Rotisserie
Page: 1, 2, 3 ... 11, 12, 13  Next
MICHANICAL™
MICHANICAL™ is offline
PostPosted: Thu Jun 01, 2006 8:37 pm    Post subject: Rotisserie Reply with quote
Build @ your own risk. I Michael Allen of the Studio 3 Project, assume zero responsibility to these plans, rotisserie and all person's using them. I have donated my ideas and time for free to aid in the restoration of projects. Please apply common sense when building this contraption, and Safety first!
I built this from $50. in scrap materials. I estimate new material cost @ $300. This design was ideal for transporting use. Other rotisseries may be more appropriate for in place rotation. My design is simple and builder friendly. Take your time and study the plans. You will need a welder, welding mask, 1/2 drill, 1/2 inch drill bit, chop saw or cutting devise, tape measure, thick leather gloves, safety goggles and possibly a calculator.
Step one: Build a 30 degree jig out of 2 x 2 angle iron; Weld the two 23 inch angle iron sections (long point to long point) with 15 degree cuts @ a perfect 30 degree angle. To verify true degree reference length of A sq. + B sq. = C squared.
Step two: Cut your 0.23622047 decimal inch wall thickness 2" x 2" tubing @ 15 degree cuts to length. Mark all lengths, 21 inches and 23 inches. (Please see foot note). Pair the correct to plans sections in two, double check and make minor adjustments if needed. Break the rotisserie into a top and bottom, each should share parallels angles and one side. Using Jig, weld pairs, then weld pairs together. Now you have a complete multigon making a 360 degree circle, I.E. 12 30 degree angles make 360 degree multigon. Repeat this step for second multigon.
Step three: Cut your multigon "B" to a top and bottom, note location to plans. Insert "b" solid stock in bottom half and weld in place @ all four locations. Slide top half of multigon back in place and drill out a hole for a holding pin. Remove top half.
Step four: Weld "A" in place. Note "a" (receives a 2 inch x 2 inch tubing)
Step five: Make your mounting bracket arms and plates. Mount the plate's (flat 1/2" steel plate) in place  on your vehicle, and get ready for some muscle work. Slide the arms in place on the multigon. Raise the vehicle to center point of gravity. Raise the bottom half multigon with all in place, steady the bottom half w/ tack welded temporary stabilizer. Weld the arms "C & D" to the 1/2 plate that is bolted on your bus. Note: the bracket arms should be removable from the "A" pockets. Note: "c & d" were designed for barndoor bus, when building rotisserie for non barndoor; mount plates in place and correct the dimension width on arms prior to welding. Allow 1/2 inch of total play.
Step six: Build a safety bar. See jpg. This is very important. You don't want the bus rolling back on your ass or squashing your precious hands! Please note safety bar jpg. Use this bar.
Step seven: Lift the top half's of the multigon's in place and safety pin. Roll that bus over, safety bar the position and fix that nasty rust to factory standards. If its worth doing, do it right!
Foot note: 21 and 23 inch length's can all be changed to 23 inches. This will simplify the layout but make the overall height taller and you should consider the height of your garage opening prior to making this change.
Michael Allen
www.theStudio3Project.com
Rotisserie #2
Plans by sgellis later in this thread.
Post with photos:
http://www.thesamba.com/vw/forum/viewtopic.php?p=8252247#8252247
Link to PDF:
http://www.thesamba.com/vw/archives/manuals/bus_rotisserie/VWBus_Rotisserie.pdf
Rotisserie #3
By user aeLiXihr
Post with photos:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8941620#8941620
DXF Autocad file:
https://www.thesamba.com/vw/archives/manuals/bus_rotisserie/kantelraam.dxf
combiwagon1969
combiwagon1969 is offline
PostPosted: Wed Jun 27, 2007 1:32 am    Post subject: the vw Rotisserie Reply with quote
Hi. first of all I have to say MUCH RESPECT for this one.
First class, really. Now, do you have any more pictures, dimensions etc. the info that you have given, while good, is a bit hard to follow so any extra pics and stuff would be handy.
Bugs'n'Pugs
Bugs'n'Pugs is offline
PostPosted: Tue Mar 25, 2008 8:47 am    Post subject: Reply with quote
Would something similar to this work on a Beetle or a Super Beetle?
