Vanagon Gas Heater?
OhChit
OhChit is offline
PostPosted: Thu Sep 11, 2008 3:17 pm    Post subject: Vanagon Gas Heater? Reply with quote
I searched the Forum but didn't see anything to answer my question. My question is how do I or can I install a Gas Heater in my mid 80's Vanagon. I use to have one in my older AC Bay Window and really loved it. What's my best affordable choice if I want to install one. Can I install a B2 or B4, has anyone done this or is there a better solution for camping in chilly weather? I was considering the B2 or B4 for several reasons, one parts availablity also it would be an installed item that wouldn't get triped over, etc. What's your thoughts?
woggs1
woggs1 is offline
PostPosted: Thu Sep 11, 2008 3:40 pm    Post subject: Re: Vanagon Gas Heater? Reply with quote
What do you mean by "gas"? Propane or petroleum?
4 speed 88 Westy
foodeater
foodeater is offline
PostPosted: Thu Sep 11, 2008 4:08 pm    Post subject: Reply with quote
The gas(oline) heaters are are much more common on the air-cooled Vanagons. In fact I cant think of ever seeing a US model water-cooled Vanagon with one, the reason being it was easier, cheaper, and almost as effective for VW to just put in that leaky rear heater we all know and love.
I had an air-cooled vanagon that had the gas heater, and it was great. one of my favorite things about it was that you could run it with the motor off and it worked just as well. I think your best bet would be the classifieds section here or on ebay.
Heres an ad for one http://www.thesamba.com/vw/classifieds/detail.php?id=451726
I think it would be best if you could find one in a junkyard. or on a van someone is parting out, so that you could take everything that you'll need off the van yourself.That way you'll get to see how everything gets connected. Dont forget the switches, relays, and other little bits that might not come with it if someone else took it off the van.
89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
OhChit
OhChit is offline
PostPosted: Thu Sep 11, 2008 6:32 pm    Post subject: Reply with quote
Yep. I really liked the old style gas blower / heater in aircooled VDubs also. Heck they used the same fuel as the engine, and would keep the van nice and toasty using very little fuel. That's exactly why I was thinking of the gas heater idea. I realize that the newer Vanagon gas heaters are expensive and more complicated, then the earlier styles, that's why I was trying to think of a reason why not to install the older style? Think about all of the parts etc that are still avalible for those style heaters. Question
r39o
Samba Polizei
r39o is offline
PostPosted: Thu Sep 11, 2008 6:33 pm    Post subject: Reply with quote
My neighbor didn't know he had the factory gasoline heater until one day he asked me what a particular knob was for!!!!
That is in an 85 wbx with a sunroof but no A/C.
carterzest
carterzest is offline
PostPosted: Thu Sep 11, 2008 6:38 pm    Post subject: Re: Vanagon Gas Heater? Reply with quote
I almost sprung for an Espar, fromerly known as Eberspacher and did a bunch of research on them. Found them at Thermoking NW....Spendy but very nice..[url] http://tknw.com/products/Espar [/url]. I think the model was BN4 nowadays....
http://tknw.com/showcaseproductdetail.htm?ID=5802584&Brand=364&Type=3100
Site seems harder to navigate than it was before.
I also found some nice ones at Westmarine.......Often you can find used ones, but personally I would go with new. Still may do it but for now, I sold the 1980 Westy and got a 1991 Westy with much better/faster heat!
For a temporary fix, you can buy a MR HEATER portable unit. You can buy one almost anywhere... Works fantastic and on low will last @ 24 hours...plus it has built in shutoff Co2 alarm/feature. My wife will not camp without it anymore! I like it because I just use it to take the chill off in the morning before making coffee and breakfast...My small propane canister has lasted three weekends, two nights and is still about half full...but, it has been summer so not so cold! Very Happy I think it has auto shutoff if tipped over and it fits really well between front seats...My dog found the new "G'spot in the van!
Happiness=Portland, Oregon in the rearview mirror!
FNGRUVN
FNGRUVN is offline
PostPosted: Thu Sep 11, 2008 7:49 pm    Post subject: Reply with quote
Have you considered a Propex heater? New technology at half the size and weight.
airkooledchris
airkooledchris is offline
PostPosted: Thu Sep 11, 2008 10:43 pm    Post subject: Reply with quote
i have a BA6 in my ac Vanagon and its simply awesome.
hardly uses much fuel and puts out a ridiculous amount of heat....
only drawback is the thing needs juice to keep going so watch your battery and/or run a deep cycle battery... there is also a timer and you can only run it for a little bit before you would need to manually start that process again.
im sure there is a way to run it constantly by hacking something, or getting a real unlimited timer for it - but you'd have to search around, It's not something ive looked in to. unless your staying somewhere really really cold, you can usually get away with just firing it up before bed and once in the morning and your set.
