Gauges
Page: Previous  1, 2, 3 ... 5, 6, 7 ... 13, 14, 15  Next
Bub
Bub is offline
PostPosted: Sat May 03, 2008 11:08 am    Post subject: Reply with quote
Not a mention of Drager gauges yet.
Found this one the other day...anyone ever attempted to restore one?
The internals are amazing- I opened this one to free it up and it seems to work awesome now.
Anyway, a US model Drager, no date stamp.
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
redhot
redhot is offline
PostPosted: Sat May 24, 2008 1:56 pm    Post subject: Reply with quote
Hi,
This is perhaps not the best thread to ask in, but I can`t find anything more suting either.
I`m after a set of gauges that looks vintage, like they belong in the car. The modern gauges for sale that I have seen are to modern in their design.
1) Does anyone sell gauges with a vintage look, resembeling the beetles original speedo?
2) Does anyone know where to get / have upgraded their modern instruments with new facing and a chrome ring? Does anyone have a vector file of it?
3) Can I use a Porsche 356 gauge with oil temp / pressure in the same gauge in a Beetle? I was thinking of using the Porsche senders (available?) but are the pressure mechanical?
Daniel
Daniel is offline
PostPosted: Tue Jun 17, 2008 9:23 pm    Post subject: Reply with quote
Here's a gauge I just picked up. Same size as a normal bus version, but with a different looking face. It's dated on the back as 10/54.
PostPosted: Tue Jun 17, 2008 10:57 pm    Post subject: Reply with quote
https://www.thesamba.com/vw/gallery/pix/452065.jpg
10/54 is really early for that style of gauge.
Does it have a Beetle or Ghia chrome ring or ?
Suboval
Suboval is offline
PostPosted: Wed Jun 18, 2008 6:47 am    Post subject: Reply with quote
What's the difference between the rings?
PostPosted: Wed Jun 18, 2008 8:32 am    Post subject: Reply with quote
I don't know if there is a difference. Buses have a more curved ring to match the Bus dash but 10.54 would be too early for that in a Bus.
Daniel
Daniel is offline
PostPosted: Thu Jun 19, 2008 12:53 am    Post subject: Reply with quote
I checked it against a bus gauge I have and the rings are quite different. The bus one is much smoother where this one has an extra rib.
There's also no vw markings on it so I'm guessing it's an early aftermarket vdo one. I'll have to email the guy I got it off to see if he has any other info on it.
Daniel
Daniel is offline
PostPosted: Thu Jun 19, 2008 1:28 am    Post subject: Reply with quote
OK, got a really quick reply from the seller. He said it came out of a 54 truck his father wrecked about 30 years ago. It was in a small panel that had an amp gauge as well.
Wiggy
Wiggy is offline
PostPosted: Thu Jun 19, 2008 7:52 am    Post subject: Reply with quote
I had that exact same gauge with that ring that was installed by the dealer in my old 55 vert.
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
PostPosted: Thu Jun 19, 2008 8:17 am    Post subject: Reply with quote
They look like these early Ghia gauges I have:
I did notice the 1/4 symbol is slight offset between your 54 and my 56/57 fuel gauges.
They were also used as accessories on Buses, typically ambulances.
CalLookCustoms
CalLookCustoms is offline
PostPosted: Tue Jul 15, 2008 1:29 pm    Post subject: Reply with quote
Picked up this NOS gauge off eBay. Couldn't find much information on this in the forums and gallery. Perhaps someone could identify this?
[/img]
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Tue Jul 15, 2008 2:02 pm    Post subject: Reply with quote
Some form of pressure gauge.... and not for an automobile unless you're running several superchargers and a few turbos in row Laughing
Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices.
NASkeet
NASkeet is offline
PostPosted: Wed Jul 30, 2008 5:36 am    Post subject: Accessory gauges - remote-shunt ammeter & voltmeter circ Reply with quote
The following, are some electrical circuit wiring diagrams, pertaining to the possible arrangements of battery-charging circuits and my own approach to retro-fitting a remote-shunt ammeter and voltmeter, for monitoring purposes.
By using two or more, separate remote-shunts and a two-pole selector switch, one can use a single remote-shunt ammeter, to monitor the current flow in different parts of the electrical system; particularly to and from the battery (charging & discharging currents, and the total current supply to the vehicle's electrical loads.
The selector switch for the voltmeter, enables one to check direct voltage readings at the voltage regulator and at the forward end of the vehicle after any voltage drop in the main supply cable and connections.
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
oval56
oval56 is offline
PostPosted: Mon Sep 08, 2008 3:56 am    Post subject: Reply with quote
my latest score, datet 62, 6volt
willt fit perfectly to my new 1433ccm 30+xxhp engine Very Happy
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
redhot
redhot is offline
PostPosted: Tue Dec 16, 2008 3:19 pm    Post subject: Reply with quote
Does there exist a small version, like the Moto-meter instruments, about 42mm, in both oil pressure and temperature?
Planning to fit them in the radio-aparture without cutting the dash
IN2VWS
IN2VWS is offline
PostPosted: Tue Dec 16, 2008 10:24 pm    Post subject: Reply with quote
Motometer made small gauges....
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
redhot
redhot is offline
PostPosted: Wed Dec 17, 2008 3:40 am    Post subject: Reply with quote
Yes, that was the set I was thinking of. But did they also make a oil pressure gauge in the same size? What is the warning light in the set for, oil pressure like the stock idiot light?
IN2VWS
IN2VWS is offline
PostPosted: Wed Dec 17, 2008 4:37 am    Post subject: Reply with quote
The warning light has no specific function. The instructions says:
"The signal light in the Rallye-Set may be used as controlling device for any purpose (for instance control of handbrake, halogen-lights or fog lights)."
Just checked the MotoMeter catalog,and there was no 40mm oil pressure gauge available at that time.
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
vwraymund
vwraymund is offline
PostPosted: Fri Jan 09, 2009 6:12 am    Post subject: Reply with quote
Look at this.
Al new VDO fuel gauge for beetle dashboard from aug.57.
It is NOS and has al the things you need.
Also the org. instaling paper.
This is the only complete one i have ever seen.
Its dated 10-58 also the box says 58.
Gr Ray
slugbug60
slugbug60 is offline
PostPosted: Sun Mar 08, 2009 4:33 pm    Post subject: Reply with quote
hi... could you possibly post up a pic of this fuel gauge from the back?
Thanks
Chris
'60 Beetle 2110cc "The Slug"
www.austinaircoolers.com
Page 6 of 15
