That awful laminate on all the wood (77 Camper)
Page: Previous  1, 2
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Jan 04, 2009 12:44 pm    Post subject: Reply with quote
BusBerd wrote:
greenbus pilot wrote:
chazz79 wrote:
dang! that suit is pimp.... I'd rock that anyday
......Needs a hat......! Cool
"crumpleface" said she could make a suit like that! You just need to send her the material. Laughing
PM her here:
http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=133204
Don't bite my style. People are just jealous because I did it first.
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
pfatt
pfatt is offline
PostPosted: Sun Jan 04, 2009 6:19 pm    Post subject: Reply with quote
[/img]https://www.thesamba.com/vw/gallery/pix/511250.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511249.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511248.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511225.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511236.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511237.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511238.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511239.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511240.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511241.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511242.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511243.jpg[img]
[/img]https://www.thesamba.com/vw/gallery/pix/511244.jpg[img]
Here are some pictures of what I ended up with after I delaminated all the cabinets. I stained them then put about 10 coats of Minwax Polycrylic clear coat on all of it. The work is not perfect, but the wood is distressed and I think it looks btter than what I would want off the shelf. I actually started filling in all the nicks and gouges but then decided to leave them. it looks just great that way.
pfatt
pfatt is offline
PostPosted: Sun Jan 04, 2009 6:29 pm    Post subject: Reply with quote
This is what I ended up with after delaminating all of the cabinets. I stained it all then put about 7 to 10 coats of Minwax polycrylic. I'm thrilled with the way it turned out.
iWANTBUS
iWANTBUS is offline
PostPosted: Sun Jan 04, 2009 6:34 pm    Post subject: Reply with quote
looks great!
Steelhead
Steelhead is offline
PostPosted: Sun Jan 04, 2009 10:43 pm    Post subject: Reply with quote
damn that looks so much better. Seriously, this is such a huge upgrade. Huge! Get cracking everyone...rip off that vinyl.
'77 Bay Window / '89 Caratsburg (aka. the Stormtrooper)
greenbus pilot
greenbus pilot is offline
PostPosted: Sun Jan 04, 2009 11:43 pm    Post subject: Reply with quote
PM her here:
Yeah Gruv, you got the suit, but I am gonna paint my house L63H!
( maybe when it warms up a bit......)
Razz
Sent from a white van down the street.
theizzardking
theizzardking is offline
PostPosted: Mon Jan 05, 2009 11:05 am    Post subject: Reply with quote
meh i'm leaving my alone cause after this thread having an all original westy interior will be worth some $$$$ with everyone modding everything!
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer"
Traveling Writer
Samba Scribe
Traveling Writer is offline
PostPosted: Mon Jan 05, 2009 4:39 pm    Post subject: Reply with quote
Looks great, and I'm definitely going to take the peeling, chipped laminate off mine and minwax it or something... BUT didn't I read somewhere that you shouldn't pack insulation into the door/wall cavities because it'll trap condensation from your snoring body and rust the heck out of the bus from the inside out??
Cheers,
Davi
1977 2.0 FI Westy
2011 1200cc Yamaha Super Tenere
1976 Feet (they work surprisingly well)
pfatt
pfatt is offline
PostPosted: Mon Jan 05, 2009 8:43 pm    Post subject: Reply with quote
well actually that insulation is original. I just left it in. There's no rust behind it whatsoever
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Mon Jan 05, 2009 9:19 pm    Post subject: Reply with quote
Same thought here. It was put there 30 years ago, and no rust at all.
Eric
VDubTech
VDubTech is offline
PostPosted: Mon Jan 05, 2009 9:30 pm    Post subject: Reply with quote
Easy to say when you live in a desert. Evil or Very Mad
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Mon Jan 05, 2009 9:33 pm    Post subject: Reply with quote
Hater. Razz
Eric
dan macmillan
dan macmillan is offline
PostPosted: Mon Jan 12, 2009 6:13 am    Post subject: Reply with quote
After looking seeing this thread and considering my laminate is badly chipped I decided to start removing it and doing a custom stain on the wood. I took the original posters advice re using an iron to remove it.
Although this works good, it was taking too much time for my liking. I found out that if you use a propane torch and heat the laminate till it starts to burn and bubble slightly, then just a little more, the glue will create a pressurized pocket that pushes the laminate free of the wood.
It does not burn the wood and makes removal fast and easy.
When using the iron I was taking the laminate off in small pieces. Using the torch I was able to remove it in complete sheets. It also leaves less glue residue on the wood. Later {probably today} I will take some pictures of the process and post them.
Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone
dbo550
dbo550 is offline
PostPosted: Mon Jan 12, 2009 11:03 am    Post subject: Reply with quote
I'm with izzardking on this. The generations of westy owners to come are gonna wonder what the hell we were thinking. So save what laminate you can so our kids can sell it on eBay to pay for college.
1985 Westy
2001 Audi Allroad
1999 Volvo v70 xc
1995 Volvo T5-R, Yellow
1998 Jetta GLX
dan macmillan
PostPosted: Mon Jan 12, 2009 6:36 pm    Post subject: Reply with quote
You purists will probably cry or at least leave your opinions on why we should not do this.
Time:
remove laminate 5 min,
sand wood 20 min
stain with ebony stain 5 min
clearcoat tommorrow, 10 min
Current projects:
Page: Previous  1, 2
Page 2 of 2
