Texxxxx Samba Member
Joined: January 28, 2008 Posts: 448 Location: Monterey, CA
Posted: Fri May 16, 2008 6:03 pm Post subject: 12V Ashtray Outlet |
I would guess this has been done before, but I haven't seen it. I used the ashtray behind the drivers seat to mount a 12V outlet from my aux bat. I plan to run one to the ashtray beside the sliding door also.
I had bought some of these:
http://www.delcity.net/delcity/servlet/catalog?parentid=789160&page=1
just the recepticle. 1 1/8" holesaw...
It's a little tight in there...
Power for the Coleman Powerchill...
[/url] _________________ '85 GL w/2.1L "The Tardis"
It's A Vanagon Day |
Lanval Samba Member
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
Posted: Sat May 17, 2008 4:01 pm Post subject: |
Texxxxx,
AWESOME IDEA!!!! I have been looking for a place to stick outlets. I never thought of using the ashtrays! Then, I got to thinking......
Thanks for the inspiration!
_________________ '69 Mike
'85 GL
'87 Wolfsburg Hardtop |
1621 Samba Member
Posted: Sat May 17, 2008 4:24 pm Post subject: |
Great ideas. I've been thinking lately about running a 12v outlet under the dashboard, just above the glove box. That way I can run power to a GPS, cell phone, or whatever gadget comes along without having the wire in the loose fitting cig lighter. Then simply pull the GPS off the windshield and toss in the glove box. No need to unplug. Just thinking about it right now. _________________ '85 Westy |
CoastieLFS Samba Member
Posted: Sat Jun 20, 2020 7:09 pm Post subject: Re: 12V Ashtray Outlet |
How the heck did you get the ashtray chasis out? Not the inner tray, that's easy, but the ashtray itself. I tried gently raising the two tabs at the bottom, but it didn't budge. Wondering if it's also glued on? _________________ '95 Eurovan Camper (2.5L)
'01 Weekender (Colorado Red)
'03 Weekender (Emerald Green)
Portland, OR |
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Sun Jun 21, 2020 7:57 am Post subject: Re: 12V Ashtray Outlet |
CoastieLFS wrote: |
How the heck did you get the ashtray chasis out? Not the inner tray, that's easy, but the ashtray itself. I tried gently raising the two tabs at the bottom, but it didn't budge. Wondering if it's also glued on? |
Mine was tough but it did pop out.
No glue on my 87 or 81.
Picture links broken?
No voila! For me
Owen _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
CessnaJon Samba Member
Joined: August 15, 2008 Posts: 679 Location: Senoia,GA
Posted: Sun Jun 21, 2020 8:17 am Post subject: Re: 12V Ashtray Outlet |
Looks good. Here is my creation.
_________________ 1973 Westy (shared birthday)
1990 Westy Multivan
2015 Passat TDI 6sp
2015 Sportwagon TDI 6sp
LR-JET, Gulfstream 159 |
weekendr Samba Member
Joined: August 18, 2021 Posts: 64 Location: Halifax NS Canada
Posted: Thu Mar 10, 2022 10:01 am Post subject: Re: 12V Ashtray Outlet |
CoastieLFS wrote: |
I got mine out no problem, but I can't get it back in. My van has a galvanized metal clip/spring behind the ashtray chassis which sits loose and fell down inside the interior panel. I fished it out but am having trouble with reinstallation. Any advice on how to keep the clip in place in order to replace the ashtray frame without removing the entire van interior? _________________ Early 1986 Wolfsburg Westy Weekender 2WD GL manual with KEP EJ22 |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 1186 Location: PNW — Washington
Posted: Thu Mar 10, 2022 10:46 am Post subject: |
1621 wrote: |
Great ideas. I've been thinking lately about running a 12v outlet under the dashboard, just above the glove box. That way I can run power to a GPS, cell phone, or whatever gadget comes along without having the wire in the loose fitting cig lighter. Then simply pull the GPS off the windshield and toss in the glove box. No need to unplug. Just thinking about it right now. |
For what it’s worth, I ran the 12v power supply cord from my GPS under the edge of the instrument cover and down behind the lower dash cover where it comes up to my aux power socket.
_________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic) |
