remote filter...
vwfye
vwfye is offline
PostPosted: Thu Dec 04, 2008 11:35 am    Post subject: remote filter... Reply with quote
i've mounted a remote filter set up for my car, but i don't know what filter # to use.... anyone remember which number works for these?
64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK"
gixxer 711
gixxer 711 is offline
PostPosted: Thu Dec 04, 2008 11:56 am    Post subject: Reply with quote
looks like fram hp1 Wink Twisted Evil
Danny
Erik G
Erik G is offline
I want to say early rabbit, but I am unsure. If you search the bus forum, some people were just talking about it, and of course saying not to use fram filters. Wix or napa gold, but I already knew that part from my watercooled days
Notched
Notched is offline
PostPosted: Thu Dec 04, 2008 12:06 pm    Post subject: Reply with quote
I'm using a K&N, this was recommended to me. I can get you the number if you want Brian.
Don't use a regular Fram! I've heard that there are issues with the run-of-the-mill Pep Boys, Smucks, Wal*Mart cheapie Fram oil filters.
Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
localboy
Samba Longboarder
localboy is offline
PostPosted: Thu Dec 04, 2008 12:08 pm    Post subject: Reply with quote
PH8A also works, but is not high pressure designed and I've "heard" of them bursting. I use the HP1 myself.
One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project
Russ Wolfe
Russ Wolfe is offline
PostPosted: Thu Dec 04, 2008 12:11 pm    Post subject: Reply with quote
I think I have one that has been removed out in the shop that still has the filter installed.
I can go look at it.
BTW, did you know that a lot of the filters on the market all come off the same assembly line. Just different colored paint or stamp in the printer.
Gary: OK. Ima poop.
vwfye
vwfye is offline
PostPosted: Thu Dec 04, 2008 12:12 pm    Post subject: Reply with quote
i'm asking which HP1 guys or NAPA gold, or WIX #... i won't use an HP1 as i have had 2 rupture on other rides... I just need the # so i can get a NAPA gold (aka Wix) today. thanks!
1974 Ghia "PUK"
vwfye
vwfye is offline
PostPosted: Thu Dec 04, 2008 12:13 pm    Post subject: Reply with quote
yep! the Wix/Napa Gold use a plastic relief valve and the Fram uses a cardboard rv...
thanks russ i could use the #! i can cross reference it at the store tonight.
1974 Ghia "PUK"
localboy
Samba Longboarder
localboy is offline
PostPosted: Thu Dec 04, 2008 12:31 pm    Post subject: Reply with quote
Huh. Confused I've had HP1s since I've gotten the Notch running and no issues. The kit from GB even came w/ one.
I've got a MANN filter (German made) in the garage....the number on the box: W 940/25. Don't know if that helps. Confused
vwfye
vwfye is offline
PostPosted: Thu Dec 04, 2008 12:43 pm    Post subject: Reply with quote
thanks! yes, i had two HP1s fail in cold weather start ups.
1974 Ghia "PUK"
localboy
Samba Longboarder
localboy is offline
PostPosted: Thu Dec 04, 2008 12:45 pm    Post subject: Reply with quote
That's probably it. I don't start my car when it's cold. Wink
Erik G
Erik G is offline
PostPosted: Thu Dec 04, 2008 1:43 pm    Post subject: Reply with quote
if you cut up a fram filter, then go cut up a wix or napa gold filet, you will see why not to use a fram. they are junk, cardbord string and glue.. the relief valve is the main issue. Mann is a much better filter, wix or napa gold is the way to go, and they are not expensive
Erik G
Erik G is offline
PostPosted: Thu Dec 04, 2008 1:47 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=328494&highlight=fram
Erik G
Erik G is offline
PostPosted: Thu Dec 04, 2008 1:49 pm    Post subject: Reply with quote
also, the HP1 and the PH8a are the same thing, one has a bigger canister
vwfye
vwfye is offline
PostPosted: Thu Dec 04, 2008 3:07 pm    Post subject: Reply with quote
looks like the NAPA filter is FIL 1452. I will be picking one of those up this week! Thanks for the Mann #, that helped!
1974 Ghia "PUK"
localboy
Samba Longboarder
localboy is offline
PostPosted: Thu Dec 04, 2008 6:46 pm    Post subject: Reply with quote
Glad to be of service. I picked up the MANN for the next oil change [on the Notch] the last time I was in our local ACVW parts store.
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Thu Dec 04, 2008 7:23 pm    Post subject: Reply with quote
This guy likes the HP1:
http://www.aircooledtech.com/oil_filter/
I've been using HP1 since the day Gene Berg sent me one in my kit. Never an issue and seems to be doing it's job. I also run the Berg pressure relief valve so over-pressure isn't an issue for me in the cold...and my oil gauge proves it as well Wink
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
Erik G
Erik G is offline
PostPosted: Thu Dec 04, 2008 7:55 pm    Post subject: Reply with quote
better parts are better parts, fram is not owned by the company as it was back in the day. here is a long list of types, plus pics of them disassembled, etc http://www.knizefamily.net/minimopar/oilfilters/opinions.html
Air_Cooled_Nut
PostPosted: Thu Dec 04, 2008 9:12 pm    Post subject: Reply with quote
Yeah, I've seen that page and others. He does recommend HP1 for [Mopar] racing applications. Unfortunately, he doesn't have flow data, only observational.
The First Invasion
Russ Wolfe
PostPosted: Thu Dec 04, 2008 9:32 pm    Post subject: Reply with quote
One thing that he does not mention, and he may not be aware of it, but Mahle now owns Dana/Wix, and they also own Mann.
Most of their oil filters are assembled in China now.
We shipped a complete oil filter line that came out of Murfreesboro, TN last year to China.
Champion Filters is owned by a big conglomerate known as UCI. A competitor to Mahle.
Gary: OK. Ima poop.
