Spot Weld Cutters
mallred
mallred is offline
PostPosted: Wed Aug 13, 2008 10:14 pm    Post subject: Reply with quote
This thing works great.......as good or better than new, when used properly
http://www.drilldoctor.com/
I am very curious as to how these things work.
It looks like a pencil sharpener.
I learned to sharpen drill bits properly, during my millwright apprenticeship many years ago.
I find it hard to imagine how a pencil sharpener looking unit could cut the angles, and sweeps, you need on a properly sharpened bit.
I have heard many times they work well!
Can someone enlighten me?
Mark Allred
'64 Resto Custom Bug - Daily Driver
'57 Sunroof Bug - Endless Project
Living beneath the Sagebrush Canopy
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Sat Aug 16, 2008 7:35 pm    Post subject: Reply with quote
It may look like a "micky mouse" RONCO type machine but they work.
It only sharpens the points though....
They work decent... better than having a bunch of useless bits around
(not everyone is adept at old fashioned methods of sharpening bits like you may have learned in your trade/skill)
AND you can get TONS of bits CHEAP AS HELL at pawn shops and sharpen them and save a TON OF MONEY VS buying new bits all the time. Except for a few really small bits that can get broken or a very specific "lettered" or other odd sized bit... I have found pawn shops to have buckets of drill bits for sale for about 5-25 cents each!
http://www.drilldoctor.com/ftproot/500750X_Users%20Guide.pdf
finefettle
finefettle is offline
PostPosted: Sat Dec 06, 2008 2:54 pm    Post subject: Eastwood spot cutter Reply with quote
My Eastwood spot cutter lasted about 10 welds them gave up. I switched to Dewalt Pilot point drill bit (5/16 I believe) and it worked great.
poopdevil
poopdevil is offline
PostPosted: Tue Dec 09, 2008 7:43 pm    Post subject: Reply with quote
I am currently removing my rear package tray as it is rotten and i tried a 3/8 bit but it is hard to tell when to stop and i either go all the way thru or I make a dent but then have to try to pry it up and it never just pops loose..
TIPS?
How do I get it off without punching thru and not prying the crap out of around each weld. It leaves bits of metal behind that I have to grind down.
duginabug
duginabug is offline
PostPosted: Tue Dec 09, 2008 11:20 pm    Post subject: Reply with quote
This is what worked for me.
What I did was scuffed up the spot-welds with sandpaper to make then stand out, then make sure your centered on the weld. If the bit walks on you, you may have to use a center punch. The key is to drill SLOW. Not like stupid slow but with the thin metal you don’t want to go at it high speed. With a good sharp bit, steady speed and pressure, you should be able to cut the first layer of metal with one or two full turns of the bit.
1960 Sedan. L349 Jade Green.
Gary
Person of Interest
Gary is offline
PostPosted: Wed Dec 10, 2008 8:29 am    Post subject: Reply with quote
Use a center punch no matter what. Also, I recommend using a wire wheel on a drill to clean the sheet metal of paint, dirt, and rust. Some of those spot welds are almost invisible unless clean sheet metal is visible.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
The_Codeman
The_Codeman is offline
PostPosted: Wed Dec 10, 2008 4:00 pm    Post subject: Reply with quote
is used one of these from harbor freight when i replaced my front apron/tire tray.
3/8 is a little large but it did work very well for $4
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95343
codeman
AJ Quick
AJ Quick is offline
PostPosted: Sun Dec 28, 2008 8:03 pm    Post subject: Reply with quote
The ones I used that looked like that often had the teeth break off.
Read My Beetle Restoration Blog!
http://www.RideSpace.net/
http://www.AJQuick.com/
View user's profile Send private message Visit poster's website AIM Address Classifieds Feedback
poopdevil
PostPosted: Wed Mar 18, 2009 12:13 am    Post subject: Reply with quote
I ended up using the same one as you did there from harbor freight. Only thing is that yes the cut is pretty big. Anyone know where I could get one smaller in diameter?
I tried a drill bit also but it would barely do the job. Is there a specific bit that any of you used out there that made easy cuts?
