dreadnotmusic Samba Member
Joined: March 04, 2003 Posts: 880 Location: Guam, USA
Posted: Sat Oct 11, 2008 11:56 am Post subject: Windshield Lip Repair Help *FINISHED!* |
So I've taken the plunge and decided to fix my rusty lip the correct way. I've got the bus depot replacement lip on hand and have made a nice cut along the front of the rusty section.
There seem to be spot welds holding the rearmost section of the lip to the back panel. Can anyone offer advice on separating the two lips?
Thanks!
_________________ 66 Riviera
Last edited by dreadnotmusic on Sun Oct 26, 2008 5:47 pm; edited 1 time in total |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9156 Location: Syracuse, NY
Posted: Sat Oct 11, 2008 12:40 pm Post subject: |
Get a spot weld cutter. Drill them out. |
Posted: Sat Oct 11, 2008 12:53 pm Post subject: |
Thanks VDubTech...
Any chance Kragen or PepBoys carries these? Ace Hardware perhaps? _________________ 66 Riviera |
Bleyseng Samba Member
Posted: Sat Oct 11, 2008 1:08 pm Post subject: |
A FLAPS might or should but a auto paint store will have good ones with replacable teeth. Drill only thru the first layer of metal!!!! split the pieces with a sharp flat tool.
My trick when installing new metal is too lay it over the spot its going, tack it in at the lip and then using a dremmel cutting tool, cut along the edge of the new piece using it as a guide to fit it to the old. Then you have only a small 1/16th gap to weld and fill. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
gmag69 Type2 Nutcase
Joined: January 13, 2006 Posts: 1941 Location: northwest PA
Posted: Sat Oct 11, 2008 3:19 pm Post subject: |
dreadnotmusic wrote: |
Thanks VDubTech...
Any chance Kragen or PepBoys carries these? Ace Hardware perhaps? |
Harbor Freight had them here in Erie,PA. They are even the replaceable ones. I bought like 4 of them. They were like $4 a piece. Still on my first one.  _________________ Check out my Westy resto. thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=230285 |
Posted: Sat Oct 11, 2008 3:35 pm Post subject: |
Thanks guys, great tip on fitting the new one. I got the spot weld drills from a local auto body supply shop. Nice and easy, though I went deep in a couple spots.
Here is my progress so far. I'm going to have to fill a couple gaps, but not bad for a first timer!
Posted: Sat Oct 11, 2008 5:11 pm Post subject: |
looks good just keep fitting it til its really close as its hard to fill with the welder. Even with a MIG with gas its hard. I hope you are using a wire feed MIG with gas as thats pretty damn easy to weld lite gauge metal with. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
Posted: Sat Oct 11, 2008 5:15 pm Post subject: |
I'm using a Miller-Matic portable welder with .035 wire. The shielding gas for this unit is CO2 only due to the size of the bottles. I hope it's not too dirty.
I'm a bit worried about filling gaps. I don't know if the nose skin has relaxed and opened up the gap because there's much more of one than I measured for. I might have to cut some filler metal from some sheets that I have.
Oh,,,,this is my first weld job. I borrowed the unit from my work. I've never worked metal before.  _________________ 66 Riviera |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53051 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Oct 11, 2008 5:27 pm Post subject: |
OOooohhh.... this should be interesting, take lots of pics as you learn
Start by welding the outer edges, as things shrink the middle gap may close up.
Nothing wrong with Co2 but you really should get to know the welder on the scrap parts first, a W/S lip repair can go sideways really fast if you're a noob. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Paul D Samba Member
Joined: July 30, 2006 Posts: 565 Location: Far away from the fruits & nuts
Posted: Sun Oct 12, 2008 5:36 am Post subject: |
More pictures please!
