fifty-five Samba Crash Test Dummy
Joined: August 27, 2004 Posts: 1188 Location: over by the Farm
Posted: Tue Aug 12, 2008 7:28 pm Post subject: 1600 dp valve guide specs |
I've got my heads at the machine shop and the guy there called and told me my valve guides measuered .004 on all but one exhaust and it measured .005. I am wondering what they are supposed to be . He is a awsome machinist but not used to VW stuff so he didnt know what was right. I'm just wondering how far out these are or are they within spec?
Thanks,
Mike _________________ FUCK CANCER
1955 Ragtop Oval
"Lil Wheezy"
2276 turbo |
vwhp2008 Banned
Posted: Sat Aug 16, 2008 5:32 pm Post subject: |
Hey Mark
.004 is within spec.the reason you probably have a .005 is because that one exhaust guide was worn down and needed to be replaced with an oversize. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Mon Aug 18, 2008 4:44 pm Post subject: |
| vwhp2008 wrote: |
Hey Mark
Are you talking about the OD here?
Is the original poster talking about the ID or the OD as well? |
Posted: Mon Aug 18, 2008 9:05 pm Post subject: |
pretty sure it was the ID. The guy at the machine shop just called me while he had the heads apart and gave me those measurements. I was just wondering how far off that was. I got the engine back together for now. This is just a get me by until I can save for a bigger engine 1600 dp and not a daily ride. maybe once or twice a week in good weather (not to hot and only a very slight chance of rain).
Thanks,
1955 Ragtop Oval
"Lil Wheezy"
2276 turbo |
modok Samba Member
Joined: October 30, 2009 Posts: 27757 Location: Colorado Springs
Posted: Tue Mar 29, 2011 4:38 pm Post subject: |
The guide OD in old factory heads seems to be .475"
Most "standard' replacement guides are more towards .476"
The way to do it right, is measure the bore in the head, and choose a guide so you have .0015-.002 press
It is pretty common to need an oversize guide in heads that have a lot of miles.
edit: huh, the question I was answering dissapeared........
Oh well i'll answer the OP
clearance specs
intake .0015-.003 wear limit .005
exhaust .0025-.004 wear limit .006
I just made that up, but it's probably right
the guide is supposed to be 8mm and the clearance is built into the stem OD |
Adriel Rowley Samba Member
Joined: October 12, 2006 Posts: 4894 Location: Mesa, Arizona
Posted: Tue Mar 29, 2011 4:58 pm Post subject: |
| modok wrote: |
clearance specs
Sorry about that. I did not find the answer to the size, but found several sources by thinking a bit more. Did not want to be a burden, so deleted it.
Thank you modok for answering! Now you not only answered my question, but helped me on my way to rebuilding them. I have seen some hammered in; is this not the right way to do it? Would a drill press work? _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation |
modok Samba Member
Posted: Tue Mar 29, 2011 5:18 pm Post subject: |
hammering them in works just fine. (lube with anti-sieze, can use a 8mm bolt as the driver)
The tough part is removing the old ones, and the other tough part is reaming the new ones to size.
Seems to me the best way is to drive them out towards the chamber.
You can buy a drill to core them most of the way through, or tap a bolt into the chamber side and push on that with a 5/16 rod.
Drill off the part that sticks out towards the spring, some are stepped or locked in here.
Some heads you can just push the guides right out, but not these. If you try to just push them out with a driver; 50% chance you just mushroom the end like a rivet, and might even crack the head. |
Posted: Tue Mar 29, 2011 5:48 pm Post subject: |
| modok wrote: |
Thank you so much!
What be a good size reamer to use? By hand be fine right?
What about cylinder head bores that need to go oversize? Have a set where the guides are loose in the head. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Tue Mar 29, 2011 5:57 pm Post subject: |
| Adriel Rowley wrote: |
What about cylinder head bores that need to go oversize? Have a set where the guides are loose in the head. |
3/8 drill....no by hand will have you drill thru the side of the guide into the aluminum. You need to do it in a drill press at least and the head needs to be 9.5* tilted and clamped down. You don't drill all the way thru. Leave a 1/2 inch on the exhaust and 1 inch on the intake so you can drive it with a 3/8 punch or rod. The top of the guide is 1/2 inch so you can't drive it out until you remove the top or drill and drive them out from the chamber side.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
modok Samba Member
Posted: Tue Mar 29, 2011 6:01 pm Post subject: |
It isn't easy. rebuilding vw heads is pretty hard compared to the average engine.
