Easy Syncro 2" lift
Tristar Eric
Tristar Eric is offline
PostPosted: Sat Feb 14, 2009 1:34 pm    Post subject: Easy Syncro 2" lift Reply with quote
Well here it is, the revised 2" lift. Some of you may recall the "budget 2" lift". I have to give credit for the idea to Herman in BC Canada for the basic idea. I had to revise it to work.
http://vanagonsyncroproject-herman.blogspot.com/
Herman's idea was simple, create a tubular sleeve that slides over the lower portion of the front strut.
I made a pair only to find that there was no room for the driveshaft. What needed to be done was offset the lower addition to allow room for the driveshaft.
The Syncro in my opinion is limited in how high you can lift it. 2" is the absolute limit without modifying the suspension.
The rear is lifted with a 2" upper spacer and a shock extender.
Before and after pics...
Shot of the lower front strut showing the offset.
Rear spacer and shock extender.
Vanagon/Transporter flares here: www.terrawagen.com
[email protected]
tencentlife
tencentlife is offline
PostPosted: Sat Feb 14, 2009 2:19 pm    Post subject: Reply with quote
I like the lower shock link idea in the rear, looks easy to build sturdily. Any reason that wouldn't be a good solution for the fronts as well? It would be easy to add a slight offset to the front links to clear the driveshaft if needed.
Experience is death to doctrine.
Tristar Eric
PostPosted: Sat Feb 14, 2009 2:27 pm    Post subject: Reply with quote
That was version 1, only issue was that you are forced to raise the front a minimum of 2". By adding a section under the strut you can lift as little as you like. I think it looks better also.
Version 1 :
[email protected]
tencentlife
PostPosted: Sat Feb 14, 2009 2:48 pm    Post subject: Reply with quote
I think you mean the first one shown was version 2?
Anyway, great ideas, all of them. Very cool. Gotta keep them in mind when I dig into my Syncro. It looks so lonely up on the stands in my shop. But the engine business beckons....
Thanks, Eric!
FNGRUVN
FNGRUVN is offline
PostPosted: Sat Feb 14, 2009 3:35 pm    Post subject: Reply with quote
Is there any chance that the rear shock mount might try to pivot and bend the shock's piston rod? I was thinking the rubber shock bushing might give just enough to throw the bottom out of alignment with the top. I'm probably wrong, but just a thought.
Tristar Eric
PostPosted: Sat Feb 14, 2009 5:46 pm    Post subject: Reply with quote
I ran that same setup on my Bundeswehr Syncro for over 4 years. The extender keeps the shock well lined up. It's the twist that does it.
[email protected]
dixoncj
dixoncj is offline
PostPosted: Sat Feb 14, 2009 7:47 pm    Post subject: Reply with quote
I have a Fast Forward kit with the rear donut. Didn't modify my stock Boge rears to do the job and they seem to be working fine. I thought about the add'l length being an issue but it hasn't seemed to have done much either way. Am I missing something?
canasync
canasync is offline
PostPosted: Sun Sep 04, 2011 9:25 pm    Post subject: Reply with quote
Installed a self-made version of Tristar Erics "Version 1" lift today. So far I am happy with the results.
1987 Syncro
3 knobs
PumpeDüse TDI (17mm Garret Turbo, bigger injectors, stage 4 malone tune, intercooled)
Cruise Control
Planar Coolant Heater
Remote Start/locks
Custom Lift
Custom Bumpers with receivers
Coast Mountain Hightop - Comming Soon
1985 2wd Vanagon Pre-runner in the making
soon to be powered by 2.5L Subaru
Custom Lift
Tristar Eric
PostPosted: Tue Sep 27, 2011 5:47 pm    Post subject: Reply with quote
Nice job! wasn't too hard was it?
[email protected]
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Sep 27, 2011 10:40 pm    Post subject: Reply with quote
How is the driving after that?
canasync
canasync is offline
PostPosted: Wed Sep 28, 2011 12:50 am    Post subject: Reply with quote
Yeah, it was really easy.
I quickly realized why you changed your front extenders to the Herman style spacers. I will be changing to those as well since I would like new springs which would then make the Syncro far too high. Plan right now is to have it about an inch lower once the I get the new lift done and new springs installed, till then I will run with what I got.
As for drivability, the reason that I went for this lift was so that I can keep the factory characteristics such as articulation however due to the new rear wheel position I no longer have the downward travel that I require and if I extend the travel I will run into CV problems which would mean switching over to 930 CV's (not in my budget at this time).
My quest for the best on/off road suspension setup continues.
Tristar Eric, if you have any tips for the version 2 easy lift let me know. What was the diameter of the tube that used to slip over the shocks?
1987 Syncro
3 knobs
Cruise Control
Remote Start/locks
Custom Lift
Custom Lift
buspor63
buspor63 is offline
PostPosted: Wed Sep 28, 2011 5:58 am    Post subject: Reply with quote
Are those tube extenders slip over or are they tack welded in place? If welded, are there any dangers to be aware of?
Imagine that, theres not an "h" in either Westfalia or Syncro?
hege
hege is offline
PostPosted: Wed Sep 28, 2011 6:29 am    Post subject: Reply with quote
Monotube shocks usually have 100-200psi pressure, so when welding one of them it's better to dismantle them. Twintube shocks that generally are in cars, don't have a high pressure (5psi? correct me if I'm wrong here, haven't worked on twin tube with pressure) because they don't need the high pressure to work.
Funny that this thread came to life. I extended my front shocks yesterday:
Now when reading this I wish I had lenghtened it more. I only extended the shock 0.7". Embarassed
Did it like one of my friends recommended: Cut the eyelet out, tack weld it together and check alignment and finally then weld like hell and throw it in a bucket of water.
SyncroGhia
SyncroGhia is offline
PostPosted: Wed Sep 28, 2011 8:21 am    Post subject: Reply with quote
I'm ok with the tube lengthening idea up front but not so sure about having 2 sets of rubber joints on one end of the shock absorbers, especially at the front as I can picture them going into all sorts of odd positions when under high load plus you are asking a bush (twisting it 90o) to work in an angle it wasn't designed to move in at that range.
If the lower mounting point up front is fixed, then you will run out of articulation on the bottom of the shock absorber as the suspension goes through it's full range of movement.
Not trying to shoot it down in flames... just my opinion. I'm all for new ideas and trying stuff out. Very Happy
MG
T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
dubbified
dubbified is offline
PostPosted: Sat Jun 23, 2012 4:44 pm    Post subject: Reply with quote
Version 1 :
how are these shackle lift dealies workin out?
I have a set of Konis that I envision this mod for, to get the extra 1.5-2 inches on so they mount right with these GW lifting springs...
Thanks!
PM sent as well,
Al