I need some inspiration to see if I can do it myself, keep it up. _________________ 76 Fuel Injected Standard Bug
KantDriveFast wrote:
Quote: |
As cool as it is to find old VWs that have been sitting since the '70s, most of these are cut up (buses especially) and smell like weed and feet. Sad |
2VWs1BMW Samba Member
Posted: Sun Oct 12, 2008 6:28 am Post subject: |
Dread,
Don't worry about the nose skin so much. Get a bunch of small vice grips and clamp the repair pieces to the inner support and then trim the panel to fit to the nose. This took several iterations on mine, but the end results were perfect. _________________ - Brian -
'17 Alltrack
'99 ///M Coupe w/48k mi - Bimmerforums
'77 Westy w/156k mi |
Posted: Sun Oct 12, 2008 8:51 am Post subject: |
If you drilled through both panels with the spot weld cutter here's what you do. This goes for any place there is a gap you need to fill as long as you can get behind it. Get yourself a piece of copper pipe big enough to to cover the hole. Now smash one end of it flat leaving the other end open to use as handle. Now hold the flat part to the back of the hole and weld the hole closed. The weld will not stick to the copper and helps keep you from burning through the metal. Just a FYI. Keep up the good work.  _________________ Check out my Westy resto. thread.
Posted: Sun Oct 12, 2008 8:55 am Post subject: |
Good tip Geno, thanks. I'm probably going to wait on the welding until a co-worker comes over to assist. He does this for a living, and I don't want to screw it up. I bought a sheet of 22ga weldable steel because the replacement piece doesn't fully cover the section I had to cut out. I might have to fit a couple small strips in there to close the gap.
I've ground down all the rust on the inner lip and plan to spend the day laying a nice coat of silver POR15 on there. I don't want to do this again.
Thanks for the tips so far. My wife can't believe I cut a bit hole in our bus.  _________________ 66 Riviera |
PicklePickle Samba Member
Joined: February 24, 2008 Posts: 933 Location: Gonzales, LA
Posted: Sun Oct 12, 2008 11:36 am Post subject: |
Thanks for the tips so far. My wife can't believe I cut a bit hole in our bus.  |
Dude, you have some serious balls! First time welding job! I want to see how this comes out because I have never done an welding either and need to get the front lip fixed on my 78. _________________ "Aircooled VWs are like roaches in that if you let one in, they'll soon be nesting all around you in great numbers."
1970 Yellow Beetle aka "Melbourne" |
Joey Samba Member
Joined: August 12, 2005 Posts: 5376 Location: Nova Scotia - Canada
Posted: Sun Oct 12, 2008 12:03 pm Post subject: |
I'm using a Miller-Matic portable welder with .035 wire. |
I'd use .025". The thinner the metal, the smaller the wire. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Mon Oct 13, 2008 6:37 pm Post subject: |
Lot's of progress today! Thanks to a fellow VW enthusiast and welder from the local VW group "NAG" www.norcalaircooledgroup.org , I'm miles ahead of where I was yesterday. It's a tribute to the VW community that he was more than willing to drive 30 miles to my house and complete this job with no compensation. I objected, of course, on the compensation part. I can't thank him enough!
Posted: Tue Oct 14, 2008 3:26 am Post subject: |
Sweet. Glad to hear you got it fixed. It is cool someone was willing to come help ya out too. I guess VWs bring out the best in people.  _________________ Check out my Westy resto. thread.
Posted: Wed Oct 22, 2008 3:45 pm Post subject: |
Alright, several folks asked for a follow up on this so here's where I'm at. Here's a shot of the repair just after the welds were all ground down and a nice coat of POR15 was added and then sanded.
Here she is rolled outside to check the sanding and filler work I did. Not much filler used at all. Everglass filler went on first to smooth things out and then a light skim of Metal Glaze to cover the pin holes.
Here's how it sits now, with a nice coat of Epoxy primer. I'm waiting on a painter to come over and give me a quote on spraying the front panel. I want my bus back on the road!
Patrick199 Samba Member
Joined: June 29, 2006 Posts: 550 Location: Menlo Park, California, USA
Posted: Wed Oct 22, 2008 7:43 pm Post subject: |
Quote: |
I'm waiting on a painter |
i know painters. this could be a long wait.
Quote: |
I want my bus back on the road! |
Paint it yourself. If you can do the prep, you can paint too. |