Fritter
Fritter is offline
PostPosted: Wed Mar 18, 2009 4:07 pm    Post subject: Reply with quote
The Harbor Freight one worked great for me. Can't beat the price, even if a tooth or two breaks off after 50 spot welds. Just grab another!
finefettle
PostPosted: Thu Mar 19, 2009 7:37 am    Post subject: Irwin turbo max bits Reply with quote
I'm having success with Irwins turbomax bits. Better than pilot points. Just take your time.
poopdevil
PostPosted: Thu Mar 19, 2009 1:59 pm    Post subject: Reply with quote
Where did you get them at?
finefettle
PostPosted: Thu Mar 19, 2009 2:28 pm    Post subject: Irwin turbo max bits Reply with quote
I found a set at Lowes for around 15 bucks or so. It even had a 1/2" bit with it. I use oil when I drill and I've been using the same bit for 40+ spots so far. Still sharp Smile
Rob Timmons
Rob Timmons is offline
PostPosted: Thu Mar 26, 2009 6:56 pm    Post subject: Reply with quote
I have one similar to this but it is made by blair. I was breaking teeth like crazy until I decided to drill a small dimmple in the middle of the weld first. The bit stopped wandering and I now get a lot of cuts out of one bit.
Gary
Person of Interest
Gary is offline
PostPosted: Thu Apr 16, 2009 5:25 pm    Post subject: Reply with quote
Well, I bought one of these a few months back, but not from Eastwood. It was from a local tool store for the price of $17.70 for a 3/8" cutter.
I works great by cutting the metal on the top layer rather than requiring both panels be cut. I recommend it over those crappy cutters with the drill bit that has the circle with teeth on it. I tried one once and it couldn't even cut butter.
KYbuggy1
KYbuggy1 is offline
PostPosted: Tue Jun 09, 2009 9:31 pm    Post subject: Reply with quote
I drill more spot welds than I care to remember, every day practically. This is the back , elbow and wrist saving"est" tool I've ever purchased:
http://www.dentfix.com/viewItem.asp?idProduct=17&a...SS_Capable
Nearly effortless.
Hard to swallow the price at first, but WELL worth it in the long run. A hobbyist would never wear it out if it wasnt abused. Comes with an inline oiler attached.
And if you cant get to the backside, you can remove the clamp and it still works better than any spotcutter bit out there, and I've tried every single new thing that came along on the tool trucks until I bought the spitznagel.
Second best is the style of bits posted by finefettle, a very distant second.
Larry
'64 Beetle driver,stock 1600,dual baby webers
single seat competition hillclimb woodsbuggy 14:1 2500cc T1
inline 2 seater woodsbuggy 13:1 2387cc (son's)
3 seater woodsbuggy 10.5:1 2276cc (wife's)
http://woodsbuggy.com/ http://dandkoff-roadpark.com
uoduckfan89
uoduckfan89 is offline
PostPosted: Sun Jun 28, 2009 4:57 pm    Post subject: Newb to spot weld cutting Reply with quote
I'm rebuilding a 71 standard bug and I need to take the whole front end off (not worth fixing), what's the best way to get a good clean disassemble?
John Miller
John Miller is offline
PostPosted: Mon Aug 31, 2009 11:32 am    Post subject: Reply with quote
I just bought this one.
I'll never use anything else.
The 68 Ghia
The 62 Beetle
slafa wrote:
Any suggestions will be appreciated even if they suck and are stupid.
maggiolino basso
maggiolino basso is offline
PostPosted: Sat Oct 10, 2009 3:57 pm    Post subject: Reply with quote
codeman
These are the heat for the home welder/bodyman.... $4.99 plus tax at Harbor Freight..................
"Give a man a fish, feed him for a day, teach a man to weld you feed him for a lifetime"
http://maggiolinobasso.blogspot.com/
zuggbug
zuggbug is offline
PostPosted: Wed Oct 14, 2009 7:34 pm    Post subject: Reply with quote
I have been using these bits with a drill - very slow go and a lot of elbow grease - I just bought a Rigid impac driver
had to modify the bit a little but MAN!!!! Very Happy Very Happy it cut thru the metal like a hot knife cuts thru butter.
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
Page 3 of 4
