78 Westy, knob on sliding door
exoticdvm
exoticdvm is offline
PostPosted: Thu May 08, 2008 6:22 pm    Post subject: 78 Westy, knob on sliding door Reply with quote
New 78 Westy owner, learning about all the obscure buttons and knick-knacks in our bus...
What's this doo-dad on the sliding door? (orange arrow pointing at mystery knob)
1978 VW Westfalia
http://www.marcandeliana.com
gutted
gutted is offline
PostPosted: Thu May 08, 2008 6:33 pm    Post subject: Reply with quote
I believe someone asked this yesterday. There should be a second handle at the back of the door to help close it from the inside without slamming the door.
exoticdvm
PostPosted: Thu May 08, 2008 6:38 pm    Post subject: Reply with quote
Any companies selling this inside sliding door handle?
Anyone have any photos of what it's supposed to look like?
1978 VW Westfalia
Karl
Karl is offline
PostPosted: Thu May 08, 2008 6:41 pm    Post subject: Reply with quote
Same as the front handle but it does not move. It is a helper handle.
Remove the screw from what you have left and sh!tcan the piece on the square shaft. It was part of the old handle.
http://www.busdepot.com/details.jsp?partnumber=211843642A
exoticdvm
PostPosted: Thu May 08, 2008 6:45 pm    Post subject: Reply with quote
Perfect. Thanks Karl!
1978 VW Westfalia
exoticdvm
PostPosted: Thu May 22, 2008 6:07 pm    Post subject: Reply with quote
So I tried removing that metal knobby part of the old sliding door upper right handle bracket, and I busted the entire bracket. The rectangular piece (that the handle fits into) broke off the rest of the bracket. Anyone know where I can buy this small metal bracket that is bolted on to the door and holds the handle in this location? (see my original pic with arrow). Thanks.
1978 VW Westfalia
NASkeet
NASkeet is offline
PostPosted: Fri May 23, 2008 9:19 am    Post subject: 78 Westy, knob on sliding door Reply with quote
I have yet to see one on a British specification, 1968~79 VW Type 2 and I don't think they were especially common in North America!
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
hazetguy
hazetguy is offline
PostPosted: Fri May 23, 2008 9:30 am    Post subject: Reply with quote
my 74 Westfalia has one that i want to put a handle on.
NASkeet
NASkeet is offline
PostPosted: Sat May 24, 2008 5:50 am    Post subject: 78 Westy, knob on sliding door Reply with quote
From what I know of those helper-handle brackets, the square post with the M5 pre-threaded hole, is angled slightly towards either the front or the rear of the sliding door. Which direction of tilt is the correct one?
To which 1968~79 VW Type 2 models and model years, were these helper handles fitted and in which countries? From what I have read, they seem to be associated with Westfalia campervans, but noting that they imcluded in the official 1968~79 VW Type 2 Replacement Parts Catalogue & Microfiche, I wonder whether they might have featured on other models as well!?!
Regards.
Nigel A. Skeet
Karl
Karl is offline
PostPosted: Sat May 24, 2008 9:24 am    Post subject: Reply with quote
If it is tilted, it is bent. New, it was straight. I will dig out an extra and take a pic of it..... Ok, found one:
hazetguy
hazetguy is offline
PostPosted: Mon Jun 02, 2008 6:04 am    Post subject: Reply with quote
edited
otiswesty
otiswesty is offline
PostPosted: Mon Jun 02, 2008 10:09 pm    Post subject: Reply with quote
I found one in a yard a (long) while back. It had 2 small black plastic bolthead covers also, VW I think. I broke a few of the plastic interior handles in the helper position before I switched to the Vanagon black metal sliding door handle which fits perfectly and seems to last forever. It also has a slight articulation that helps with closure.
1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy
Mr. Loaf
Mr. Loaf is offline
PostPosted: Tue Jun 03, 2008 3:59 am    Post subject: Reply with quote
Isn't this the same handle that WolfsburgWest sells?
Never drive faster than your Angel can fly
$24,100 was too hard to resist.................
NASkeet
NASkeet is offline
PostPosted: Thu Jun 10, 2021 11:14 am    Post subject: Reply with quote
If they are that fragile, I think I shall just stick with my home-made pull-close strap. Cool
Regards.
Nigel A. Skeet
otiswesty
PostPosted: Thu Jun 10, 2021 4:30 pm    Post subject: Re: 78 Westy, knob on sliding door Reply with quote
I think the reason that my OG handles were breaking is because they were used units that had some small cracks in the plastic already. Back then, I was getting most of my spare parts from the wrecking yards as the busses were plentiful there in southern California in the late 1980s and early 1990s.
The rear handle also experiences a very different stress in the rear closing assist position compared to the front opener. In the front it is really a lateral pull along the axis of rotation of the latch mechanism. In the rear, the position is fixed and the forces are inward, stressing the structural design of the metal insert as it is cast into the plastic handle. Any weakness and its all over. I have also, at one time, broken off one of the square studs on the rear handle mount, but haven't had any issues with it for many years now.
We were actually making a cast aluminum handle in the early 1990s to use in this position until I realized that the black metal T3 handle was an easy swap. That ended that production idea. The prototypes were promising tho. No pics, sorry.
Just a regular guy
BruceJ
BruceJ is offline
PostPosted: Sat Jun 18, 2022 6:00 am    Post subject: Re: 78 Westy, knob on sliding door Reply with quote
I just ordered one of these kits from www.buttysbits.com for my '72:
https://www.buttysbits.com/?product=bb-155-westfalia-sliding-door-helper
Q: If I close the door to install this, will the door stay in place when I remove the two bolts?
1965 Beetle
1972 Westfalia
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Sat Jun 18, 2022 7:24 am    Post subject: Re: 78 Westy, knob on sliding door Reply with quote
Nigel has the set-up. If you place a plastic handle for the helper position it’ll never crack unless you use it.
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
busdaddy
busdaddy is offline
PostPosted: Sat Jun 18, 2022 8:14 am    Post subject: Re: 78 Westy, knob on sliding door Reply with quote
Yes, but I would make sure the rear 2 are properly tight before removing the fronts, they should hold adequately to prevent it moving out of adjustment.
Pic from Colin's refresh thread:
Слава Україні!
NASkeet
NASkeet is offline
PostPosted: Sat Jun 18, 2022 11:59 am    Post subject: Re: 78 Westy, knob on sliding door Reply with quote
Once one has checked the tightness of the rear-most pair of M6 bolts, fully close & lock the sliding door, before removing the front-most pair of M6 bolts to retro-fit the pull-close handle or strap. By doing this, the sliding door is also supported by the locks rather than solely by the sliding hinge mechanism.
Regards.
Nigel A. Skeet
BruceJ
BruceJ is offline
PostPosted: Sat Jun 18, 2022 12:46 pm    Post subject: Re: 78 Westy, knob on sliding door Reply with quote
Thanks for the tips! And yes, it would not surprise me if the plastic handle breaks--that's what plastic seems to do best--but I have an extra handle laying around anyway. If (when) it does break, I might try a more creative solution--spigot handle, leather strap, who knows?
1965 Beetle
1972 Westfalia
