kustomkat1950 Samba Member
Joined: March 04, 2005 Posts: 79 Location: desert, ca
Posted: Wed Oct 01, 2008 6:20 pm Post subject: well..............check this out |
so i have first, second and third. shifting into fourth goes in but i lose power in fourth with a cruising speed of 51. no good. i can cruise to work at 50 in third but when i shift, i decrease speed. no e brake drag, everything else motorwise is good. i have 185/65 in the rear tuckin like a mofo. i drive an inch of the ground. really. i eat road reflectors. could an axle bearing cause this. i have a 1300 sp with a stock trans. and i really have to drive my bug. i'm about ready to pull my sqback motor to throw in it. i have a tahoe to drive but it collects dust cause i love driving my bugs...anyone have any clue?????? thanks _________________ justin
"save string" |
Posted: Wed Oct 01, 2008 6:48 pm Post subject: anyone.... |
im ready to pull motors... gotsa drive tommorrow _________________ justin
"save string" |
Hotrodvw Samba Member
Posted: Wed Oct 01, 2008 9:44 pm Post subject: |
It couldn't be wheel bearings. They don't need oil or lubrication anyway. There are a thousand people here that think so anyway. Oil doesn't run up hill.....what do you think?? I can see plenty of issues that might contribute to your 'issue'. I think you already have an idea. That e-brake cable looks a bit snug dewd...... _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36034 Location: Conejo Valley, CA
Posted: Wed Oct 01, 2008 9:51 pm Post subject: |
Not to mention that you are well below the California vehicle code limit for ground clearance. It is illegal to be so low that any portion of the car would rub the ground should you shed a tire. This is for safety reasons. If you get a flat, hell if you are low on air in a front tire, you lose all directional control of the car. This is brainlessly lowered. Might be best if you don't drive in 4th gear with this setup.
First would be even better for you. |
Posted: Wed Oct 01, 2008 9:53 pm Post subject: |
It is truly the dumbest damn thing I've seen in a long time. But hey.....we're concerned about 4th gear here, Not safety.  _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26538 Location: Douglas, WY
Posted: Wed Oct 01, 2008 10:42 pm Post subject: |
Hotrodvw wrote: |
It couldn't be wheel bearings. They don't need oil or lubrication anyway. There are a thousand people here that think so anyway. Oil doesn't run up hill.....what do you think?? ...... |
If I had a slammed bug this low (well, I wouldn't, I hate how they handle, and one THAT low I'd never even consider) and with that much of an angle on the axles I think I'd at least go and pack some good moly grease into the wheel bearings...
You sure that it is a 1300 in there? It looks like a stale-air 40HP (1200) heater box in that picture. STill, even a 40HP should be able to go faster than 51 in 4th gear. They were rated (with stock tire height) up to 72MPH. |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Thu Oct 02, 2008 5:21 am Post subject: |
If its pulling fine through the other 3 gears and looses power in fourth, my guess is the tranny has had enough.
Have you checked the oil level in the tranny?
Keep in mind that you have EVERYTHING way out of the design parameters. Things CAN NOT work properly like this. Not only do you have no lubrication going to the wheel bearings, but you also have too much angle at the fulcrum plates.
This causes wear at the fulcrums. That puts metal into the lubricating oil in the trans. That metal is going through all the sychros, bearings, gearsand other moving parts and is causing more wear, putting more metal into the gear oil.
Do you think this could be a problem?
Dude, you need to do a tranny raise! You can't jack things this far out of thier intended design areas and expect them to work.
Is this transportation or art work? If it is art work, park it and stare at it. Admire what you have done. But if this is transportation, you need to correct a few things, or else be able to accept that this package can not perform without constant replacment of expensive parts.
