donmac Samba Member
Joined: April 23, 2007 Posts: 367 Location: Pearland, TX
Posted: Wed Jul 30, 2008 11:32 am Post subject: Replace Oil Control Valves? |
I'm doing a stock 1600 rebuild. Are the oil control valves normally replaced or assumed good? Thanks. _________________ Don
67 Dune Buggy aka Shrek
74 Baja Junk Pile aka Wild Thing |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79581 Location: Sneaking up behind you
Posted: Wed Jul 30, 2008 11:40 am Post subject: |
You need to remove them when you clean the case. Make sure you know which one goes where and that they move freely in the bores when you reinstall them. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
donmac Samba Member
Posted: Wed Jul 30, 2008 11:47 am Post subject: |
I removed and inspected them but I don't have any way to check the springs and after 35 years I'm thinking they may be a little tired? _________________ Don
Glenn  Mr. 010
Posted: Wed Jul 30, 2008 12:02 pm Post subject: |
I've never had a problem with used springs.
But i have had problems with the new aftermarket ones being way too stiff and causing excessive oil pressure problems.
My advice... keep the old ones. _________________ Glenn
Member #1009
#BlueSquare