Robw_z
Robw_z is offline
PostPosted: Fri Sep 12, 2008 12:43 am    Post subject: Reply with quote
What is the likelihood of finding one of these in an old junkyard aircooled bus? How are they installed in a Vanagon? I'm gonna need some heat this winter but a Propex is out of my price range.
-Rob
Wellington
Wellington is offline
PostPosted: Fri Sep 12, 2008 4:27 am    Post subject: Reply with quote
The BA6 was an option in Canada. I have one factory fitted in my !985 Westfalia and love it. The P.O. I think took every option available at the time. As well I have the heater under the rear seat, but the gasoline heater is instant. Great for those rainy camping walks. It will run your battery down if used a lot. The switch has a timer in it, so you can set it for a predetermined run "time"
carterzest
PostPosted: Fri Sep 12, 2008 4:53 am    Post subject: Reply with quote
-Rob
Mr Heater, thats my name, that name again is Mr Heater...Sorry, obscure Simpsons reference....Mr Plow! Razz
I seriously cannot use mine on high....Also, for witner camping, I/We sleep down below with the top down and not popped!
http://www.mrheater.com/productdetails_extended.asp?catid=41&id=24
Model MH9B - Buddy Portable LP Gas Heater
Certified by CSA International (American Gas Association), Mr. Heater's Portable Buddy heater features a low oxygen safety shutoff pilot to provide safe, reliable propane heat indoors. The Portable Buddy gives you instant heat anytime!
Please note: The Portable Buddy is Certified for Outdoor Use Only In Canada
• Designed and approved for indoor use
• Automatic low-oxygen shut off system
• Uses 1 lb. or 20 lb. propane cylinder with optional hose connection
(Mr. Heater Stock #F273701/02)
• Free standing or wall mount
• Quiet, odor-free, lightweight, portable
• Easy to carry
• 4,000 & 9,000 BTU high and low setting
• Heats up to 200 square feet
FOR RECREATIONAL AND COMMERCIAL USE:
• Tents
• Cabins
• Garage/Workshops
• Enclosed Porches
• Barns
• Ice Fishing Shanties
• Truck Caps
• Campers
• RVs/Mobile Homes/Trailers
• Storage & Tool Sheds
• Camp Buildings
• Construction Trailers
• Patios/Enclosures
• Picnic Shelters
• Work Enclosures
• Hunting Blinds
• Camp Shelters
• Tailgate Parties
• Outdoor Event Booths
• Horse Trailers
coolwind57
coolwind57 is offline
PostPosted: Fri Sep 12, 2008 5:23 am    Post subject: Reply with quote
foodeater wrote:
...In fact I cant think of ever seeing a US model water-cooled Vanagon with one, the reason being it was easier, cheaper, and almost as effective for VW to just put in that leaky rear heater we all know and love.
My 83 water-cooled Diesel has one. Of course it runs on diesel. Has a glow plug igniter and everything. I just need to get the thing operating before this winter. The bently is chock full of troubleshooting these things and I just have to find some time to do it.
1983 Vanagon Diesel L
NA 1.6, 5-speed Manual
Burning Waste Vegetable Oil, baby!!
airkooledchris
PostPosted: Fri Sep 12, 2008 9:21 am    Post subject: Reply with quote
As mentioned above I have a BA6 and it is awesome, however having said that, for the money and time you would need to install it into your van - the Mr Heater units are a GREAT alternate.
You wont run your battery dead and these suckers really pump out a LOT of heat.
not a good solution if you want it for driving around, but for camping, they are steller.
for driving around, id try to get a complete unit that you pull yourself locally, so you know how all of these old parts fit together. otherwise, for the time and money you'd end up spending adapting a misc eBay purchased one to your van - you'd probably end up wishing you just did the propex - not to mention the propex would retain its value if you were to ever get rid of the van (justification?)
OhChit
OhChit is offline
PostPosted: Fri Sep 12, 2008 2:11 pm    Post subject: Reply with quote
Yes, the Mr Heater Propex units are very nice but I just refuse to spend that kind of money on something that we'll only use seasonal. Heck for a few bucks I'd rather pickup one of those small propane Coleman heaters to run simply to get the chill out of the van. My goal is to either install the gas BN2 or the newer style Vanagon gas heater. A while back I saw a complete Westy in a scrap yard that still had a gas heater installed and when I get back to that yard my 1st mission will be to see if the heater is still intact? I'm actually leaning towards the BN2 due to their small size, reasonably priced, and abundant parts availability. Not to mention it's a solid performer. Yes I realize that it's a smaller heater, but the key here is to get enough heat to take the chill out, not bulding a Vanagon Steam room. Besides that there's always the hot water engine heater, and reguardless what heater anyone uses, I would suggest adding an inexpensive CO2 / fire sensor inside of your Van for safety reasons etc. By the way, I remembered seeing some place where a guy added a very small DC Computer fan "most all computers use 12V DC fans" above his gally stove and also used it as an exhaust fan, it was ducted outside. Anyone ever done this, those small fans only pull about 1amp of power yet move alot of air. Something like this could serve several usages, and work well as a fresh air ventilating system in conjunction with a heater if run for extended time.
