Engine Stand
Page: 1, 2, 3 ... 33, 34, 35  Next
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Apr 03, 2008 10:34 am    Post subject: Engine Stand Reply with quote
using the "El Cheapo" engine stand for years I got tired of it bending and not really able to hold the weight of a complete Type 1 engine let alone a Type 4. I recently saw a ebay auction/ad for better made bracket that can be used either as a bench mount or free standing with the purchase of a generic engine stand. So I decided to buy it and check it out. I also purchased a generic engine stand from Harbor Freight and they fit together well.
The Type 1 stand can be ordered with either a bench mount or an adapter to use a generic stand. The adapter come with 3 welds around it that have to be ground to make it fit. The reason is there are so many different stands and there is no one size fits all. It just took a few seconds with a bench grinder and it fits snugly.
Here's the ebay auction/ad and the total cost was $51 including USPS Priority shipping.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=170204739765
The Harbor Freight stand was the 750lb stand and was $42 delivered.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=32915
Universal engine stand info from another thread:
VOLKSWAGNUT wrote:
I use universal engine stands, 3 legs/wheels.. 4 legs/wheels.. no legs/wheels. .. ..
No requirement for any special VW yoke adapter..as long as you use (have) common sense.
The most important thing to do when using a universal engine stand on a VW air cooled engine, use nice large ( and shaped) washers/plates on the case at the stand to engine case points. It helps disperse the weight.
I prefer to use all 4 case mount bolts/studs until its down to the time to split the case..
Then its light enough to remove 2 of the bolts or 2 stand arms and split the case.
The disadvantage .. is the flywheel bolt access.
For most universal stands the flywheel must be removed before mounting on a stand.
A VW adapter.. is limited to VW.. but does make the flywheel gland bolt easier to access and does make setting end play easier.
I can do without that benefit alone to have a tool I can use for much more.
Sure.. the tripod 3 wheeled ones can be unstable when spinning a complete and wide engine.. So I do prefer 4 wheels "H" pattern or "I" pattern stands.
Plus the universal ones are mostly limitless what can be mounted, rolled around and worked on...
Moderator note:
Please post all home-made or other engine stands in this thread
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
TailTip
TailTip is offline
PostPosted: Thu Apr 03, 2008 10:39 am    Post subject: Reply with quote
Great idea. Idea
tspot100
tspot100 is offline
PostPosted: Thu Apr 03, 2008 10:52 am    Post subject: stand Reply with quote
did the same thing a few years ago when i built the motor for my 68. works great. didn't care for my old bench mount.
Budes45
Budes45 is offline
PostPosted: Thu Apr 03, 2008 11:47 am    Post subject: Reply with quote
For a few bucks more I went for this stand much more stable.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=32916
I wish I saw that atachement a few years ago when I fabed my own.
Mr. 010
Glenn is offline
PostPosted: Thu Apr 03, 2008 11:53 am    Post subject: Reply with quote
I looked at the 1000lb stand and just didn't see the need to spend more. This stand can easily hold the 250lb Type 1 engine and not tip over.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
veedubcrazy
veedubcrazy is offline
I got the same set-up. Bought it from a consumers club outta Virginia Beach when stationed there. The brand was Larin. It was heavy duty enough to hold a 500 c.i. Caddy motor. It had the additional brace to keep it from bending. And using the traditional engine brace for a VW engine makes it nice to work with...
1967 Deluxe Sedan
1971 Squareback - "The Silver Surfer"
turboblue
turboblue is offline
PostPosted: Thu Apr 03, 2008 12:37 pm    Post subject: Reply with quote
4 wheeled stand is much more stable with a turn key engine on it that the 3 wheeled version.
Nearly dumped a complete engine on the 3 wheeled stand one time.
Was moving it and the front wheel hit an expansion joint in the floor.
Welded a T on the end and installed 2 casters in the front, much better.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
joescoolcustoms
joescoolcustoms is offline
PostPosted: Thu Apr 03, 2008 12:44 pm    Post subject: Reply with quote
Glenn:
Do you have a picture of your old stand? Just courious.
I bought a cheap bench mount stand, mounted it to my bench and then found a scrap peice of tubing that fit the bench part and welded a gland nut to it and now use that part to hold a crank for asy.
I slightly modified the head to go into one of my V8 stands just like everyone else.
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Mr. 010
Glenn is offline
The main thing is not the actual stand, but the VW mount. It's really well made and you can use whatever stand you like.
What I do like about the Harbor Freight stand, there's one bolt that holds it together. Remove the bolt and it knocks down to 3 parts that's easily stored under the work bench.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
jspbtown
jspbtown is offline
PostPosted: Thu Apr 03, 2008 12:48 pm    Post subject: Reply with quote
I have basically the same stand. Almost did roll over my fully dressed engine once. I was surprised how quickly it happened. I was wheeling at around at the time. That being said...it was plenty stable when working on it, just not so much when moving it. I am going to add the extra "out riggers" when I have time
dwayne prince
dwayne prince is offline
PostPosted: Thu Apr 03, 2008 1:42 pm    Post subject: Reply with quote
while the three wheel stand will hold a type 1 with no problem,just be careful.i have one that i've used alot.all it takes is one time and something will be screwed up.the door on my ghia will testify to that one
Mr. 010
Glenn is offline
PostPosted: Thu Apr 03, 2008 1:47 pm    Post subject: Reply with quote
Personally I think it is foolish to have a complete engine still on the stand and then try to roll it around.
Once the engine is done... take it off and put it on a dolly.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
DSTMULE
DSTMULE is offline
PostPosted: Thu Apr 03, 2008 3:14 pm    Post subject: Reply with quote
Glenn....Have enough stuff crammed in that Garage? Kinda like mine, I'm lucky to recall what / where i have it all...I usually buy a new one and then find the one i bought years ago just in case i needed that.
slowtwitch
slowtwitch is offline
PostPosted: Thu Apr 03, 2008 3:40 pm    Post subject: Reply with quote
I went with a VW Alley stand , also.. I went with their T4 stand...
looking at their type 1 stand, I probably could've used it on my type 4 build. Very stout stands
pete
Mr. 010
Glenn is offline
PostPosted: Thu Apr 03, 2008 3:43 pm    Post subject: Reply with quote
slowtwitch wrote:
I went with a VW Alley stand...
pete
That's who made the VW Type 1 mount I have.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
turboblue
PostPosted: Thu Apr 03, 2008 4:03 pm    Post subject: Reply with quote
I didn't know it was tipsy until I tried to move it.
Those three legged stands are an accident waiting to happen IMHO.
Gary
Mr. 010
Glenn is offline
PostPosted: Thu Apr 03, 2008 4:06 pm    Post subject: Reply with quote
My point of posting was the excellent VW mount that will fit any generic stand, be it 3 or 4 legged.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
boos-k_nb
boos-k_nb is offline
PostPosted: Thu Apr 03, 2008 4:43 pm    Post subject: Reply with quote
And how you put 2 known heavy duty products together and have a rebuild stand under 100$ without re-manufacturing or doing mods on your own. I think thats the point with links listed.
Dropping an engine is because you never asked for help when you needed it. I'll never transfer an eng again without help Embarassed 2 person job.
Mr. 010
Glenn is offline
PostPosted: Thu Apr 03, 2008 4:45 pm    Post subject: Reply with quote
EGGzactly.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
dwayne prince
PostPosted: Thu Apr 03, 2008 4:50 pm    Post subject: Reply with quote
and its a fine piece,andyour point is well taken.
Page 1 of 35
