bugpartslou Samba Member
Posted: Wed Jul 16, 2008 2:47 am Post subject: Will an 85 Vanagon Sliding Door fit a 90 Vanagon? |
| Does anybody know? |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Wed Jul 16, 2008 3:37 am Post subject: |
Do a search; this topic has been brought up. I know there are differences in the early to mid 80's, but I'm going by memory.
The search should help you. Here's one I found by searching "sliding door":
http://www.thesamba.com/vw/forum/viewtopic.php?t=295375&highlight=sliding+door _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
Terry Kay Banned
Posted: Wed Jul 16, 2008 4:38 am Post subject: |
No it won't---
80 to 85 are all the same, 86 to 90 share all the same hardware & mounting points. _________________ T.K. |
Wellington Samba Member
Joined: September 21, 2004 Posts: 2015 Location: Montreal
Posted: Wed Jul 16, 2008 4:58 am Post subject: |
| 1985 was the transition year, I have a 1985 with the later style door, so you will have to check yours and see which one you got. |
Posted: Wed Jul 16, 2008 6:45 am Post subject: |
Wellington is correct. If the '85 door in question has the short outside door handle (easy identifier), it will fit. The earlier '85 doors had the early style long handle and therefore the early style latches, guides, etc. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Wed Jul 16, 2008 8:28 am Post subject: |
| loogy wrote: |
| Wellington is correct. If the '85 door in question has the short outside door handle (easy identifier), it will fit. The earlier '85 doors had the early style long handle and therefore the early style latches, guides, etc. |
Hmm, so what's the handle measuremnet for the short version?
I mean, I got a handle, but without the "other" version to compare it to, how do I know if it's the short one or the long one?
So to speak.  _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
kevtherev Samba Member
Joined: December 23, 2007 Posts: 897 Location: the 51st state
Posted: Wed Jul 16, 2008 1:13 pm Post subject: |
fairly easy to fit a late slider on an early van or vice versa
just need small mods to the latch area of the pillars!
dosn't take long! couple of hours should do it
opening size is the same |
Posted: Wed Jul 16, 2008 2:27 pm Post subject: |
| hiram6 wrote: |
| loogy wrote: |
So to speak.  |
I don't have a short handle to measure, but a long handle is approx. 21cm (8.25") overall. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
ChesterKV Samba Member
Joined: February 07, 2005 Posts: 1725 Location: El Cerrito, CA
Posted: Wed Jul 16, 2008 3:14 pm Post subject: |
| Wellington wrote: |
That means your van is an 85.5 which Volkswagen (as well as its high end Audi models) is famous (infamous?) for doing; it leads to a lot of head scratching at times.
- Chester _________________ 1984 Wolfsburg 7-passenger stock sunroof
1992 Subaru Legacy EJ22 boxer motor installed.... van is now sold.... currently playing with a 1987 Toyota MR2 with 1.6 liter twin-cam motor. Better than the Subaru boxers....... I'm impressed. Well, okay, in an "apples and oranges" kind of way.  |
beatrich Samba Member
Joined: October 17, 2007 Posts: 148 Location: Somewhere on the road
Posted: Wed Jul 16, 2008 6:15 pm Post subject: |
| Check the 85 door handle against yours- If it's a match, then it works, right? Wish there was a place to get a used Vanagon part within 50 miles of Spokane. |
Terry Kay Banned
Posted: Wed Jul 16, 2008 8:48 pm Post subject: |
It's pot luck on an 85 door fitting.
If you can get the build date of the donor Van--sometimes they'll fit, sometimes they won't.
Depends on what inventory they line was using that day--late door's & hardware or early hardware--
Whatever they happen to have at that time.
You could remove & replace allof the lastch mechansim, & striker plate off of a later modal Van and maybe get it to work.
I have never seen this happen though--
The mounting screw holes aren't lined up right to accept the later hardware in the early door.
You'd be much better off bumping your side door find to an 86--then it will fit for sure. _________________ T.K. |
Posted: Thu Jul 17, 2008 4:08 am Post subject: |
| ChesterKV wrote: |
| Wellington wrote: |
- Chester |
I think I recall my manufacture date as August. What i do know, I got the later slider door, plastic coolant pipes front to rear, tachometer, rear wiper, however, it has a 1.9litre (for now) ceramic fuses as opposed to blade, and has the early uprights front suspension. Ya ,they mix and match, makes it fun to get parts. Sorry for the hijack, it 's just interesting to see that it's not exactly defined when you need parts. |
hiram6 Samba Member
Posted: Thu Jul 17, 2008 12:19 pm Post subject: |
Those of us with an 85 should have our own support group.
"Hi, I'm Hiram, and I own a transition year Westy" "Hi, Hiram"
Seriously, it does make it a challenge to find the right part sometimes, but I look at it like this.
While I may have the old style fuses (-), I also have the round headlights (+).
While I have the 1.9L (-), I've got some stouter engine internals (+).
While I've got steel pipes (-), hey I've got UNRUSTED steel pipes (+)
I've got the tach, the rear wiper etc., but it's obvious, as Terry said, VW just grabbed whatever was on the shelf to attach to the van sitting in front on them on the assembly line at that moment. Kind of like each one is a custom job!! _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
erdonline Samba Member
Posted: Thu Jul 17, 2008 8:19 pm Post subject: Door compatability and differences |
I had to replace my slider a few months ago. I have an '85 and it is the newer style, and the door I found fit fine. I did have had a chance to compare the two styles, though, and there seem to be these differences between early and later doors: Different handle size; different latch on the front end of the door and pillar; different latch on the rear end of the door and pillar; different size window. The window on earlier doors is the same size as the driver side window. The window on later doors is about an inch narrower left to right. Does anyone know why the window size changed when they changed the doors? I haven't looked very closely at the inside without the interior panels on, but it seems that the hardware is all below the windows, so I don't see the reason for the change.
Also, others have mentioned swapping earlier and later doors. It may only take a few hours, but it would require welding the rear latch pin on, and welding is a skill that some of us have not yet acquired (but I hope to learn.)
Ed in CT |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1683 Location: Between Here and There
Posted: Sat Jan 11, 2014 8:01 pm Post subject: Re: Door compatability and differences |
| erdonline wrote: |
| Also, others have mentioned swapping earlier and later doors. It may only take a few hours, but it would require welding the rear latch pin on... |
I'm resurrecting an old thread to see if anyone has photos and more specific information for this conversion. I haven't had much luck with finding info by searching... I do remember someone saying it was quite difficult and not worth making the switch, but this thread makes it sound like its not that big a deal.
My main interest in this is that the wife and kiddo have a really hard time opening the '84 long throw latch, and the newer doors are easier...I'm going to try to rehab the latch this spring, and put on yet another new handle and see how that works... _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
morymob Samba Member
Posted: Sun Jan 12, 2014 11:22 am Post subject: |
| Right, the earlier rear latch mounting spot different than later so not switchable. |
