fazool666 Samba Member
Posted: Mon Nov 17, 2008 9:07 am Post subject: Quart low after 200mi !?!?!?! |
I just recently installed a new 1776 in my beetle and have put apx. 1200 miles so far on the engine. I changed the oil at 500mi after break-in and have no visible leaks anywhere and do not seem to be burning any oil either. I decided to take the car on a road trip this past weekend and when I reached my destination, I checked the oil and noticed it was apx. 1 qt low!?!? I did a visual inspection and the entire engine is dry with no visible leaks except for the breather vent tube that runs through my tin was wet with a little oil (which I would assume would be normal). Anyway, added a quart and on the return trip found I was a quart low again when I got home. I looked around again and nothing except the vent tube was wet again. Now is it possible to blow a quart every 200mi out of the vent? Does this seem excessive to anyone and if this is the problem, is there any better breather system that allows the oil to return to the crankcase automatically?
This is currently what is on the engine with a vent tube - http://cbperformance.com/catalog.asp?ProductID=244
Thanks! |
junior55 Samba Member
Posted: Mon Nov 17, 2008 9:23 am Post subject: |
I would consider a piped-type vent box mounted up towards the top of the engine. I have a bugpack vent box and run the oil-filler pipe and my two vented valve covers into it. I like it.
General rule of thumb is that going beyond stock cc's creates additional turbulence and some venting problems, so you very well might be spraying out that amount of oil over a 200 mile trip.
You wanna hope this is it..
Given the other oil loss possibilities, this one would be the easiest fix. |
Posted: Mon Nov 17, 2008 9:59 am Post subject: |
| Yea I hope this is the issue as well. Thanks for the info! |
Posted: Mon Nov 17, 2008 2:30 pm Post subject: |
You could KEEP the filler that you have and go with the bugpac remote box like I have.
I haven't used the one that you have shown but many of my friends do.
Get a box of some sort... don't just run a tube. |
Jengel451 Samba Member
Joined: July 15, 2007 Posts: 479 Location: Greenacres, WA
Posted: Mon Nov 17, 2008 2:39 pm Post subject: |
That sounds a bit excessive. Your rings might not have fully bedded in, if which case, you could be burning a bit, as well as losing via blow by/vent tube.
check your compression as a sanity check. What oil did you use for break in and what are you running now? _________________ 63 Dee "lux Interior" RIP Lux
09 R1 Track Weapon
66 Ducati 160 Monza Jr
64 Ducati Mountaineer
72 Z50a PitMonster |
Posted: Mon Nov 17, 2008 2:48 pm Post subject: |
Motor was built by CPR / Steelbuggin and had 20W 50 for the break in. At 500mi changed to syn 0w 30. I was also thinking the same thing that it may not have broken in 100% yet. I plan on doing a comp. test as well just for piece of mind.
Posted: Mon Nov 17, 2008 2:55 pm Post subject: |
| fazool666 wrote: |
| Motor was built by CPR / Steelbuggin and had 20W 50 for the break in. At 500mi changed to syn 10w 30. I was also thinking the same thing that it may not have broken in 100% yet. I plan on doing a comp. test as well just for piece of mind. |
I would call them to be sure. But personally, I would not run synth that fast. I had to run dino, non detergent for almost 1000 miles before my rings started to really seat. 20/50 might be overkill as well.
Take a look at the oil sticky. _________________ 63 Dee "lux Interior" RIP Lux
09 R1 Track Weapon
Posted: Mon Nov 17, 2008 2:56 pm Post subject: |
| You may be right and I was iffy on putting syn that soon as well but figured i'd give it a shot. Like I said i'm gonna check comp and may even change out to reg oil for the time being until it seats further. What do you recommend for oil during break in? |
Posted: Mon Nov 17, 2008 3:00 pm Post subject: |
| fazool666 wrote: |
I use non-detergent 30w, with Comp Cams break in additive. Others have thier own methods. But that is what has worked for me. _________________ 63 Dee "lux Interior" RIP Lux
09 R1 Track Weapon
visibleink Samba Member
Joined: May 03, 2002 Posts: 1669 Location: Austin, Texas
Posted: Mon Nov 17, 2008 3:24 pm Post subject: |
| Jengel451 wrote: |
| fazool666 wrote: |
Take a look at the oil sticky. |
That was too fast to switch to synthetic.....it's great stuff but can prevent engines from properly breaking in.
Call Chico and do what he says. _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
<-- Helga, she slammed her dub in '53 and adjusted valves with her teeth |
Posted: Mon Nov 17, 2008 5:14 pm Post subject: |
| Just spoke to Chico and he said the same thing - oops! I will change out the oil tomorrow and let it go apx. 2000 mi before putting syn. Thanks for everyones input! |
Posted: Tue Nov 18, 2008 7:55 am Post subject: |
| fazool666 wrote: |
Did he say anything about rings possibly have not broken in?
You may want to run it hard and get it hot to help them seat properly. _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
Posted: Tue Nov 18, 2008 9:53 am Post subject: |
| He said rings are still in the process of breaking in and within 1500-2000mi it should not burn oil and thats when to start running syn. I was under the assumption that the rings were seated with the initial break-in when he ran the engine on the dyno according to an email he previously sent but didn't realize they would still need that much of a break-in |
Posted: Tue Nov 18, 2008 11:34 am Post subject: |
Could you let us know if your consumption goes down after a few more
thousand miles?
Maybe I have been lucky with the engines that I have run, but I
breezed into normal service of my engines without any noticable
oil consumption from day one on.. go figure. |
Posted: Tue Nov 18, 2008 11:38 am Post subject: |
| I'll definitely keep you updated - later today I'm gonna change out the oil and take it from there. I think it's the combo of both lack of a breather box at hwy speeds and that the rings are not 100% broken in as well BUT i'm still going to do a comp test for the hell of it. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11153 Location: Black Forest, CO
Posted: Tue Nov 18, 2008 11:42 am Post subject: |
running 20-50 on a new engine is stupid! I don't know if the engine has the thermostat/flaps, but if these are missing it can prevent the rings from properly breaking in, seen it 100x.
John
Aircooled.Net Inc. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Tue Nov 18, 2008 11:58 am Post subject: |
I thought so at first as well but figured the builder knows what he is doing!?!?! The question now is what do you recommend I put in when I change the oil today? Should I use straight 30 with comp additive like Jengel says? That sounds normal but I am in the Northeast where it's beginning to get cold.
Thanks for everyone's input  |
Posted: Tue Nov 18, 2008 12:11 pm Post subject: |
run 0-20 or 0-30.
Does it have a thermostat and flaps? If not, get them on there.
John
