Texxxxx Samba Member
Joined: January 28, 2008 Posts: 452 Location: Monterey, CA
Posted: Tue Apr 08, 2008 8:52 am Post subject: Cutting Swivel Base |
I'm planning to install my swivel bases soon, and I plan to use 10cent's method of bolting them in.
http://www.thesamba.com/vw/forum/viewtopic.php?t=238428&highlight=swivel+base
I want to get a bit more leg room, still see the top of the gauges and make it easier to rotate the driver's seat, so I am thinking about cutting the rear battery holder off the swivel, and bolting it down about an inch and a half back:
I don't think this will make it any weaker... does anyone else see a problem?
(That's not my swivel...stole pic from forums) Thx- _________________ '85 GL w/2.1L "The Tardis" |
Waldemar Sikorski Samba Member
Posted: Tue Apr 08, 2008 1:54 pm Post subject: |
| It will. |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10164 Location: Abiquiu, NM, USA
Posted: Tue Apr 08, 2008 2:47 pm Post subject: |
I can't see why that wouldn't work. Even one inch would get you enough clearance from the steering wheel to swivel the driver's seat more easily. I see yours is a passenger van, so no problem with the cabinet just behind the seat which apparently makes a driver's side swivel in a Westy pretty useless. You'll need to fabricate some kind of alternative battery hold-down if you ever install an aux battery, and of course your battery box covers will have to be shortened. If you never want to put a battery in there, you might not even have to shorten the plate anyway.
There will be a small loss of strength in the plate from removing the bent edge and groove that is formed into the panel, but the bases are such heavy steel I can't see that being a problem unless you are particularly heavy. Cutting the plate a bit longer than you intend, and bending down the edge of the plate all the way across would restore that strength. Or you could weld on a length of steel angle to span for the same result. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
At birth you only know how to suck. Spend the rest your life learning how not to. |
Posted: Tue Apr 08, 2008 4:57 pm Post subject: |
Thx for the input, guys.
10c-I'm pretty frikkin' heavy...lol... 6'1", 230. I already have purchased an Odyssey battery for under the driver's seat. Just waiting to get the swivels taken care of before I wire that and the Yandina in.
If I just take the scoopy battery holder off, I'll lose only about 1/2"..if I cut it on the battery side of the groove...3/4".
I have the time tomorrow, so something will come off...lol. _________________ '85 GL w/2.1L "The Tardis" |
goffoz Samba Member
Posted: Tue Apr 08, 2008 6:10 pm Post subject: |
My swivel doesn't have that piece?
I cut it out of an 86 |
Posted: Wed Apr 09, 2008 5:41 pm Post subject: |
I went conservative with my cut...battery side of the groove...used a bandsaw with a metal cutting blade.
I hope to put the driver's side in this weekend...I'll post back to let anyone interested know if the 3/4" helps in swiveling a full-size vanagon seat. _________________ '85 GL w/2.1L "The Tardis" |
Posted: Thu Apr 10, 2008 7:07 pm Post subject: |
Today I cut the tab(s) that prevents the swivel base(s) from lying flat
and discovered that I got very lucky. The base, with the back cut off, clears the Odyssey battery, on it's side, totally....by maybe a 1/16".
I'll be able to move the driver's seat back a couple inches if I want to. I can mount the Odyssey backwards (terminals toward rear) and still have access to the terminals, but will have to remove the swivel base to remove the battery. The main battery is too high to do the same to the passenger seat, and I'm not buying another Odyssey...lol.
One drawback..the driver's seatplate will hit the seatbelt anchor rotating right to the inside. I'll have to be out of the seat and rotate it left towards the door to do a 180. Or change the seatbelt anchor. _________________ '85 GL w/2.1L "The Tardis" |
Posted: Sun Apr 13, 2008 2:32 pm Post subject: |
I decided to use 6 M8 bolts instead of the 4 M6's that 10cent used on each base. I also didn't need to use the JB Weld. I tried, but wasn't patient and then realized with the battery holder cut off I could hold them in place after using 10cent's 'long bolt' trick.
Don't use the flanged ones like I did...They are too high and hit the lip and the cone shaped part of the swiveling part.
I re-did them with flangeless M8's...just clears it.
The 2 inches that I gained from cutting the battery holder paid off. Rotating is easy...lots of legroom...still plenty of headroom. The steering wheel does cut a bit off the top of the speedo and tach. Not bad, though.
I still need to cut down and re-rivet the battery covers.
Next Project will be installing Odyssey aux battery, Yandina battery combiner and Blue Sea fuse block.
Thx, 10cent, for showing me how to bolt them in. Big help! _________________ '85 GL w/2.1L "The Tardis" |
Posted: Sun Apr 13, 2008 3:00 pm Post subject: |
Hey, Texxxxxxxx, good job!
I thought a lot about the number and size of the fasteners, and what kind of strength was needed, until I realised that it's the seat belts that hold the person, and the seat, from flying out of the car in a crash. And that the seat weighs a fraction of the weight of an adult.
Notice that the belts are anchored with big, high-grade fasteners. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Posted: Sun Apr 13, 2008 3:57 pm Post subject: |
| tencentlife wrote: |
Notice that the belts are anchored with big, high-grade fasteners. |
I didn't think of it that way, but now that you mention it, it makes sense. _________________ '85 GL w/2.1L "The Tardis" |
foodeater Samba Member
Joined: July 13, 2007 Posts: 1318 Location: Newburgh, NY
Posted: Mon Apr 14, 2008 10:37 am Post subject: |
| I thought a lot about the number and size of the fasteners, and what kind of strength was needed, until I realised that it's the seat belts that hold the person, and the seat, from flying out of the car in a crash. And that the seat weighs a fraction of the weight of an adult. |
What about a rear end collision where the energy of the collision would be transferred towards the rear of the van? wouldnt the strength of the bolts used to mount the seat come into play then? When I crashed my syncro the seat got deformed quite a bit (it was a front end collision though).
Just a thought. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP |
Posted: Mon Apr 14, 2008 10:53 am Post subject: |
Yup, it sure would. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
