Bruce Wayne Samba Member
Posted: Fri Aug 29, 2008 11:26 am Post subject: short shift kit |
thinking of getting the short shift kit for my 85GL. should I get the one with or without the extension? I see they have it at VC for $50 (without exstension)and $75 (with exstension).is there a cheaper place to get it? pros and cons of this mod anyone? |
Wellington Samba Member
Joined: September 21, 2004 Posts: 2012 Location: Montreal
fastwagens Samba Member
Joined: March 01, 2004 Posts: 1028 Location: Michigan (The other west coast)
Posted: Fri Aug 29, 2008 12:53 pm Post subject: |
I have a short shift kit I got from a van I parted (unknown manufacture) and am using it with a shift extension that I fabricated and sell in the classifieds. I am very happy with this set up that I removed it to take some measurements and it felt so uncomfortable going back to stock that I put it back on immediatly. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12371 Location: Santa Cruz, CA
insyncro Banned
Posted: Sat Aug 30, 2008 5:22 am Post subject: |
Wellington,
The difference between the two kits is the diameter of the shaft.
One is 12mm older models and 14mm for 86-91 Vans.
I bought the more cost effective one and it didn't fit my late model Vanagon.
The Gene Berg versions of this system are much better IMHO.
dylan |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10151 Location: Abiquiu, NM, USA
Posted: Sat Aug 30, 2008 8:52 am Post subject: |
Get it. You'll love it. It's the way the thing should have been built.
I see adding the extension as just lengthening the throw all over again, right after adding the riser to shorten it. Depends on where you like your hands to be, I suppose, but it would just return to a wide pattern, moved higher. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Experience is death to doctrine. |
Posted: Sat Aug 30, 2008 2:14 pm Post subject: |
dylan |
I called a place around here that has a short shift kit that say's it's for bus' and bug's. not sure if it's 12mm or 14mm or ??? my van is a 85 GL,so I need the 12mm size correct? they want $4.50 for this kit. yes $4.50!! |
Posted: Tue Sep 02, 2008 4:25 am Post subject: |
Thanks Dylan for the info. Look at the second link I posted, it shows the ubit in the package, no extension pictured, just a spacer plate.
Would I be correct to assume either one woulf fit my van if I didn't want an extension? |
insyncro Banned
Posted: Tue Sep 02, 2008 4:39 am Post subject: |
Wellington,
I believe that the one you are looking at will fit.
The raiser block is the same for both size shifters.
Give the vendor a call to verify.
df |
kevinbassplayer Samba Member
Posted: Wed Sep 03, 2008 7:53 am Post subject: |
I have the Van-Cafe short shift kit and it rocks! |
doyll Samba Member
Posted: Fri Sep 05, 2008 5:40 am Post subject: |
Think the only difference in them is one is for 12mm and other is for 14mm shifter shaft... IE the sleeve piece that is used to space the shifter cup up the shaft to change the ratio. Not positive as have never compared them side by side.
Not complicated to make kit yourself.
5/8" (maybe more, just guessing from memory) spacer plate to match shifter plate (piece of 5/8" plastic with big hole in center and 2 small holes for bolts/coupling nuts), 3/4" sleeve spacer with tapered in on bottom and beveled on top like in kit (12 or 14mm id), 2 each coupling nuts and bolts.... might be a little hard to find metric coupling nuts. I have CSP installation .pdf is you want it.
Have heard that just moved the spring retention ring up 1/2" works too. Just drill a new depression for set screw in spring retention ring. This lowers the shift lever down 1/2", but peps who did it this way don't seem to have anhy problems.. of course it lowers shift nob 1/2" too. Easy to try as can put it back very quickly to stock. I was given a kit, so didn't try this trick. |
Posted: Sat Sep 13, 2008 8:31 pm Post subject: |
so I installed the short shift kit from VC yesterday,so far I like it. I have only driven it to the store and back. should get a real feel for it in the coming week on the commute to work and back.also took out the plastic pieces at the base of the shifter and took it all apart and regreased it. what little grease that was left in there was all dried up.feels much better and shifts much smoother now!! |
ejimmi Samba Member
Posted: Sat Apr 30, 2016 1:53 pm Post subject: Re: short shift kit |
I just made one of these. Its definitely worth the $60 if you don't have a lathe and other shop tools.
