volksauto Samba Member
Posted: Sat Oct 25, 2008 2:23 pm Post subject: 4 Way flashers in a oval?? |
| I want to hook up 4way flasher"s in my oval. I need to know how to wire it. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26598 Location: Douglas, WY
Posted: Sun Oct 26, 2008 6:47 am Post subject: |
VW basically had two ways of doing it - either a large relay with a fairly simple dash switch that would connect all 4 lights together and to a flasher relay, or by a more complicated dash switch and a basic flasher relay that would do it. On an oval with the tail-lights set up like the Bus was, you could go with the setup they used on Busses. Is yours 6V or 12V?
-Andy |
bearlyhigh Samba Member
Posted: Mon Oct 27, 2008 11:04 am Post subject: |
I'd like to hook mine as follows:
"a more complicated dash switch and a basic flasher relay that would do it."
Any wiring diagrams out there or what parts are needed? links to the part would be helpful. |
Posted: Mon Oct 27, 2008 11:41 am Post subject: |
| I was waiting to find out if he was wanting to do it 6V or 12V before I posted parts links and diagrams. (when I first replied, I was also out of town in a motel room and didn't feel like digging that info up at that time as well) |
Posted: Mon Oct 27, 2008 4:21 pm Post subject: 4 Way Flashers |
| My oval is 12v. I have a 4way flasher switch from a bus. hooked it up but when I turn on the blinkers all of the lights flash and when I turn on the 4 way flashers the I get the same result. |
Posted: Tue Oct 28, 2008 10:54 am Post subject: |
| glutamodo wrote: |
Well, I have a 12v setup....what parts do you suggest if I were to use a push button switch and a 4 way flasher? |
Posted: Tue Oct 28, 2008 11:02 am Post subject: |
| I'm working on this right now, I'll have some info and a diagram up in a few minutes here. |
Posted: Wed Oct 29, 2008 4:34 am Post subject: |
| Thanks Andy....will give it a try when I get the switch. |
Posted: Thu Oct 30, 2008 4:15 pm Post subject: 4 way |
| Thanks for the info |
Posted: Sat Dec 13, 2008 4:46 am Post subject: |
| Got it to work like a charm....Anyone know where I can get the bulb for the switch?? |
AlanInMass54 Samba Member
Joined: August 29, 2003 Posts: 1112 Location: Massachusetts
Posted: Sat Dec 13, 2008 6:04 am Post subject: |
| If it's 12 volt thats gonna be a N0177512, same bulb as in late model Golf/Jetta heater and A/C control panels, among other things. So most dealers should have it. |
eth727 Samba Member
Joined: February 21, 2007 Posts: 542 Location: san diego
Posted: Sat Dec 13, 2008 8:06 pm Post subject: |
| putting 4 way flashers in a oval is a stupid idea. you're going to drill your dash and put a out of place looking switch that will just decline the value of your oval. no one is going to notice if you have them on unless you put superbeetle lights. don't waste your time with that modern safety crap. |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1397 Location: Bella Coma Canada
Posted: Sat Dec 13, 2008 8:55 pm Post subject: |
| eth727 wrote: |
We installed our 4 Way switch in the glove box _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'69 Karmann Ghia Convertible (new project)
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS |
Posted: Sat Dec 13, 2008 9:14 pm Post subject: 4 way flashers |
I asked the question if anybody had wired up 4 way flashers because
I all ready had a hole in my dash for a choke. I have installed a 1600 dual port motor and it has a electric choke . as for value of my car or any safety crap that you might not notice your imput was a waste of time. The short of it, I am tring to fill a hole in the dash not cut another one and I have some extra parts from a 67, and one of the switches is a 4 way flasher switch. |
Posted: Sun Dec 14, 2008 6:59 am Post subject: |
| sombody else had already cut a hole in the dash for an emrgency flasher...just filling in the hole. |