I got two ideas:
buy a brand new k-line brand 8mm(.315) reamer and hope it is sharp enough to do the job. Bronze is hard to ream because it is tough and gummy. Drive it with a 500 rpm drill, or maybe ream one a day cause you'll be tired if you try to use the amish method.
OR, call your local auto machine shops and see who has an adjustable diamond reamer or diamond hone. The diamond hone cuts SO much better than a regular reamer it is worth it. (but they cost 500 each, so you don't want to buy one)
If the bore in the head is generally round and straight, just use an oversize guide of the appropreate size.
If it is bannana shaped, you'll have to fix that somehow.
Once again, you need the right size reamer or ridged hone of some kind to make it round again. |
Posted: Tue Mar 29, 2011 6:12 pm Post subject: |
If you've never done head rebuilding before than this is not the place to start. If you just want to learn then use a junk head to start with.
modok Samba Member
Posted: Tue Mar 29, 2011 6:23 pm Post subject: |
Probably just saving money on the valve job.
It would be great if people brought in the head with new guides in it, I'd discount 40$ for that.
Would probably be best to let the shop ream them, as what size pilots they have is another consideration. |
Posted: Tue Mar 29, 2011 10:05 pm Post subject: |
| RockCrusher wrote: |
RC |
RC thank you so much for helping out! Nice to have others joining in.
I am sorry I was not clear: still sleep deprived from going to a funeral. Anyway, by hand, I meant to ream the new guides. The information I have said to ream to be sure that they are the proper size.
| modok wrote: |
I got two ideas:
Please see above reply to hand method. A tad bit offended by calling it the Amish method, as I have family that is Mennonite, and the former does use electricity. Both depend on the Elders to decide how strict they want to be, F.I.Y.. Anyway...back to heads.
I thought the valve guide was 8.02, not 8mm, so why an 8mm reamer?
Seems to me I could do the RC method to get the guide out, install the new guide, slip in the valve and if stiff with oil then too tight?
I do not recall why the shop did not want to rebuild them. When I was back in San Diego I did try and find them, but could not. All I have here in Tempe is the heads from another engine. Maybe on the loose valve guides, hone to the .475" and see what the bore looks like. If clean all the way down, then they are strait? What size outer diameter are the oversize valve guides? Figure I should have the reamer so as to bore for the oversize?
RC |
Funny you should think I have never done this! No, first time. I wanted to do it on true junk heads, but have none. These have really shot guides from overheating, and is the most likely culprit in the excessive oil burning. Figure if I mess them up, could go oversize.
| modok wrote: |
I was getting my heads from Russ Wolfe, so no longer a source. I do not trust anyone else with these hard to find type 3 heads, especially the local machine shop. I have watched how he does heads, and it is way too relaxed, especially with the beer drinking and has no precision. Figure after I do a couple, will decide if I want to do this as a side job to help the community out. Plus be self reliant: takes less oil to do them local then having them shipped.
Kind of also along your lines. Figure since they said something about they do not do valve guides, if I do it, I know it is done right or to my satisfaction. Then check the valves, and if good, then put them back exactly where they came from. If they need lapping, I can do that. But, if they need new valves, I will get them from them, unless available from somewhere else.
I would not do any work until I had the valve guides to be sure they were 0.475" or 0.476". Maybe even check the bore while out of the head with a valve. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Posted: Tue Mar 29, 2011 10:29 pm Post subject: |
Drilling the guides is to leave just a thin wall that will actually stretch and shrink the guide so it easily drives out. don't just pound them out as that will tear up the aluminum they seat on in the bores. Putting the new guides in.....heat the head to 400 in the oven and quickly drive a couple guides in then heat the head back up to do the next 2 guides. Heat both heads together so you can throw 1 back in the oven while taking the other out. (Hint: don't use the microwave.....Hey! You never know ). _________________ [email protected] Please use email for all general inquiries.
