How To Remove Your Late Westy Interior (Pics) FAQ
Page: 1, 2, 3, 4  Next
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sat Apr 19, 2008 10:17 pm    Post subject: How To Remove Your Late Westy Interior (Pics) FAQ Reply with quote
To link to this thread
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=291736&start=0&postdays=0&postorder=asc&highlight=]How To Remove Your Late Westy Interior (Pics) FAQ[/url]
Hello all,
This is meant to be a step-by-step tutorial for removing your Late Bay Westy interior.
**Make sure to bag and label things as you remove them**
Hope it helps!
The starting point:
Step one...empty the cabinets! Duh!
I start with the sink/stove cabinet. Remove the doors; they just slide up off the hinges.
Take out the two shelves. Angle them upwards until they have enough clearance. I also take out the p-trap from the pipes; it allows for more shelf clearance. The p-trap unscrews by hand.
Now remove the "plumbing cover". It just pulls away.
It should now look something like this. (I have a lot of extra cables running through here)
Now remove these two bolts (in the lower left of the cabinet), and remove the cover from the sink pump area.
Pull the water tank drain pipe up into the cabinet.
Slide your driver's seat forward and remove these two bolts:
Note that one is longer then the other - label them.
Time to get a little dirty! Crawl under the bus and find the end of the sink drain pipe. There should be a cap screwed onto the end (I don't have one). Unscrew the pipe retaining ring, and remove the two screws to the left to remove the metal plate.
Remove the second plate by removing the 3 screws.
Back inside, remove the metal catch from the spare tire cabinet. This step is really optional, but I like to take it off so I dont break anything.
Disconnect the water line from the water inlet, and the propane line from the coupling in the floor.
Back outside, remove the sink vent cover:
...and the rubber gasket:
Inside, lean the cabinet forward and disconnect the sink pump ground wire:
Now, still with the cabinet leaning forward a bit, remove the plumbing. It takes a lot of wiggling around, but it will come out.
Thats it for this cabinet. Just take it out!
Next is the side cabinet next to the back seat.
Lift up your Westy bed and remove this bolt on the right side:
This is the drain pipe for the icebox (fridge if you have one). Go under the bus and push it up into the icebox/fridge. I tap it gently with a rubber mallet.
Slide the cabinet forward a bit, and reach into the rear section and make sure the wiring stays behind.
Now just slide the cabinet forward and remove it!
Time to take out the rear seat!
Remove the cover from the electric box by removing these screws:
Disconnect the box by removing the bolts/nuts from the base:
Now remove the main seat bolts:
Remove the heat directing plate:
Remove the ring (probably optional)
This is what you have left:
On the left hand side of the seat, you see this near the top. Remove these 2 small nuts:
This is what is on the back side, in the rear passenger side wheel well:
Here it is removed:
Open your rear hatch, take out the pad and remove these two screws:
Close-up
Now lift up the seat so it clears the floor vent and remove. Note the electric box (or whatever it is actaully called) is still in the bus.
Time to take out the 'head-knocker' upper cabinet.
This pic was taken laying down, looking up on the passenger side. Remove these 2 screws. NOTE: have a friend around so this cabinet doesnt fall on you!
Open the cabinet and remove this nut:
NOTE: There is one more nut to remove just to the rear of this one on the ceiling which needs to be removed, I just forgot to photograph it I guess. Sorry.
Thats it for that cabinet. Hope it didnt fall on you!
Now the side cabinet (You're almost done!)
Remove these brackets:
Standing outside the bus, looking in the rear hatch; remove these screws:
Thats pretty much it. Angle it to the center of the bus and slide it out.
Hey look! You're done!!
Here are the only tools you need to do the job:
Sockets: 8mm, 10mm, 13mm, 17mm
Ratchet with various extensions
Screwdrivers: #1,2,3 Phillips, #2 slotted
Open/Box Wrenches: 10mm, 19mm
Rubber Mallet
Thats all you need.
I hope this thread helps anyone who is looking to remove their Westy interior!
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
elstrom
elstrom is offline
PostPosted: Sat Apr 19, 2008 10:27 pm    Post subject: Reply with quote
That's awesome! Thanks for the preemptive assistance.