If you are set up with that type of equipment its a pretty simple project.
You need:
* A 3/4" thick spacer to raise the shifter base.
* Some 3/4" thick threaded standoffs for the floor studs, you will then use bolts to bolt the base to the standoff.
* A 3/4" spacer with outer bevel on one end and inner bevel on the other end, to match the taper on the base of the shifter.
It should be pretty obvious when you get in there, all thats really going on is you are moving the entire pivot point up 3/4".
Results are amazing!
Heres a pic showing the base riser, standoffs, and the beveled spacer at the base of the shift fork.
goffoz Samba Member
Posted: Sat Apr 30, 2016 10:42 pm Post subject: Re: short shift kit |
ejimmi wrote: |
Sorry, considering the box under the floor with the shift guides, I don't see how this could work.
....How do you get reverse??  |
narendra.vw Samba Member
Joined: February 07, 2013 Posts: 440 Location: Bangalore India
Posted: Sun May 01, 2016 12:16 am Post subject: Re: short shift kit |
I'm using this kit for my TD(14 mm shifter rod).
All it does is, shift pivot point by 10mm. It did help me in fast shifting
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12170 Location: Port Manteau
Posted: Sun May 01, 2016 8:06 am Post subject: Re: short shift kit |
Wow, those five speed shift boxes are quite a bit different than four speeds _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4596 Location: East Kootenay, British Columbia
Posted: Sun May 01, 2016 8:36 am Post subject: Re: short shift kit |
goffoz wrote: |
ejimmi wrote: |
It doesn't actually shorten the stick, nor it's reach into the box. It only raises the pivot point making it "feel" like a short shift. Shorter throws between shifts. The overall height of the shifter remains the same.
That's why if you add an extension, the knob will be higher, but then the knob has to describe a longer arc to execute a shift and comes back to feeling like a regular shifter.
Love mine I bought years ago from Gene Berg. With a tight shifter base and clean grease you don't feel like you're rowing a boat while shifting!. _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
goffoz Samba Member
Posted: Sun May 01, 2016 9:19 pm Post subject: Re: short shift kit |
MsTaboo wrote: |
goffoz wrote: |
ejimmi wrote: |
Love mine I bought years ago from Gene Berg. With a tight shifter base and clean grease you don't feel like you're rowing a boat while shifting!. |
So, if you raise the base 3/4" then the ears on the shift linkage will not mesh with the guides in the box below the floor.
You must have too relocate the pivot point , so the bottom of the shaft is still in the right location in the box.
Ok, I see, you need to re-drill the pivot point to match the new base.
http://www.t3technique.com/accessories/miscellaneous-accessories,-shirts,-etc/296.html |
Posted: Sun May 01, 2016 9:47 pm Post subject: Re: short shift kit |
The one, on mine is universal, the only choice you have to make is 12 mm or 14 mm shifter rod.
They provide a stopper ring for the rod spring(the ring dia change according to the shifter rod).
It comes with a clear instruction. |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2987 Location: Issaquah, WA
Posted: Sun May 01, 2016 10:18 pm Post subject: Re: short shift kit |
Zeitgeist 13 wrote: |
Wow, those five speed shift boxes are quite a bit different than four speeds |
The normal 5 speed shift box looks just like the 4 speed box with the addition of those two aluminum guides bolted to the base of the box. This one is for a late model factory 1.6 TD Vanagon that has the raised/angled center floor structure. Basically, they extended the box so that the shifter could sit close to the standard position below the raised floor.
Definitely a weird looking solution.
D |