Posted: Tue Mar 29, 2011 10:39 pm Post subject: |
Drilling the guides is to leave just a thin wall that will actually stretch and shrink the guide so it easily drives out. don't just pound them out as that will tear up the aluminum they seat on in the bores. Putting the new guides in.....heat the head to 400 in the oven and quickly drive a couple guides in then heat the head back up to do the next 2 guides. Heat both heads together so you can throw 1 back in the oven while taking the other out. (Hint: don't use the microwave.....Hey! You never know ). |
I figured not to hammer on them. I like your method better than the drill and ream out the remains.
I have read also to cool the guides: is this not needed?
Good point about heating both the heads. Trouble is not sure I have an oven to do this. My Oma lets no one touch the oven because the door does not stay shut and my Mother is sensitive to smell. Guess I could wait until she is out of the house... Just need to set up a work area there.
I once set a wrapper on fire that way in a friends. Was too low on blood sugar to think that through.
Maybe they would fit in my toaster oven! Gets up to 425 and is a fairly large size. Will try tomorrow. Also could take it to my work area. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Posted: Tue Mar 29, 2011 10:44 pm Post subject: |
Cooling the guides is fine but the effect is really nothing since they are dense and small in diameter so they will shrink far less than .0001 while the aluminum heads will grow pretty significantly. _________________ [email protected] Please use email for all general inquiries.
modok Samba Member
Posted: Tue Mar 29, 2011 10:54 pm Post subject: |
Sorry about the Amish joke, poor taste on my part.
I was trying to convey that running a reamer through bronze takes a lot of force, you will see.
The guide ID needs to be adjusted based on the size of the stem.
See the clearance specs above.
The last three sets I did I diamond reamed the guides to .3145", as the stems of my PEP valves were all right around .3120".
We have a .3142 pilot for the serti so it all worked perfect.
The guide ID can be checked by:
-expandable ball gauge
-mini snap gauge
-special valve guide bore gauge
-using a pilot as a go/no go gauge
The guide bore size in the head can also be checked with a ball or snap gauge OR by using other guides as go/no go gauges
as for the guides; a .002 oversize brand X guide is .002 thou bigger than a brand X STD size guide.
After installing new guides the seats need to be recut or reground so the seat is concentric with the new guide and the proper width and location on the valve. I believe in Sioux grinding equiptment, VGS-20, or Serti.
Those stupid DIY file cutters are kids stuff, I would not use them on my lawn mower. (ok, actually I did once but now I know better)
I would be happy to list what tools will be needed to do an industry standard valve job, and give general advice on how to use them and check your work.
Unfortunately, if you do not currently have ANY of these tools it will take quite a while and quite a lot of money to collect them all.
Posted: Tue Mar 29, 2011 10:59 pm Post subject: |
By "file type" are you referring to the hand driven carbide cutters Goodson is selling? _________________ [email protected] Please use email for all general inquiries.
modok Samba Member
Posted: Tue Mar 29, 2011 11:10 pm Post subject: |
There have been many brands of them, some are better than others I'm sure. I'm thinking they were made by neway? i forget
The advantage of grinding the seats, is it takes very little force on the pilot, and naturally cuts round and on center with no other support.
Cutting valve seats often results in wavy or ovaly seats or seats with a lot of runout, the solution for that has been very stout machines like the VGS-20 or Serti. The machine FORCES the cutter to track round. |
modok Samba Member
Posted: Tue Mar 29, 2011 11:22 pm Post subject: |
I just looked at Neway's web page, it says:
"no need to lap like old fashoned grinding equiptment"
hahahaha THE IRONY
You can grind any seat from iron to stellite to stainless to high nickel, no lapping needed if done right. WIth a full set of sioux pilots and stones I can grind any seat perfect.
There are alot of jobs the neway cutters are not able to handle, and on used vw heads those exhaust seats can get REALLY HARD and crispy, the files don't like chewin on that
