Stuffing the widest tires
Page: Previous  1, 2
VWDruid
VWDruid is offline
PostPosted: Wed Jun 18, 2008 12:28 pm    Post subject: Reply with quote
you are running with grossly under-rated tyres on
aye i got that part, one of the first thing i did after reading the tire sticky was look what lode bearing tire fit on a 15in rim... nothing, so now im looking for some stock or these 16 in rims are intriguing. I may just risk a 50 mil drive to buy some if i dont get any local bytes for a trade.
just looked up to see what yr Bug these will fit to repost my ad, look like 61 to 67.. I'm not giving them up to a bus owner.
Tyvm Skeet
NASkeet
NASkeet is offline
PostPosted: Thu Jun 19, 2008 5:42 am    Post subject: Re: argg and when i was all set to get 14in Reply with quote
Tyvm Skeet
NASkeet wrote:
Assuming your 15 inch wheels are 5½~6 inches wide, 195/70 R15C tyres (virtually identical, external circumference, to that of 185 R14C tyres), as used on the 1993~2003 VW Eurovan, would be a better choice.
As I previously indicated, the 195/70 R15C tyres, as used on the 1993~2003 VW Eurovan, have a more than adequate load rating, for the 1968~79 VW 1600 & 17/18/2000 Type 2s! Brick wall
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
theizzardking
theizzardking is offline
PostPosted: Thu Jun 19, 2008 12:24 pm    Post subject: Reply with quote
i`m still baffled by the v6 in a 1970 bus?
VWDruid
VWDruid is offline
PostPosted: Thu Jun 19, 2008 10:31 pm    Post subject: Reply with quote
i found them and got them on the bus i feel a bit safer only got two atm, man there not much room from the side wall to the tier but think it will be fine till i start trying some dune bugging Shocked
set me back $270.35 with all the work for 2 I'll wait for them to brake in some and to billed up some $$, going to look for some junk yard seat belts to
make it more come fey. thanks agen .
what about V6?
NASkeet
NASkeet is offline
PostPosted: Fri Jun 20, 2008 6:35 am    Post subject: Re: argg and when i was all set to get 14in Reply with quote
what about V6?
I would think that US$270·35 was quite cheap for two 195/70 R15C tyres, which is only about £70 each!
I am not sure about the available rear wheel-arch clearance, on a 1968~71 VW Type 2, but your apparent lack of available clearance might be more attributable to your "choice" of wheel offset, rather than the wheel & tyre size!?! To the best of my recall, the factory-stock 1968~70 VW Type 2 wheels, have an offset of 45 mm, whilst those of the 1971~79 VW Type 2 wheels, have an offset of 39 mm.
Regards.
Nigel A. Skeet
Page: Previous  1, 2
Page 2 of 2
