mork Samba Member
Joined: January 06, 2006 Posts: 181 Location: blacksburg
Posted: Sun May 18, 2008 2:08 pm Post subject: Dual battery diagram missing |
Hiya!
I'm trying to rewire my aux battery after switching busses and I don't remember where the wires go. I've searched the history and I get great results except that the wiring diagram is missing and a question mark box is all that appears. Has the link changed? I have the kit from bus depot but I'm pretty sure they're all mostly the same. Did I have a fuse inline previously and where? Any help is so much appreciated!
<3 becky _________________ What is larger than a mouse? Das Haus! What is smaller then a house? Das Haus! |
germansupplyscott Samba Member
Posted: Sun May 18, 2008 3:15 pm Post subject: |
it should be something close to this:
_________________ SL |
jgordon Samba Member
Joined: March 21, 2008 Posts: 162 Location: Cocoa Beach Florida
Posted: Sun May 18, 2008 3:22 pm Post subject: |
Thanks Scott,
i was looking for that myself !!!
WOOT
James |
mork Samba Member
Posted: Mon May 19, 2008 10:02 am Post subject: |
Yay! Thanks Scott, that's exactly what I needed! _________________ What is larger than a mouse? Das Haus! What is smaller then a house? Das Haus! |
BUGSTUFF Samba Member
Joined: October 20, 2004 Posts: 532 Location: Bartlett, IL
Posted: Wed May 21, 2008 3:34 pm Post subject: |
Scott,
Thanks for posting this!!!
My buddy's '74 had all the wiring in the engine compartment but it looked like spaghetti. The relay was intact and everything (except one wire) was still connected to the relay. Used the diagram and got everything connected and working again. Just in time for our Rt. 66 Bus caravan next month. His wife is excited that the fridge and the sink will be operational. Yay! _________________ Kirk
Northeast IL VW Association - www.nivaclub.org
www.facebook.com/nivaclub
Volkswagen Club of America - www.vwclub.org |
BONANZA STEVE Samba Member
Joined: August 24, 2007 Posts: 158 Location: Bonanza Oregon
Posted: Wed May 21, 2008 3:40 pm Post subject: |
Does anybody have for early Bay? 68 to 71? _________________ He who flips me off while passing me in my Bus is not a friend. He who stops to help push my Bus is a friend for life.
1. 1969 Bay Weekender
1 1973 412 Wgn
1 1967 Ford Fairlane Ranchero |
NOVA Bus Samba Member
Joined: April 18, 2005 Posts: 517 Location: Herndon, VA
Posted: Wed May 21, 2008 4:13 pm Post subject: |
Nice work Scott!  _________________ ********************************
1977 Transporter / Weekender
- GE engine, L-Jetronic w/ hyd. lifters
- Brown Beige plaid P27 Interior (ED)
http:/[url=http://www.vw-mplate.com/mplate-29638.png]Click to view image
Camper Interior donor:
[/URL]/www.vw-mplate.com/mcode.php?lang=EN&id=721 (M-Code for interior). |
Posted: Wed May 21, 2008 7:09 pm Post subject: |
we make one for 68-71 also. it's nearly identical with some very small differences. _________________ SL |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10798 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Apr 12, 2010 1:09 pm Post subject: |
ok, it's time for me to install an accessory battery to run my fridge, and i have what i think will be the correct wiring kit. i am still confused on a couple things:
do i just use a regular braided ground strap for the second battery? in referencing a pic i took of an original second battery in a '79 Westfalia, the ground looks like it is run to another source and is not a braided strap. it's just a wire with a ring terminal at the end, grounding to the body, and a white wire running to the other Westfalia stuff.
i have the stock original fridge for a '74 P27 Westfalia, controls as seen in this pic:
i have also referenced the late bay wiring diagram here:
http://i156.photobucket.com/albums/t17/hazetguy/scan1-1.jpg
http://i156.photobucket.com/albums/t17/hazetguy/scan1001.jpg
the kit i have is a Hella kit. 4RA 003 LGE-141 "Single Relay Kit Battery Or Fridge" which contains this relay: http://www.rallylights.com/detail.aspx?ID=944
from what i have gathered, it is a kit from england.
