won't idle after muffler change
bus boy john
bus boy john is offline
PostPosted: Wed Oct 15, 2008 1:47 pm    Post subject: won't idle after muffler change Reply with quote
changed my muffler, that went well.
for reasons I had to remove the carb and pull the two left plugs.
all put back together and she runs great, except when I stop, she doesn't idle.
Is there something about the new "stock type" muffler that effects the running idle?
Leds all over my bus!
http://www.chromewiretie.com/nicholsonbus.html
hazetguy
hazetguy is offline
PostPosted: Wed Oct 15, 2008 1:51 pm    Post subject: Re: won't idle after muffler change Reply with quote
i'd really like to know what those reason were.
and maybe what size engine, what type engine, what carb set up you are running, what muffler you put on, you know, information that might help diagnose what is going on.
donemoto
donemoto is offline
PostPosted: Wed Oct 15, 2008 2:03 pm    Post subject: Reply with quote
Check to make sure wires to idle solinoid and choke are back on in place.
1975 Campmobile
1962 Bug Convertible
Homebuilt VW Trike
1966 HD Sprint H
1940 HD ULH Flathead
1985 Electra-glide Classic with Tour-Pac
1968 Harley Rapido
1968 Honda CL Scrambler 175cc
1962 Honda Cub 50 Step-thru
1980 Honda Cub 70
bus boy john
PostPosted: Wed Oct 15, 2008 2:18 pm    Post subject: Reply with quote
you hit it on the head, one of the wires to the coil was off, must have hit it.
the reason I had to remove the carb and the two left plugs. PO had an AC unit it it. I removed all but some kind of plate/bracket that held something in the engine sections. couldn't remove the tins without getting rid of the bracket.
thanks again
ps:
on removing the muffler-
All went as hard as I expected and as well as I hoped for.
took my time, had a little trouble figuring our all the parts from all the kits.
Should be quieter, maybe a little warmer for when it gets down to the 40s.
whoever designed the heater exchange/muffler and everything else down there, must have been either a tiny hand person with tiny tools or a sadist.
donemoto
donemoto is offline
PostPosted: Wed Oct 15, 2008 2:31 pm    Post subject: Reply with quote
Muffler was designed by an anal engineer with a bean counting accountant as an assistant. Laughing
Glad it was easy for you. Always doublecheck your work
One night I put a engine in my singlecab.. It ran just fine except I forgot the clutch Rolling Eyes Embarassed I don't work drunk in dark, anymore. Twisted Evil
1975 Campmobile
Homebuilt VW Trike
1966 HD Sprint H
1968 Harley Rapido
1980 Honda Cub 70