'78 Landmark Conversion/Westy "Buster"
Mark
Mark is offline
PostPosted: Sat Apr 19, 2008 10:38 pm    Post subject: Reply with quote
Nice work, thanks for documenting this job!
www.zwerks.ca
calebmelvin
calebmelvin is offline
PostPosted: Sat Apr 19, 2008 11:02 pm    Post subject: Reply with quote
This should be a sticky!
Caleb
'68 Tagged Manx | My Wanted Ads
79westy
79westy is offline
PostPosted: Sat Apr 19, 2008 11:06 pm    Post subject: Reply with quote
Awesome tutorial and awesome looking interior. Why did you take it out?
"The bus came by and I got on, that's when it all began."
grigley
grigley is offline
PostPosted: Sat Apr 19, 2008 11:08 pm    Post subject: Reply with quote
nice work, but I have to ask... why are you doing it? Looked really nice asis.
78 westy
76 transporter
89 Tristar Doka
calebmelvin
PostPosted: Sat Apr 19, 2008 11:19 pm    Post subject: Reply with quote
See here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=282597
Caleb
VDubTech
VDubTech is offline
PostPosted: Sun Apr 20, 2008 5:12 am    Post subject: Reply with quote
Good post, but I Work in a different order. I always remove the bed first,then the frisge cabinet slides right out, then the sink/stove and finally the two in the back. Either way, nice documentation.
jmstu76
jmstu76 is offline
PostPosted: Sun Apr 20, 2008 6:48 am    Post subject: Reply with quote
How much time would this normally take, if you weren't documenting?
James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger Instagram Gallery Classifieds Feedback
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Apr 20, 2008 8:47 am    Post subject: Reply with quote
If I wasnt documenting the procedure, it would take at most 1 1/2 hours. Of course, I've done it a couple times.
Eric
'79jw
'79jw is offline
PostPosted: Sun Apr 20, 2008 12:09 pm    Post subject: Reply with quote
Applause
'79 westy
'74 trans
gmag69
Type2 Nutcase
gmag69 is offline
PostPosted: Sun Apr 20, 2008 12:42 pm    Post subject: Reply with quote
Thanks Eric now I know what to do when I put in my interior. Very Happy
Check out my Westy resto. thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=230285
Rocknrod
Rocknrod is offline
PostPosted: Sun Apr 20, 2008 7:12 pm    Post subject: Reply with quote
Good stuff!
Thanks... and I don't even have a late westy. Laughing
1971 Westfalia with a high top.
http://71vwbus.blogspot.com/ - Pictures and words... Oh My!
jmstu76
jmstu76 is offline
PostPosted: Sun Apr 20, 2008 7:17 pm    Post subject: Reply with quote
I really appreciate this thread. I have been insulating my bus and it is time to insulate behind the westy interior. I removed my sink and fridge today. It was so easy. Another mystery that turned out to be simple. Again, thanks for the pics.
James
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Apr 20, 2008 7:49 pm    Post subject: Reply with quote
Glad I could help!
Eric
MOX
MOX is offline
PostPosted: Mon Apr 21, 2008 10:12 am    Post subject: Reply with quote
can you throw up a pic of the bus with only the sink section removed? if you have one.
i have been thinking of making a bench the same height and width of the cooler that would run right up to the back of the drivers seat because i never use my sink. it would give me lots of storage space too, like a giant toy box!
Randy in Maine
Randy in Maine is offline
PostPosted: Mon Apr 21, 2008 11:22 am    Post subject: Reply with quote
Very helpful Eric!
I will be doing that shortly for the in and out painting.
How about the dash?
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Mon Apr 21, 2008 11:26 am    Post subject: Reply with quote
I have this pic from a few years ago, if it helps...
Eric
MOX
MOX is offline
PostPosted: Mon Apr 21, 2008 11:31 am    Post subject: Reply with quote
OHHHH, i like the looks of all that space!!!!!!!!!!! thanks !!
1979VWWestyCamper
1979VWWestyCamper is offline
PostPosted: Thu May 01, 2008 12:20 pm    Post subject: Nice, now where do you get the wheel covers? Reply with quote
That's what I just did... just got done sound deadening and painting the inside. Will be helpful for when I go to put things together...
Question: What material (or better, where do you get it) goes under the seats in front, or what covers those wheel wells (on the interior)? My bus didn't come with any thing and I can't seem to find where to get it.
Page 1 of 4
