPosted: Mon Mar 10, 2008 11:12 pm    Post subject: Reply with quote
Just about all the new cars have aerodynamic acrylic head light covers now. I think those old sealed beam type headlight requirements have been modified or rescinded with the new headlights they have now.
http://www.infiniti.com/g_sedan/index.html?dcp=23875959;&dcc=0;&dcn=1
didget69
didget69 is offline
PostPosted: Tue Mar 11, 2008 10:04 pm    Post subject: Re: Karmann Ghia Chassis OK Reply with quote
Vanagon trans or Corvair trans won't fit Beetle chassis without lots of work... if you haven't tackled a Corvair swap into VW before, it's probably best to stay with VW power. To build the Corvair into a hp powerplant would cost more than building up a good performance Type 1 motor.
As for the headlight covers - covering the sealed beam headlights with any covers are illegal in most states under DOT/NHTSA/etc., regs - Newer cars that have aerodynamic headlights are a world of difference from what the Aztec had - the aero headlights on new cars were designed & approved by Federal Motor Vehicle Safety Standards (FMVSS) from the
day the designers first developed them.
That being said, regulations vary from state to state regarding the use of
covers on older headlight setups, like on the Aztec. In MOST states, any type of headlight (or Taillight) covers are illegal for highway use, whether clear or tinted, period. All you need is a LEO to pull you over & cite some law in the books regarding headlight covers & then write you up...
bnc
Faust
Faust is offline
PostPosted: Tue Mar 11, 2008 10:23 pm    Post subject: Re: Karmann Ghia Chassis OK Reply with quote
bnc
As with all regulations, I wonder if the cause for their promulgation was real, or imagined. I don't recall any urban myths of people being cut to ribbons by the headlight covers of an XK-E. Possibly it was the "global warming" of it's day. Perhaps it was like the prostitution frenzy around 1915 that gave us the Mann Act, in more than 80 years, there have been less than 20 people charged under it.
I do notice the covers are available aftermarket for the early Datsun Z-cars.
I can readily imagine an LEO deciding I needed a night in the slam.
BL3Manx
BL3Manx is offline
PostPosted: Tue Mar 11, 2008 10:44 pm    Post subject: Re: Karmann Ghia Chassis OK Reply with quote
didget69 wrote:
[Vanagon trans or Corvair trans won't fit Beetle chassis without lots of work... if you haven't tackled a Corvair swap into VW before, it's probably best to stay with VW power. To build the Corvair into a hp powerplant would cost more than building up a good performance Type 1 motor.
bnc
The Corvair is definitely not common or easy engine choice for a buggy anymore. If you're not confident in your design or fabrication skills its probably best to pass it up. However, there's definitely a cool American Iron factor about it hanging out the back of your buggy, and 2.7L and 140, 150 or 180 horsepower from a stock aircooled engine is pretty attractive.
Totally agree that they cost over twice what a Type 1 performance engine would cost to build. But sometimes a deal like this comes along.
http://www.thesamba.com/vw/classifieds/detail.php?id=581558
Not sure at all about other states but I've looked through the California vehicle code before and never could find any restriction about clear covers over your headlights.
http://www.dmv.ca.gov/pubs/vctop/vc/tocd12c2a2.htm
HeidelbergJohn4.0
HeidelbergJohn4.0 is offline
PostPosted: Thu Mar 13, 2008 8:14 pm    Post subject: Re: Karmann Ghia Chassis OK Reply with quote
bnc
funny you mention those. i saw a nice 260 with them today at a gas station near my office.
71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.)