more info here: http://72.167.58.16/community/showthread.php?t=9
the relay has the same terminals as the one Scott lists above. the Hella instructions leave me confused though. "to ensure satisfactory charging, we recommend that no consumers should be connected to the auxiliary battery during charging". so does this mean i can't have the fridge on 12V power while i am driving and charging the battery? that's the whole reason i want to have a second battery so it can charge while driving, i don't want to have to disconnect the fridge while driving.
also, in looking at Scott's diagram, am i presuming correctly that both batteries get charged while the engine is running?
my objective is to have the second battery only powering the fridge (when not plugged in to shore power), and maybe a small electric 12V fan for air circulation inside the bus, for the second battery to be able to be charged while the engine is running (and also the main battery at the same time too), and for the second battery to be isolated from the rest of the bus electrical system otherwise.
is this the way the system works and i am just misunderstanding it?
will i need some kind of isolator/city control like the 76-79 Westfalias use?
i know this topic gets beat to death, and i've read many other threads, but i am still almost totally confused. i just don't want to burn anything up or damage my existing components. also, if the kit i have is incorrect for this application, i have no problem buying the correct kit.
MrBreeze Samba Hitman
Joined: October 06, 2002 Posts: 5643 Location: Lawn Guyland, Noo Yawk
Posted: Mon Apr 12, 2010 1:12 pm Post subject: |
You ain't got squat, it's in Glenn's garage  _________________ -=Rob
WTB: Bay Shore or Queensboro VW Frames
HBB 1984-2009
RW 1943-2011
ER 1964-2023 |
Posted: Mon Apr 12, 2010 1:29 pm Post subject: |
the hella kit you have is, for all intents and purposes, identical to the original VW wiring. our kit is the same also, only we think it's a bit better than the original because it uses no wire taps into the alternator harness, we have a splitter and associated pigtails.
you bold text above is correct in the way the system is designed to work and the relay you have will accomplish this.
this type of relay charges the house battery slowly due to the small wire gauges used. this is probably why the hella instructions suggest not having the consumer (in your case fridge) turned on while the battery is being charged. the original westy fridge units consume a lot of power and with the fridge running the charging circuit can barely keep up with the fridge draw. _________________ SL |
Posted: Mon Apr 12, 2010 1:46 pm Post subject: |
thanks for the info Scott. i was planning on wiring according to your diagram using the same gauge wiring you specify, not the smaller main wire that come with the kit, and i was in no way going to cut into the wiring harness or use that scary wire tap thing. i was going to make all connections at wire ends with factory splitters and new connectors.
thanks for the charging info, although it bums me out that it is not recommended to use the fridge while charging. this also confuses me too though, because the Westfalia instructions says "the refrigerator should only be operated on battery power while the engine is running, otherwise the battery will soon run down." i'm not trying to argue this point, i am just confused as to how things stay charged/operating when the bus is or is not running. would putting in a 70A alternator help this situation?
i will be installing a deep cycle battery to help with longer "no charge" times. |
hamid Samba Member
Posted: Thu Nov 11, 2010 1:04 pm Post subject: wiring |
HI all
what is the biggest and best auxillary batery I can put on my bus and where do I get it in Southern Cali. thank you in advance for all your help eveyone. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17631 Location: San Diego, California
Posted: Thu Nov 11, 2010 2:01 pm Post subject: Re: wiring |
hamid wrote: |
HI all
Well, the easiest thing would be to get a group 24 deep cycle battery for the drivers side battery tray. If you want to have something with more capacity it's best to buy two 6 volt deep cycle batteries (Golf Cart) and wire them in series so you have 12 volts. In San Diego the place to go would be powerstride http://www.powerstridebattery.com/ _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1414 Location: Cambridge, MA
Posted: Thu Nov 11, 2010 8:56 pm Post subject: |
The Hella instructions are overly conservative. The 5 amp draw from the fridge should not significantly impact the ability of the aux battery to charge. A 70 amp alternator also wouldn't help the situation appreciably. The stock system works fine for most people. Even a 1000 amp alternator won't really charge the battery any faster, the charge curve is pretty much set by the internal resistance of the battery and the voltage setpoint of the voltage regulator.
