Exploded view of handbrake adjustment mechanism -pre 55 Oval
Clarky
Clarky is offline
PostPosted: Mon May 26, 2008 9:49 am    Post subject: Exploded view of handbrake adjustment mechanism -pre 55 Oval Reply with quote
Does anyone have an exploded view/picture of the handbrake adjustment mechanism for a pre 55 Oval.
My chassis came in bits and I have a bag of parts I have now cleaned up and want to fit as soon as I can.
Cheers
Michael
www.vwoval.co.uk
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon May 26, 2008 10:24 am    Post subject: Reply with quote
THese are the only pics and diagrams I've seen of the early long-pushrod style emergency brake setup:
-Andy
Clarky
Clarky is offline
PostPosted: Mon May 26, 2008 10:32 am    Post subject: Reply with quote
Cheers Andy, that's a good start as I have all these bits to fit Laughing
www.vwoval.co.uk
RareAir
RareAir is offline
PostPosted: Mon May 26, 2008 11:13 am    Post subject: Reply with quote
You're in luck as it looks that almost everything is present. Finding some of those little pieces can easily drive you mad.
I said almost because you don't have the tiny split pin that goes on the very end of the push rod. But those can be bought at a hardware store for pennies.
Clarky
Clarky is offline
PostPosted: Mon May 26, 2008 11:16 am    Post subject: Reply with quote
Laughing
That's typical then as I've found another set in one of my boxes that's missing just one long bolt.
www.vwoval.co.uk
ProjectX
Accessory Nut
ProjectX is offline
PostPosted: Mon May 26, 2008 12:43 pm    Post subject: Reply with quote
I hope you have the threaded pin still in the brake shaft, that's another piece not in the pic Cool
Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible
Clarky
Clarky is offline
PostPosted: Mon May 26, 2008 12:55 pm    Post subject: Reply with quote
yep, got the handbrake rod and the threaded adjuster in the end, all cleaned up and smooth Smile
www.vwoval.co.uk
Bravo 1
Bravo 1 is offline
PostPosted: Tue May 27, 2008 6:11 am    Post subject: Reply with quote
Why exactly would they set it up like that? A rod goes all the way forward to pull the rear brakes?
Gotta love German engineering... Wink
1964 Type 1 Sedan
The Android
PostPosted: Tue May 27, 2008 10:13 am    Post subject: Reply with quote
It was up there because it was where the cable-operated brakes on Standard models were adjusted. It took them a few years on Deluxes before they changed the design. From the KdF Wagen manual archived on TheSamba, this is a pic of the cable-operated layout.
Bravo 1
Bravo 1 is offline
PostPosted: Wed May 28, 2008 6:31 am    Post subject: Reply with quote
Thanks glutamodo, I'd never seen a picture of a cable brake system before. I didn't realize that they all went forward before going to their respective wheels, but it makes sense. Cool
1964 Type 1 Sedan
Oldfart
Oldfart is offline
PostPosted: Thu May 29, 2008 3:44 am    Post subject: Reply with quote
So is the handbrake pushrod the reason the 53/54 models had the heater knob behind the the handbrake?
RareAir
RareAir is offline
PostPosted: Thu May 29, 2008 6:59 am    Post subject: Reply with quote
I'll try to post a photo of the area under the fuel tank of my '47. Without the master cylinder and brake hoses, that area looks so clean & empty. Just a pair of tie rods & a pair of cables, that's it.
Bendik
Bendik is offline
PostPosted: Mon Apr 16, 2012 2:48 pm    Post subject: Reply with quote
Sorry to bring this post up again, but I have a metal plate that is bent on the upper and lower side as well as having a square hole in the middle. Where does this go?
German U-Boat
German U-Boat is offline
PostPosted: Tue Apr 24, 2012 9:40 am    Post subject: Reply with quote
Does this plate have a small round hole on each side? If so than this is the plate that holds the ebrake pushrod spring in place and under tension.
Bendik
Bendik is offline
PostPosted: Tue Apr 24, 2012 9:44 am    Post subject: Reply with quote
Here is a pick of the two plates I am talking about. I have the plate that screws in to the framehead and these two in addition.
German U-Boat
PostPosted: Tue Apr 24, 2012 9:52 pm    Post subject: Reply with quote
The bottom piece goes on the e brake rod followed by the top piece. The e brake cable threads come thru the holes on each side and 2 nuts are threaded on each cable. Also a pin is driven thru the shift rod tip.
Bendik
Bendik is offline
PostPosted: Tue Apr 24, 2012 11:41 pm    Post subject: Reply with quote
Thanks
That was basically what I thought, but I was unsure wether there should be something between the plates. Thanks a lot for the help.
Klemen Klemen
Klemen Klemen is offline
PostPosted: Fri Oct 10, 2014 11:45 am    Post subject: Reply with quote
glutamodo wrote:
It looks to me like at the end of push rod there are 4 pins with wires for hand brake. Two for rear and two for front. Am I wrong?
1955 oct oval
1960 jan split bus
1974 topless
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Fri Oct 10, 2014 7:13 pm    Post subject: Reply with quote
Klemen Klemen wrote:
Yes, that is a cable brake setup. More about those is here: http://www.thesamba.com/vw/forum/viewtopic.php?t=443074
54ovsemi
54ovsemi is offline
PostPosted: Sun Feb 22, 2015 7:49 pm    Post subject: Reply with quote
Did you get parts reassemble sorted out? I'm facing similar dilemma...took beam off to install new beam, disassembled behind cover plate to clean up. Unfortunately I did not photo document and forgot how it goes back together!!
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