1978 Super Beetle Convertible (Project)
Post a Photo in the Forums
Rescue Man's Best Friend
thom
thom is offline
PostPosted: Tue Mar 25, 2008 9:26 am    Post subject: Reply with quote
In theory, yes. Just make the whole thing smaller, and change the mounting points accordingly.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
The Sage
The Sage is offline
PostPosted: Tue Mar 25, 2008 9:33 am    Post subject: Reply with quote
Russ and I were discussing this, the mounting points would be very similar..
You could make an adjustable version to use on both models, but honestly, with the pan / body of a bug, you really don't need this.
Feel My Pain l Sage Ad World
Volksparts
Volksparts is offline
PostPosted: Tue Mar 25, 2008 9:39 am    Post subject: Reply with quote
Maybe I am easily impressed but that is one of the coolest things I have ever seen. Thanks for posting the schematics.
NOS PARTS
NOS PARTS is offline
PostPosted: Tue Mar 25, 2008 12:06 pm    Post subject: Reply with quote
here some interesting ones;
this last 1 I like more!
View user's profile Send private message Send e-mail AIM Address MSN Messenger Gallery Classifieds Feedback
crukab
Samba Chef
crukab is offline
PostPosted: Tue Mar 25, 2008 12:28 pm    Post subject: Reply with quote
Hey, thats my truck ! Very Happy
Here is a shot of the plates & arms I made to attach to the front end, you also can see the extra wheels added, to lower the rig down a few inches.
The best part is it works with a 8 foot ceiling, in basicly 1 garage bay.
I like the one that Michael posted, But don't have that much space.
Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon
thom
thom is offline
PostPosted: Tue Mar 25, 2008 1:35 pm    Post subject: Reply with quote
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Tue Mar 25, 2008 1:36 pm    Post subject: Reply with quote
LiquiTilter
http://www.liqui-tilter.com/
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Tue Mar 25, 2008 4:30 pm    Post subject: Reply with quote
this is all bad ass!!! i gotta build one of these
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Tue Mar 25, 2008 4:32 pm    Post subject: Reply with quote
from the looks of it crucab, you bottom needs it Laughing love that vermont salt. mmmm salt crusted crucab Wink
UZI
Platinum FUBU
UZI is offline
PostPosted: Tue Mar 25, 2008 6:20 pm    Post subject: Reply with quote
Extravagant Lifestyle
crukab
Samba Chef
crukab is offline
PostPosted: Thu Mar 27, 2008 8:51 am    Post subject: Reply with quote
UZI wrote:
Is that Jdots Rotisserie ?
Tom
My Pops:
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'11 Jetta Wagon
jeremyrockjock
Samba Towbar Builder
jeremyrockjock is offline
PostPosted: Thu Mar 27, 2008 3:32 pm    Post subject: Reply with quote
I like mine.
Why buy what you can build.
bubblehead
bubblehead is offline
PostPosted: Thu Mar 27, 2008 5:28 pm    Post subject: Reply with quote
Jeremy
Could you post some more detailed pictures of your setup? I've been considering going the engine hoist route for a while. I see those things for sale cheap all the time and its similar to the ready made rotisseries out there.
Crukabs setup is really cool, just more coin than I want to spend. I also like the other one pictured above, with the two 45's that put it at a ninety.
In my opinion probably the cheapest, most effective setup.
Mr. Bubblehead
El Chupa Nibre
Mr. Bubblehead is offline
PostPosted: Thu Mar 27, 2008 6:56 pm    Post subject: Reply with quote
Jeremy are you putting that swingaxle in the bay??!!?
OGST
Samba Member #4862
j.pickens
j.pickens is offline
PostPosted: Thu Mar 27, 2008 9:47 pm    Post subject: Reply with quote
yes
BeaterBarndoor wrote:
Red Fau Veh wrote:
jeremyrockjock
PostPosted: Sat Mar 29, 2008 6:35 pm    Post subject: Reply with quote
LOL the swing axle is for a 67 deluxe belonging to my friend.
The rotisserie is scratch built from old wheelchair lift parts and box tubing. They look like engine stands but are much bigger.
Nic B-C
Nic B-C is offline
PostPosted: Sun Mar 30, 2008 8:20 am    Post subject: Reply with quote
Liking these but always wondered how you lift both ends on a rotiserie to get high enough to roll and also what controls the roll speed.
Any help would be grateful please as got several vehicles here which need chassis sorting plus im considering getting a sandblasting machine as well
Cheers
www.durhamoldschooldubbers.co.uk
Page 1 of 13