What can help is getting maximum voltage delivered to the battery, eliminating wiring resistance... that's why things like Scott's ACR help. The ACR is more heavy duty and can use heavier gauge wiring, which will pass more current with less voltage drop. Both the Hella relay and the ACR will fully charge the battery, but the ACR with thicker gauge wiring will get you there a bit faster.
Beyond that, the only thing that could charge the battery any faster is a fancy multi-stage voltage regulator, but they start at $300. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Skipro Samba Member
Joined: June 17, 2010 Posts: 47 Location: Squamish B.C.
Posted: Thu Jan 27, 2011 1:07 pm Post subject: |
Is it possible to charge both batteries at once with an external battery charger simultainiously?
I have taken out the charger under the Z bed, and Marr-ed the connections, so I am unable to charge the aux bat with the "shore power" source.
Wondering if i put the battery charger on the starting battery, and run a hot lead from the starting batt to the trigger post on the aux regulator, simulating a "charging" message from the blue alternator wire. If this would act as the normal charge the alternator would create during normal driving operation?
The battery charger would indicate "charged" when both batteries are topped up.
Question # 2.
I have switched the trigger for the radio to use the door buzzer mod (key inserted into ignition without turning, powers the accessory yellow wire on the radio-saves points).
Would it be detrimental to install a switch containing the + from the aux battery, and the + from the starting battery (maybe a 3 way switch, off, on aux, or on start bat) so the radio main constant power source could be switched from the aux to starting battery?
Has anyone done this? does it seem redundant? _________________ Yosemite Yellow 1975 Westfalia (78 2.0fi) |
Posted: Sat Jan 29, 2011 8:06 am Post subject: |
Skipro:
The solution you describe in #1 would work but you have to connect your hot lead every time and don't forget to disconnect it. If you run a hot lead from the start battery to the relay all the time, you will combine the batteries at all times and also run down your batteries from the relay draw when parked.
The solution to this problem is to replace the stock battery combiner system with a "smart relay" or ACR "automatic charge relay" which will combine the batteries when EITHER battery is being charged. To sources are Blue Sea Systems and Yandina. You can just google them. They do away with the need for a blue alternator sense wire and are a simple, elegant solution.
For Question 2, what I do is simply run my radio off the aux battery at all times. There's no particular reason to ever switch it to the start battery. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Posted: Sat Jan 29, 2011 8:45 am Post subject: |
WhirledTraveller wrote: |
Two sources are Blue Sea Systems and Yandina. You can just google them. They do away with the need for a blue alternator sense wire and are a simple, elegant solution. |
agreed. in my opinion the blue seas ACR is head and shoulders above anything else on the market including the yandina. yandina looks like it was made in someone's garage. _________________ SL |
gatorjos Samba Member
Joined: April 19, 2003 Posts: 406 Location: San Francisco
Posted: Sun Jun 26, 2011 9:09 pm Post subject: |
I just received on of these Hella Camper Relays, and was a little puzzled by the tiny wire gauges for the charging. I think I'm going to swap the blue/red and red out for some 10AWG. Does anyone know how many amps the relay is rated for? I think my fully discharged 115Ah deep-cycle will take whatever the alternator will give it (45A?), so the 16AWG or so of the current wiring is a joke... _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
1972 Ghia cabriolet (full body-off restoration -- stolen after five years of ownership)
2004 Passat 1.8T (manual)
http://21stcenturyhobo.com |