mightyart
mightyart is offline
PostPosted: Fri Sep 12, 2008 2:39 pm    Post subject: Reply with quote
Propex and Mr heater are very differant heaters.
Propex=permenant install $1,000
Mr heater= small space heater $70.00.
Bn2, BN4, Ba6, Da6 are great heaters but suck up way to much juice.
Here's a page on installing the BA6 in an aircooled Vanagon, that didn't come with one.
p://www.type2.com/bartnik/ba6art.htm
pb24ss
Location: sitting around the fire with the bluegrass band - colorado
pb24ss is offline
PostPosted: Fri Oct 24, 2008 9:01 am    Post subject: Re: Vanagon Gas Heater? Reply with quote
I did spring for an espar. i installed an airtronic d2 in my bay westy. it works great for winter driving and for winter camping. here's some pics of the install...
http://pictures.radom.org/v/vw/projects/heating/airtronic/installation/
by far this is the best thing i've ever purchased for my VW.
Sodo
Sodo is offline
PostPosted: Fri Oct 24, 2008 10:21 pm    Post subject: Reply with quote
r39o wrote:
My neighbor didn't know he had the factory gasoline heater until one day he asked me what a particular knob was for!!!! That is in an 85 wbx with a sunroof but no A/C.
I had an '85 with the VW gasoline heater. It was a Canada Van. Its been about 3 years since I sold the Van to a guy in Grass Valley, CA.
You have to get out of bed, WALK up to the dash and turn on the timer, which runs a blower about as loud as the Defrost fan on High. It runs at full blast, lots of HOT air, for about 6 minutes, and shuts off. You don't just turn it on in the morning and go back to sleep, you have to keep getting up to reset the timer, and while its running you can't sleep anyway.
If a van has it, that's great, but I would not go to a lot of trouble to install one when there are quieter, thermostat controlled heaters on the market. It was not a "comfort heater", more like for warming up after skiing, it was fabulous for that!
Tom
....KTMs, GasGas, SPOT mtb
Jon_slider
Jon_slider is offline
PostPosted: Sat Oct 25, 2008 7:47 am    Post subject: Reply with quote
to get heat, we have to tolerate noise
the reason those timers turn off is to save the starter battery
it is best to have an auxiliary battery if you intend to run a fan powered heater.
It is not, in my opinion, realistic to run a propex or any fan powered heater while you are sleeping, unless you wear earplugs.
My propex is louder than my stock rear heater fan on position 2.
I also dont think it is safe to run a Mr. Heater Buddy while sleeping. They require an open window, and they produce a lot of moisture, as well as smelling bad if you use them above 8000 feet.
imo, a Coleman Catalytic heater is MUCH safer than a Heater buddy.. they burn cleaner
As far as the thermostat feature, imho, it is overrated. I usually just turn my propex on and off by hand, to save propane.
I think one of the gasoline powered heaters would be an excellent alternative to a propane powered one. Then you dont have to keep worrying about when you will run out of propane, since there is no gauge on the propane tank..
airkooledchris
PostPosted: Sat Oct 25, 2008 2:57 pm    Post subject: Reply with quote
the Buddy heaters are Catalytic also, just like those coleman black cats that everyone was using a few years back.
is there a way to beat the 'switch' on the heater-timer so you could run it longer if you wanted to?
I have a dual battery setup and when camping I switch everything in the vehicle over to the deep cycle and would like to run the heater a BIT longer while sleeping in the morning without having to get up and re-do it over and over.
Texxxxx
Texxxxx is offline
PostPosted: Sat Oct 25, 2008 6:59 pm    Post subject: Reply with quote
I finally got to use my Propex for the first time camping since I installed it this last Summer. The noise didn't bother me too much. Sometimes it would wake me up when it came on and sometimes it didn't. I imagine it well affect people differently. It did work very well...we were at 8500' and 15 degrees. High desert BLM land outside of Bodie.
Thermostat worked well for me. Kept the van just right all night. I don't have a propane fridge (wish I did), however, so propane use is less of an issue.
'85 GL w/2.1L "The Tardis"
It's A Vanagon Day