I don't know how you are staying out of the watchful eye of law enforcment, but I must agree with some others here. You have gone too far! _________________ Mother Nature is a Mean Evil Bitch! |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
50ate Samba Member
Posted: Thu Oct 02, 2008 9:35 am Post subject: Re: anyone.... |
I call bullshit.. If indeed this is not a bagd front or air shocks or somthin.. It would be imposible to get to 50 anyway youd be draggin all this shit down the road.. Of course you cant do faster than 51 look at it.. Dont get me wrong i love slamed bugs and this one looks cool.. Sittin in the driveway..
kustomkat1950 wrote: |
im ready to pull motors... gotsa drive tommorrow |
Johnny.Baba Samba Member
Posted: Thu Oct 02, 2008 9:59 am Post subject: |
I agree, no F'n way this thing would hit any where close to 51 with this kind of drop and those pans (and more) in the condition shown. |
crazyman_stanley Samba Member
Joined: November 01, 2005 Posts: 180 Location: Norcal
Posted: Thu Oct 02, 2008 10:24 am Post subject: |
Buncha pussies
come here man; we'll welcome you with open arms
www.volksrods.com _________________ CHECK OUT MY ADS FOR 67beetle for sale!!
FOLKSLAGGIN
http://www.dubjunkies.4t.com
1967 Savanah Beige Beetle-FORSALE!!
1965 Hunk o' Shit-soon to be V-Bucket |
Posted: Thu Oct 02, 2008 10:58 am Post subject: |
Yes............please go.  _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
duginabug Samba Member
Joined: June 06, 2007 Posts: 481 Location: Washington State
Posted: Thu Oct 02, 2008 11:25 am Post subject: |
KTPhil wrote: |
WHAT?...live/drive in california...and obey traffic/safety laws?
What do you smoke for lunch?  _________________ 1960 Sedan. L349 Jade Green. |
AZ65CalBug Samba Member
Joined: December 08, 2001 Posts: 708 Location: Arizona
50ate Samba Member
Posted: Thu Oct 02, 2008 12:08 pm Post subject: |
Im not sayin i dont like em low... I run 6 in beam and drop spindles and im low out back.. But this guys shit is aird out in the pics It has to be. you would put driver weight plus gas and try to drive you would just sit and wheels would spin, its sittin on the ground.. Like i said looks cool. But kinda defeats the purpose of askin why he cant go 55mph. And as stated the e break cable looks really tight.. Plus to add there is no way this car moved any distance in this stance the pan, framhorns and jack mount would show highly visible signs of road rash and they dont.. That is why i called bs. But aird up and rollin i would suspect the tranny need attention not your motor |
'64cal lookdub 1200 Deluxe
Posted: Thu Oct 02, 2008 12:29 pm Post subject: |
Hotrodvw wrote: |
That e-brake cable looks a bit snug dewd...... |
I was thinking the same thing... |
n8murphy Samba Member
Joined: October 02, 2008 Posts: 198 Location: Pubnico, N.S./Malden, MA
Posted: Thu Oct 02, 2008 2:03 pm Post subject: |
I'm no expert but if you are able to drive through all the other gears with no powerloss its def your tranny, your engine dont know what gear your in, so id guess you got some worn out shit in the tranny. |
Posted: Thu Oct 02, 2008 6:52 pm Post subject: really,guys.....chew on this all the sh@talkers |
well, i never thought there were so many dicks on the samba. fu to all the people that insulted me. ha. really i have no feeling to speak of. if you didnt like it, i'm glad. you and your super will never get it. sorry super guys, i'm venting. you will never be apart of our club, no club to speak of, but people who think outside of the box and don't care.... its my bug and if i want to die in it, thats up to me. i think it looks bitchin and pretty much, thats all that matters. me and my friends dig it and if drivin stock shit is your thing, you did'nt see me knockin you in the forums. so there.
and yes, im bagged in the front.
"save string" |
Posted: Thu Oct 02, 2008 6:59 pm Post subject: sleuths on the samba |
nice work on guessing im bagged in the front. i have a small hump on my drive way and it sits on it. you guys really put on your sleuth caps for this one. i'm really impressed with some of you. thanks for the support from most of you and i got it fixed. wrong timing mark on the pulley. ha _________________ justin
"save string" |
6volt "THE" Kabriolet Kid
Joined: April 14, 2007 Posts: 470 Location: North Carolina
Posted: Thu Oct 02, 2008 7:02 pm Post subject: |
your car is bad ass buutttt lowerd bumpers are lame  |
